POV-Ray : Newsgroups : povray.advanced-users : Override textures/materials? Server Time
7 Mar 2026 02:01:58 EST (-0500)
  Override textures/materials? (Message 1 to 10 of 31)
Subject: Override textures/materials?
Date: 18 Jun 2021 08:42:01
Message: <60cc9499$1@news.povray.org>
Is there a way to override textures or materials that have already been
declared or applied?
I am trying to create a depth map, and need to apply a custom texture to
the entire object.
Thanks.
Mike
Subject: Re: Override textures/materials?
Date: 18 Jun 2021 08:43:45
Message: <60cc9501$1@news.povray.org>
> the entire object.
> Thanks.
> Mike
Specifying an empty texture
texture {}
to the original object does not seem to do the trick.
Mike
Date: 18 Jun 2021 09:30:45
Message: <60cca005$1@news.povray.org>
Am 18.06.2021 um 14:41 schrieb Mike Horvath:
> the entire object.
If the object in question is a primitive, then I _think_ this should be
possible simply by referencing the object in question and specifying a
new `texture` block, like so:
     // original object
     #declare OriginalObject = sphere { ... texture { ... } };
     // override texture
     #declare ClonedObject = object { OriginalObject texture { ... } };
However, if the object in question is a compound object (merge, union or
the like), then I don't think it is possible. At least if the texture is
defined at the component level.
The reason is that the mechanism is designed for use cases in which part
of a compound object's textures are defined while others can be
overridden later. Think e.g. a car, where you can later apply the
texture to use for the car's body, but all the other textures like rims,
tyres, headlights, windscreen etc. are already fixed and immutable.
To achive this, a "texture override" on compound objects only affects
those components that have no explicit texture definition of their own,
while all other components will cling to their textures like superglue.
Date: 18 Jun 2021 10:44:05
Message: <60ccb135$1@news.povray.org>
> the entire object.
> Thanks.
> Mike
In the case of a texture or material that have been declared but not
used yet, a new #declare will completely replace the original with the
new definition.
If it have been applied to something, then redefined, then, any object
that received it will keep the original definition.
In your case, you need to remove, or at least comment out, any texture
or material from your object. Then, apply your new texture to that
object as a whole.
Date: 18 Jun 2021 13:35:00
Message: <web.60ccd8d4eaa343741f9dae3025979125@news.povray.org>
What if you union everything together and do an intersection with a box that is
the size of the union's bounding box?  The intersection ought to be its own
object that you can give a fresh texture to.
Date: 18 Jun 2021 13:50:19
Message: <60ccdcdb$1@news.povray.org>
>> been declared or applied?
>> to the entire object.
>      // original object
>      // override texture
It would be nice if I could flag a texture as "important" such that it
overrides all previously defined textures. I can do this in CSS and it
is very handy.
Mike
Date: 18 Jun 2021 13:50:37
Message: <60ccdced$1@news.povray.org>
Interesting. I will try this.
Mike
Date: 18 Jun 2021 13:52:19
Message: <60ccdd53$1@news.povray.org>
>> Thanks.
>> Mike
> new definition.
> object as a whole.
Instead of declaring my textures, I may start using macros instead. That
way, I can just comment out the texture declaration inside the macro.
But might this not consume more memory?
Mike
Date: 18 Jun 2021 14:20:00
Message: <web.60cce2aeeaa34374d81232a3b7ae6630@news.povray.org>
> the entire object.
> Thanks.
> Mike
Hi Mike,
for depth_maps I use a variable to change every finish ( e.g. finish {specular
dfac*0.3 roughness 0.0003 diffuse dfac*0.6 reflection {dfac*0.03, dfac*0.1}}.
For the "normal" render dfac is defined as 1 and for depthmaps or other
effectmaps dfac is 0.
Together with a white fog you get your depthmap.
Norbert
Date: 18 Jun 2021 14:53:20
Message: <60cceba0$1@news.povray.org>
Am 18.06.2021 um 19:33 schrieb Bald Eagle:
That's a smart idea.
You may need to specify `cutaway_textures` though, and I'm not sure
whether it does indeed work with objects that are already explicitly
textured.
