I have an area light centered at the origin. I also have a partially
transparent plane passing through the origin. However, the light is not
illuminating this plane. How do I fix this? Thanks!
Mike
light_source
0
1
area_light
x * 1/100, y * 1/100
5, 5
adaptive 1
jitter
circular
orient
#declare Orrery_Ecliptic_Pattern = union
#local Orrery_Line_Thickness = 1/200;
#local Orrery_Ecliptic_Steps = 30;
#for (i, 1, Orrery_Ecliptic_Steps)
difference
cylinder {-y * 1, +y * 1, i + Orrery_Line_Thickness}
cylinder {-y * 2, +y * 2, i - Orrery_Line_Thickness}
#local Orrery_Ecliptic_Steps = 4;
#local Orrery_Ecliptic_Angle = 360/Orrery_Ecliptic_Steps;
cylinder
0, +x * 40, Orrery_Line_Thickness
rotate +y * i * Orrery_Ecliptic_Angle
plane
y, 0
pigment
object
color srgbt <1,1,1,3/4>
color srgbt <1,1,1,0/4>
hollow
Am 17.09.2018 um 06:20 schrieb Mike Horvath:
Have you tried area_illumination? Can't guarantee that it will help in
this very specific case, but it's worth a shot.
Perfect! Thanks!
Mike
