POV-Ray : Newsgroups : povray.advanced-users : Get Euler angles from unit vector? Server Time
25 Mar 2026 01:08:11 EDT (-0400)
  Get Euler angles from unit vector? (Message 1 to 10 of 13)
Subject: Get Euler angles from unit vector?
Date: 22 Sep 2018 07:49:25
Message: <5ba62c45$1@news.povray.org>
Is it possible to extract the Euler rotation amounts from a unit vector?
Is there a command that does this? Thanks.
Mike
Subject: Re: Get Euler angles from unit vector?
Date: 22 Sep 2018 08:32:50
Message: <5ba63672$1@news.povray.org>
Am 22.09.2018 um 13:49 schrieb Mike Horvath:
A unit vector by itself is not enough to fully specify a free rotation
in 3D space; you need two vectors for that.
Most notably, a single unit vector representation would allow for
arbitrary rotations around the direction of that vector.
Date: 22 Sep 2018 10:25:46
Message: <5ba650ea$1@news.povray.org>
I think he wanted something along Reorient_Trans(Axis1, Axis2) (from
transform.inc) with Axis1 = x and Axis2 his unit vector.
But expressing the transformation as the Euler angles.
Yet, as spotted, a second vector (perpendicular) is needed for complete
non-ambiguous computation.
x,y --> v1,v2
Date: 22 Sep 2018 11:09:08
Message: <5ba65b14$1@news.povray.org>
I found some old code written in Lua. Just need to adapt it to POV-Ray.
Mike
-- Returns an array containing the vector's Euler angles, relative to
the Z-axis.
-- To reproduce the original vector, rotate a point on the Z-axis by
these angles.
function vanglesXY(tVec2)
	local fSgnX, fSgnY, tPrjB1 = 1, 1, vnormalize({tVec2[1], 0, tVec2[3],})
	if (tPrjB1[1] ~= 0) then
		fSgnX = tPrjB1[1]/abs(tPrjB1[1]) * -1
	end
	tPrjB1[3] = max(min(tPrjB1[3],1),-1)
	local fAngY = acos(tPrjB1[3]) * fSgnX
	local tPrjB2 = vnormalize(vrotate(tVec2, {0, fAngY, 0,}))
	if (tPrjB2[2] ~= 0) then
		fSgnY = tPrjB2[2]/abs(tPrjB2[2])
	end
	tPrjB2[3] = max(min(tPrjB2[3],1),-1)
	local fAngX = acos(tPrjB2[3]) * fSgnY
	return {fAngX * -1, fAngY * -1, 0,}
end
Date: 22 Sep 2018 15:40:00
Message: <web.5ba69a61809fadada47873e10@news.povray.org>
Methinks you're working on a way to re-structure a transform{matrix...} back
into rotation angles ;-)
[possibly off-topic]
Reading the Wikipedia entry about 'Euler angles' (probably for the first time!),
particularly the 'simplified' form, it reminded me of some test animations I did
years ago, of an object rotating in free space. Like, a chunk of rock slowly
rotating way out in the cosmos.
At first, I thought the object needed THREE separate rotations to look right.
That seemed logical-- if only from the standpoint of an airplane's 'yaw, pitch
and roll.' But the result looked odd-- like there was an extra invisible force
acting on it (and/or that the object was ending up in the same orientation it
started in, very quickly.) Just from experimenting, I found that restricting the
rotations to TWO axes *looked* to be much more natural, and that the third-axis
rotation was... redundant-- which seems to agree with the notion of 'simplified'
Euler angles, where the needed rotations can actually be around two axes rather
than three, to get any orientation (if I'm reading the definition properly, that
is!)
Not that this is of any help to you :-(
Date: 27 Sep 2018 19:40:38
Message: <5bad6a76$1@news.povray.org>
It would be nice to be able to set vector components like this:
     #local tPrjB1.z = max(min(tPrjB1.z,1),-1);
Are there any plans to do this in the future?
Mike
Date: 27 Sep 2018 19:47:04
Message: <5bad6bf8$1@news.povray.org>
Am 28.09.2018 um 01:40 schrieb Mike Horvath:
Thought about it, but it would mean creeping into the dirtiest corners
of the parser.
Not off the agenda, but not right around the corner either.
Date: 27 Sep 2018 20:32:57
Message: <5bad76b9$1@news.povray.org>
Yes. Is there a somewhat simple method of doing this so that I don't
have to write separate code for each possible matrix convention? (There
are six possibilities, even when not taking into consideration that the
handedness might also vary.)
Mike
Date: 27 Sep 2018 21:27:38
Message: <5bad838a$1@news.povray.org>
Two important questions I have (that may not be explained in the docs),
is how to convert a 3x3 rotation matrix to POV-Ray syntax, and how to
determine the inverse matrix?
Mike
Date: 28 Sep 2018 00:27:21
Message: <5badada9$1@news.povray.org>
Am 28.09.2018 um 03:27 schrieb Mike Horvath:
given a matrix
     / a  b  c \
    (  d  e  f  )
     \ g  h  i /
you have to specify either
    matrix < a, b, c,
             d, e, f,
             g, h, i,
             0, 0, 0 >
or
    matrix < a, d, g,
             b, e, h,
             c, f, i,
             0, 0, 0 >
The order depends on whether the original matrix is specified in
"mathematical" or "computer graphics" style - they're mirrored along the
diagonal. Can't remember which one POV-Ray uses.
Determining the inverse /transformation/ is simple:
    #declare Foo = transform { matrix < ... > }
    #declare FooInv = transform { Foo inverse }
Actually getting at the corresponding matrix is possible by applying the
inverted transformation to the axis vectors.
