hi,
Mike Horvath <mik### [at] gmail com> wrote:
> What I mean is, render a sprite of a 3D object with transparent
> background, but also give the object a semi-transparent shadow.
no idea, but there's related info in the docs:
<https://wiki.povray.org/content/Reference:Image_Map#The_Filter_and_Transmit_Bitmap_Modifiers>
regards, jr.
http://www.imagico.de/pov/icons.php
in news:6090c6ac$1@news.povray.org Mike Horvath wrote:
> But could it be
> possible to do this all in one step in POV-Ray?
Never tried it, maybe with the user defined camera?
Ingo
There might be a way to do this with functions, aoi, slope, or some other
method...
But a quick and dirty cheat like this works:
Take your object(s) and put all of the parts in a merge.
Define a vector location LS for your light source.
Define a second vector location LS2 that is -vnormalize(LS) so that it is
mirrored across the origin.
Define a matrix transform with LS2 as your new y basis vector.
Put your object in the scene with the no_shadow keyword.
Put your object in the scene again, apply the matrix transform, and scale it
really small in the y direction, and apply your semi-transparent texture to it.
#version 3.8;
global_settings {assumed_gamma 1}
location <0, 5, -9>
look_at 0
sky_sphere {pigment {rgb 1}}
#declare LS = <5, 15, -10>;
light_source {LS color rgb 1}
#declare E = 0.000001;
#declare LS2 = -vnormalize (LS);
#declare ShadowTrans = transform {
matrix < 1, 0, 0,
LS2.x, LS2.y, LS2.z
0, 0, 1,
0, 0, 0
#declare Object =
merge {
cylinder {0, y, 0.05}
sphere {y, 0.25}
object {Object pigment {rgb z} no_shadow}
object {Object
transform {ShadowTrans}
scale <1, 0.001, 1>
pigment {rgbt <0, 0, 0, 0.5>}
On 2021-05-04 2:22 PM (-4), Bald Eagle wrote:
> [snip]
> [snip]
This needs to be sky_sphere {pigment {rgbt 1}}
And then render with +UA +FN
Very nice. Does this only work with Megapov?
Mike
Thanks! I will give it a try.
I wish POV-Ray supported scaling objects to zero, though I have no idea
how that should be implemented in the code. Small details like this
really bother me, LOL!
Mike
Right, I figured he already knew how to do the transparent part, and I was just
working out the fake shadow. But good for accuracy, completeness, and future
search results. :)
> Mike
Should work correctly using version 3.7 or later.
The author used MegaPOV because, at the time in 2014, the latest version
was 3.6, and that version did not include the features needed. Those are
now standard features.
The only thing that you need to do is to change the #version directive to :
#version 3.7;
or
#version 3.8;
>> Mike
> #version 3.7;
> or
> #version 3.8;
Another thing : As that scene use radiosity, you need to replace any
reasonable value. Something in the 0.65..0.8 range.
