POV-Ray : Newsgroups : povray.advanced-users : Need a script to randomly scatter objects vertically Server Time
10 Nov 2025 10:56:42 EST (-0500)
  Need a script to randomly scatter objects vertically (Message 1 to 10 of 30)
Subject: Need a script to randomly scatter objects vertically
Date: 20 Apr 2021 00:02:49
Message: <607e5269$1@news.povray.org>
I have some mesh based terrain model. I would like to drop trees
vertically on to it based on some rules:
1. the trees should not overlap with each other
2. the tree density should depend on the (configurable) slope of the ground
3. trees are circular so the only important data is the radius of the tree
4. the script needs to output the generated coordinates to a text file
Can someone help me write such a script? Thanks!
Michael
Subject: Re: Need a script to randomly scatter objects vertically
Date: 20 Apr 2021 00:05:10
Message: <607e52f6$1@news.povray.org>
> Michael
Oops, also this:
5. there are multiple types of trees with varying probability of occuring
Date: 20 Apr 2021 02:10:04
Message: <607e703c@news.povray.org>
Op 20/04/2021 om 06:05 schreef Mike Horvath:
>> ground
>> tree
>> Michael
> Oops, also this:
I have such a script!
I shall send you the details later today.
Date: 20 Apr 2021 02:47:00
Message: <607e78e4$1@news.povray.org>
Op 20/04/2021 om 08:10 schreef Thomas de Groot:
>>> ground
>>> tree
>>> Michael
>> Oops, also this:
That "later today" was sooner than expected.
In the attached zip file are three POV-Ray codes:
1) the original code by Kirk Andrews which you can use as reference
(KA_LandscapeTutorial.pov)
2) my own code based on (1) where I have added and/or changed a couple
of things. This code I use currently for any landscape, whether they are
trees or rocks or whatever (My objects poser.pov)
3) My own code for trees, with probability added for different types of
trees (My tree poser.pov)
They do not answer /all/ your conditions maybe, but come very close
indeed. I think you can improve where necessary :-)
If in doubt, please yell.
Date: 20 Apr 2021 02:48:02
Message: <607e7922$1@news.povray.org>
Oops! no attachment!
Download 'temp.zip' (11 KB)
Date: 20 Apr 2021 03:24:57
Message: <607e81c9$1@news.povray.org>
Awesome, thanks!
A couple of questions:
1. I cannot render either of the scripts you created. Seems the floor
and landscape objects are missing. What format do they take?
2. What does the proximity function do? I don't know what a proximity
function is.
Mike
Date: 20 Apr 2021 04:29:38
Message: <607e90f2$1@news.povray.org>
Op 20-4-2021 om 09:24 schreef Mike Horvath:
> Awesome, thanks!
> function is.
> Mike
Good questions.
"floor" is a placeholder name. When you define your target, i.e. the
mesh or the height_field on which you want to place your trees and which
you have already declared before, you fill in their name instead of "floor":
#declare my_HF = height_field {etc etc}
#declare Target  = object {my_HF}
The Proximity Function as defined by Kirk Andrews, and as I understand
it, is an averaged  pigment which uses the target object repeatedly as
an object pattern. It can then be used for instance to exclude trees on
sharp edges of the landscape or scale trees vertically following certain
rules (there are example uses in some of the commented out lines of the
code; I switch them on or off according to purpose or need).
I confess that I do not always exactly understand how things work in the
code, but as long as it does what I want...
If you want, I can design a little demo scene to make things more
visual. Maybe I even have one somewhere... I need to delve in my dungeons.
Date: 20 Apr 2021 13:14:22
Message: <607f0bee$1@news.povray.org>
The code is missing the `IsObjectVisible` macro too. Do you have that in
your records somewhere? Thanks.
Mike
Date: 21 Apr 2021 02:22:58
Message: <607fc4c2@news.povray.org>
Op 20/04/2021 om 19:14 schreef Mike Horvath:
Aaah... Sorry, over time those things become more complex and added to.
What is missing is Gilles Tran's Visibility Test indeed (attached).
Very useful when you do not want to drop objects /outside/ of the camera
view.
I also attached a little test scene to show how it works and how you
calibrate it for your scene.
Download 'gt_visibilitytest.mcr.txt' (2 KB) Download 'visibilitytest.pov.txt' (5 KB)
Date: 21 Apr 2021 14:10:00
Message: <web.608069edc2ce34cbfd796d7fb7ae6630@news.povray.org>
> Michael
I know that Thomas made some very nice macros public in this thread, but I want
to point to an old macro made by JRG (Jonathan Rafael Ghiglia) back in 2001 -
his "clutter macro". Since I wasn't able to find the link on this server I
include the macro here.
With some modifications every point of your list is doable - perhaps I'm able to
do it in the next days. Especially interesting is your first point - but I
haven't looked into Thomas macro regarding it - perhaps this problem is already
solved...
Furthermore, if you want to use a very large number of trees, you should use
only visible coordinates. Back in 2005 I published a method
(http://news.povray.org/povray.binaries.scene-files/message/%3C432414bf%40news.povray.org%3E/#%3C432414bf%40news.povray
.org%3E
for macro -
http://news.povray.org/povray.binaries.images/thread/%3Cdg0ifb%242oi%241%40chho.imagico.de%3E/
for the thread).
Stay healthy
Norbert
Download 'clutter.zip' (73 KB)
