POV-Ray : Newsgroups : povray.advanced-users : Extract 2D screen coordinates from 3D Server Time
29 Jun 2026 04:59:52 EDT (-0400)
  Extract 2D screen coordinates from 3D (Message 1 to 9 of 9)
Subject: Extract 2D screen coordinates from 3D
Date: 18 Jan 2020 12:16:43
Message: <5e233d7b@news.povray.org>
Hello,
My goal is to place text on an image at a certain position known by its
3d coordinates. With classic "screen.inc" this code do the job :
#include "screen.inc" // standard inc file
Set_Camera(<25,15,-33>, <2,2,0>, 70) // set location, look_at and angle
Set_Camera_Aspect(4,3) // set width in relation to height
Set_Camera_Sky(<0,1,0.3>) // set the sky vector
#declare MyTextObject = text {...}
Screen_Object ( MyTextObject, <0.00, 0.50>, <0.01,0.01>, true, 0.01 )
I found the "Updated screen.inc" in newsgroup.
<http://news.povray.org/povray.text.scene-files/attachment/%3C5b889a96%40news.povray.org%3E/screen.inc.txt>
In this file there's the macro : *Get_Screen_XY(Loc)*. This macro return
<x,y> coordinates in the image from <x,y,z> coordinates of 3d scene.
That's exactly what I need.
I update my code to :
#include "screen2.inc" // updated inc file from newsgroup
#declare Point3D = <a,b,c>;
// here, screenXY contain the right "image coordinates"
// like <400,300> for center of an image 800x600
#declare screenXY = Get_Screen_XY(Point3D);
// because Screen_Object use <u,v> from 0..1, i calc
#declare screenU = screenXY.x/image_width;
#declare screenV = screenXY.y/image_height;
// which produces <0.50, 0.50> always for the center
// and now, display text at this pos
Screen_Object ( MyTextObject, <screenU, screenV>, <0.01,0.01>, true, 0.01 )
and, uh... nothing shows up !
where's my mistake? Is there a bug in the macro or in my code ?
if you have any ideas...
thanks
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Extract 2D screen coordinates from 3D
Date: 18 Jan 2020 13:50:01
Message: <web.5e2352c8c5d107b38c662f470@news.povray.org>
hi,
kurtz le pirate <kur### [at] gmailcom> wrote:
> Hello,
in both files, the 2nd arg (Position) is a 3-vector.  maybe that?
> thanks
> Kurtz le pirate
regards, jr.
Date: 18 Jan 2020 17:05:01
Message: <web.5e237f71c5d107b39da690110@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > thanks
> > Kurtz le pirate
> regards, jr.
I have done it, it's not easy. There are two ways; data readout at same screen
xy always, no mater where you're looking,
2:
labels on objects, no matter where you're looking. here's lunar label from the
planetarium --- stuff like this requires writing some matrix functions,
#local vl = vlength(Lunar_v-campos)/88;
#local camup = <cameramatrix[4],cameramatrix[5],cameramatrix[6]>;
#local pnt = -camup*(IDS(EarthRad * 0.2724*1.05)+vl*FontSize)+Lunar_v;
#local eye = vnormalize(pnt-campos);
object {
    text {
      ttf "Arial.ttf" "Moon" 1 0
      texture {  pigment { rgb 1 }  finish { ambient 1 diffuse 0 } }
    translate x*(strlen("Moon")*-0.28)
    #if (vlength(campos) < 10000) scale <vl*FontSize,vl*FontSize,vl*FontSize>
    #else scale
<vl*FontSize,vl*FontSize,vl*FontSize+0.009*(vlength(campos)/150000)>
    #end// adjust text if blurry or breaking up
    popmatrix(vcross(camup,eye),vcross(eye,vcross(camup,eye)),eye,pnt)
    no_shadow
#macro popmatrix(A, B, C,T)
   transform {
      matrix <A.x, A.y, A.z,
              B.x, B.y, B.z,
              C.x, C.y, C.z, T.x, T.y, T.z>
huge distances was a problem, stick around home and u should be fine
text.pov is a heads up display for the lego plane. ... hmm where to put it.
Date: 18 Jan 2020 20:25:00
Message: <web.5e23af6ac5d107b34eec112d0@news.povray.org>
> thanks
Well, I mean it looks like it should work.
I don't know what version you're using, and I can never figure out which one I'm
using either.   There's never any version number, date, revision history, etc.
I'd say just check your light source, texture, positions of everything, etc.
Then output the number to the debug stream.
If that looks ok, then make a super simple scene and see if that works.
Compare the old and new screen.inc results.
Also, do you use the Update_Camera () macro before you render?
This is sort of related, and just including this here in case you're interested.
http://news.povray.org/povray.binaries.images/thread/%3C5baddad1%40news.povray.org%3E/?mtop=424795
Date: 18 Jan 2020 21:00:00
Message: <web.5e23b7cfc5d107b39da690110@news.povray.org>
i see trouble with that original code when I was first out ...
if you grok 3D math its ALWAYS normalize a vcross() that's the crossProduct.
even 2 normals with a length of 1 != length of 1
vlen(crossprod(normalize(3,5,8),normalize(7,4,6))) = 0.4469
Date: 16 Feb 2020 22:00:17
Message: <5e4a01c1$1@news.povray.org>
If it helps, the latest version of this script is on GitHub.
https://github.com/mjhorvath/POVRay-Updated-Screen-Inc
See if that solves your problem and let me know.
Michael
Date: 22 Feb 2020 03:55:21
Message: <5e50ec79@news.povray.org>
Michael, thanks for your work.
I put the test image in p.b.i. and yes it's OK
Code used in my scene :
#include "screen_mjh.inc"
Set_Camera_Sky(y)
// set the type of projection (orthographic or perspective)
Set_Camera_Orthographic(false)
Set_Camera_Aspect(image_width,image_height)
// set the location, look_at, and angle
Set_Camera(CamLoc, CamLookAt, CamAngle)
#declare pt1 = <6,4,6>;
drawPoint(pt1, rPoint, Red, true)
#declare ScreenXY1 = Get_Screen_XY(pt1);
#declare Text1 = text { ttf "crystal.ttf" "Pt1" 0.01 <0, 0, 0> pigment {
color Red } scale 0.03 }
Screen_Object(Text1, <ScreenXY1.x/image_width,
1-(ScreenXY1.y/image_height)> , 0.01, false, 1)
#declare pt2 = <-3,2,-5>;
drawPoint(pt2, rPoint, Cyan, true)
#declare ScreenXY2 = Get_Screen_XY(pt2);
#declare Text2 = text { ttf "crystal.ttf" "Pt2" 0.01 <0, 0, 0> pigment {
color Cyan } scale 0.03 }
Screen_Object(Text2, <ScreenXY2.x/image_width,
1-(ScreenXY2.y/image_height)> , 0.01, false, 1)
#declare pt3 = <4,6,-1>;
drawPoint(pt3, rPoint, Orange, true)
#declare ScreenXY3 = Get_Screen_XY(pt3);
#declare Text3 = text { ttf "crystal.ttf" "Pt3" 0.01 <0, 0, 0> pigment {
color Orange } scale 0.03 }
Screen_Object(Text3, <ScreenXY3.x/image_width,
1-(ScreenXY3.y/image_height)> , 0.01, false, 1)
However, some very small adjustments need to be made as you can see.
Get_Screen_XY() return coordinates in "image unit" and they must be
reduced to [0..1] and vertical position must also be changed with
1-value. Resulting in :
   <ScreenXY/image_width, 1-(ScreenXY.y/image_height)>
for the *location* parameter of the *Screen_Object* macro.
Great !!
Kurtz le pirate
Date: 23 Feb 2020 08:03:23
Message: <5e52781b$1@news.povray.org>
> Great !!
I don't quite understand your response. Are you satisfied with how the
tool works, or do you think there need to be changes?
Michael
Date: 29 Feb 2020 06:55:00
Message: <5e5a5114$1@news.povray.org>
Sorry Michael if I wasn't clear.
Tool are perfect !
Kurtz le pirate
