POV-Ray : Newsgroups : povray.advanced-users : Fake shadows in 32-bit images? Server Time
27 Mar 2026 23:34:44 EDT (-0400)
  Fake shadows in 32-bit images? (Message 4 to 13 of 21)
<<< Previous 3 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Fake shadows in 32-bit images?
Date: 4 May 2021 11:17:07
Message: <XnsAD20AFD4BA02Fseed7@news.povray.org>
in news:6090c6ac$1@news.povray.org Mike Horvath wrote:
> But could it be
> possible to do this all in one step in POV-Ray?
Never tried it, maybe with the user defined camera?
Ingo
Date: 4 May 2021 14:25:00
Message: <web.609191017599ad521f9dae3025979125@news.povray.org>
There might be a way to do this with functions, aoi, slope, or some other
method...
But a quick and dirty cheat like this works:
Take your object(s) and put all of the parts in a merge.
Define a vector location LS for your light source.
Define a second vector location LS2 that is -vnormalize(LS) so that it is
mirrored across the origin.
Define a matrix transform with LS2 as your new y basis vector.
Put your object in the scene with the no_shadow keyword.
Put your object in the scene again, apply the matrix transform, and scale it
really small in the y direction, and apply your semi-transparent texture to it.
#version 3.8;
global_settings {assumed_gamma 1}
 location <0, 5, -9>
 look_at 0
sky_sphere {pigment {rgb 1}}
#declare LS = <5, 15, -10>;
light_source {LS color rgb 1}
#declare E = 0.000001;
#declare LS2 = -vnormalize (LS);
#declare ShadowTrans = transform {
 matrix < 1, 0, 0,
   LS2.x, LS2.y, LS2.z
   0, 0, 1,
   0, 0, 0
#declare Object =
merge {
 cylinder {0, y, 0.05}
 sphere {y, 0.25}
object {Object pigment {rgb z} no_shadow}
object {Object
 transform {ShadowTrans}
 scale <1, 0.001, 1>
 pigment {rgbt <0, 0, 0, 0.5>}
Date: 4 May 2021 22:48:01
Message: <60920761$1@news.povray.org>
On 2021-05-04 2:22 PM (-4), Bald Eagle wrote:
> [snip]
> [snip]
This needs to be sky_sphere {pigment {rgbt 1}}
And then render with +UA +FN
Date: 4 May 2021 23:39:16
Message: <60921364$1@news.povray.org>
On 5/4/2021 5:50 AM, Bald Eagle wrote:
> http://www.imagico.de/pov/icons.php
Very nice. Does this only work with Megapov?
Mike
Date: 4 May 2021 23:44:59
Message: <609214bb$1@news.povray.org>
Thanks! I will give it a try.
I wish POV-Ray supported scaling objects to zero, though I have no idea
how that should be implemented in the code. Small details like this
really bother me, LOL!
Mike
Date: 5 May 2021 06:20:00
Message: <web.609270407599ad521f9dae3025979125@news.povray.org>
Right, I figured he already knew how to do the transparent part, and I was just
working out the fake shadow.   But good for accuracy, completeness, and future
search results.  :)
Date: 6 May 2021 10:38:05
Message: <6093ff4d$1@news.povray.org>
> Mike
Should work correctly using version 3.7 or later.
The author used MegaPOV because, at the time in 2014, the latest version
was 3.6, and that version did not include the features needed. Those are
now standard features.
The only thing that you need to do is to change the #version directive to :
#version 3.7;
or
#version 3.8;
Date: 6 May 2021 10:42:08
Message: <60940040$1@news.povray.org>
>> Mike
> #version 3.7;
> or
> #version 3.8;
Another thing : As that scene use radiosity, you need to replace any
reasonable value. Something in the 0.65..0.8 range.
Date: 6 May 2021 18:55:00
Message: <web.6094444e7599ad52fd796d7fb7ae6630@news.povray.org>
When using radiosity it's useful to include a big sphere and a ground plane,
each with no_image.
I also added some zeros to the y scale of the "shadow" to remove an artifact at
Bald Eagle's nice solution.
Norbert
// +fn +ua
#version 3.7;
#declare RAD = 4;
global_settings {
        assumed_gamma 1
        max_trace_level 5
        noise_generator 2
        #if (RAD > 0)
                radiosity {
                        pretrace_start 0.08
                        pretrace_end 0.04/RAD
                        count 30*RAD
                        nearest_count min (20, RAD)
                        error_bound 2/RAD
                        low_error_factor 0.5
                        recursion_limit 1
                        gray_threshold 0
                        minimum_reuse 0.015
                        brightness 1
                        adc_bailout 0.005
                        normal on
                        media on
        location <0,5,-9>
        look_at <0,0.65,0>
        angle 10
#declare LS = <5,15,-10>;
light_source {LS color rgb <1,0.96,0.9>}
transform {
        matrix <
                1, 0, 0,
                LS2.x, LS2.y, LS2.z
                0, 0, 1,
                0, 0, 0
#declare Object =
union {
        sphere {y, 0.25}
object {Object pigment {rgb 1} no_shadow}
object {
        Object
        scale <1,0.00001,1>
        pigment {rgbt <0,0,0,0.5>}
plane {y, 0 pigment {color rgb 1} no_image}
sphere {
        0, 1000
        pigment {color rgb <0.3,0.4,0.7>}
        no_image
Date: 6 May 2021 19:20:00
Message: <web.6094796d7599ad521f9dae3025979125@news.povray.org>
Thanks Norbert,
I actually had quite a few zeros and removed them because I had an issue with
the "shadow" even showing up.
I am curious about the artifact (was that at the connection of the sphere and
cylinder?  That's why I switched from union {} to merge {}, to minimize that).
I also just deleted a bunch of stuff about the results of your scene, because:
It looks like _total_ crap in my qtpovray render window.
It looks pretty nice in my directory preview window, when I went to attach it -
it has a very light gray background.
It looks great, but different still, when I open the actual file and view the
result, where it has a very dark gray background.
Hmmmm.....
Thanks,
Bill
