POV-Ray : Newsgroups : povray.advanced-users : Fake shadows in 32-bit images? Server Time
7 Mar 2026 02:03:04 EST (-0500)
  Fake shadows in 32-bit images? (Message 1 to 10 of 21)
Subject: Fake shadows in 32-bit images?
Date: 3 May 2021 23:59:40
Message: <6090c6ac$1@news.povray.org>
I know it's possible to create separate 8-bit shadows and 32-bit sprites
in separate processes and then alter them in Photoshop. But could it be
possible to do this all in one step in POV-Ray?
What I mean is, render a sprite of a 3D object with transparent
background, but also give the object a semi-transparent shadow.
Thanks!
Mike
Subject: Re: Fake shadows in 32-bit images?
Date: 4 May 2021 02:35:00
Message: <web.6090e9d07599ad5279819d986cde94f1@news.povray.org>
hi,
no idea, but there's related info in the docs:
<https://wiki.povray.org/content/Reference:Image_Map#The_Filter_and_Transmit_Bitmap_Modifiers>
regards, jr.
Date: 4 May 2021 05:55:00
Message: <web.609118ca7599ad521f9dae3025979125@news.povray.org>
http://www.imagico.de/pov/icons.php
Date: 4 May 2021 11:17:07
Message: <XnsAD20AFD4BA02Fseed7@news.povray.org>
in news:6090c6ac$1@news.povray.org Mike Horvath wrote:
> But could it be
Never tried it, maybe with the user defined camera?
Ingo
Date: 4 May 2021 14:25:00
Message: <web.609191017599ad521f9dae3025979125@news.povray.org>
There might be a way to do this with functions, aoi, slope, or some other
method...
But a quick and dirty cheat like this works:
Take your object(s) and put all of the parts in a merge.
Define a vector location LS for your light source.
Define a second vector location LS2 that is -vnormalize(LS) so that it is
mirrored across the origin.
Define a matrix transform with LS2 as your new y basis vector.
Put your object in the scene with the no_shadow keyword.
Put your object in the scene again, apply the matrix transform, and scale it
really small in the y direction, and apply your semi-transparent texture to it.
#version 3.8;
global_settings {assumed_gamma 1}
 location <0, 5, -9>
 look_at 0
sky_sphere {pigment {rgb 1}}
#declare LS = <5, 15, -10>;
light_source {LS color rgb 1}
#declare E = 0.000001;
#declare LS2 = -vnormalize (LS);
#declare ShadowTrans = transform {
 matrix < 1, 0, 0,
   LS2.x, LS2.y, LS2.z
   0, 0, 1,
   0, 0, 0
#declare Object =
merge {
 cylinder {0, y, 0.05}
 sphere {y, 0.25}
object {Object pigment {rgb z} no_shadow}
object {Object
 transform {ShadowTrans}
 scale <1, 0.001, 1>
 pigment {rgbt <0, 0, 0, 0.5>}
Date: 4 May 2021 22:48:01
Message: <60920761$1@news.povray.org>
On 2021-05-04 2:22 PM (-4), Bald Eagle wrote:
> [snip]
> [snip]
This needs to be sky_sphere {pigment {rgbt 1}}
And then render with +UA +FN
Date: 4 May 2021 23:39:16
Message: <60921364$1@news.povray.org>
Very nice. Does this only work with Megapov?
Mike
Date: 4 May 2021 23:44:59
Message: <609214bb$1@news.povray.org>
Thanks! I will give it a try.
I wish POV-Ray supported scaling objects to zero, though I have no idea
how that should be implemented in the code. Small details like this
really bother me, LOL!
Mike
Date: 5 May 2021 06:20:00
Message: <web.609270407599ad521f9dae3025979125@news.povray.org>
Right, I figured he already knew how to do the transparent part, and I was just
working out the fake shadow.   But good for accuracy, completeness, and future
search results.  :)
Date: 6 May 2021 10:38:05
Message: <6093ff4d$1@news.povray.org>
> Mike
Should work correctly using version 3.7 or later.
The author used MegaPOV because, at the time in 2014, the latest version
was 3.6, and that version did not include the features needed. Those are
now standard features.
The only thing that you need to do is to change the #version directive to :
#version 3.7;
or
#version 3.8;
