POV-Ray : Newsgroups : povray.advanced-users : Lumens in LightSysIV? Server Time
14 Mar 2026 16:48:36 EDT (-0400)
  Lumens in LightSysIV? (Message 1 to 4 of 4)
Subject: Lumens in LightSysIV?
Date: 11 Jun 2019 21:32:15
Message: <5d00561f@news.povray.org>
What is the correct method of calculating and specifying Lumens in
LightSysIV?
     Light_Color(light_temp, light_lumens)
Do I need to know the distance and diameter of the Sun beforehand? What
about fade_power and fade_distance?
Thanks.
Michael
Subject: Re: Lumens in LightSysIV?
Date: 12 Jun 2019 13:25:46
Message: <5d01359a$1@news.povray.org>
> LightSysIV?
> Thanks.
> Michael
For the Sun, don't bother with light fading : Use a light with the
parallel option and you are good. Unless your scene scale is
interplanetary, the fading over the extent of your scene is totally
negligible.
For the extent of the Sun when using an area_light, make it's diameter
about 0.01 of the distance. Not exact, but close enough.
For more normal lights, the fade_power must be 2. No other value is
realistic.
For fade_distance : Make it small. For an area_light, it should be about
the width of the light. For point light, a value of about 0.1 is correct.
Date: 12 Jun 2019 22:50:48
Message: <5d01ba08$1@news.povray.org>
> negligible.
> realistic.
Thanks. What about Lumens? Should Lumens always equal 1 for parallel
lights mimicking the Sun?
Michael
Date: 13 Jun 2019 02:48:42
Message: <5d01f1ca$1@news.povray.org>
>> negligible.
>> realistic.
>> about the width of the light. For point light, a value of about 0.1 is
>> correct.
With LightsysIV, I never bother with lumens. I use CIE which is part of
the package:
#include "CIE.inc"
#declare SunCol  = Blackbody(6500)*Intensity; //Sun temperature:
2800=red; 7500=blue white.
For position and diameter of the Sun, I use:
#declare SunPos  = vrotate(<0, 0, -2>*10e5, <Sun_alt, Sun_azm, 0.0>);
#declare SunDia  = vlength(SunPos)*2/215;  //apparent diameter of the Sun
The later is a formula by Cousin Ricky (somewhen in 2007 I think).
