POV-Ray : Newsgroups : povray.advanced-users : map_type 1 Server Time
13 May 2025 14:49:52 EDT (-0400)
  map_type 1 (Message 1 to 8 of 8)
Subject: map_type 1
Date: 23 Jul 2018 20:51:44
Message: <5b567820$1@news.povray.org>
If I apply an image_map to an ellipsoid using map_type 1, will the
effect be like what is pictured? (See attachment.)
Mike
Download 'cone_of_latitude_mono_uvmap.png' (38 KB)
Preview of image 'cone_of_latitude_mono_uvmap.png'
Subject: Re: map_type 1
Date: 24 Jul 2018 03:54:32
Message: <5b56db38$1@news.povray.org>
Am 24.07.2018 um 02:51 schrieb Mike Horvath:
Yes.
Date: 24 Jul 2018 04:30:16
Message: <5b56e398$1@news.povray.org>
> Yes.
Next obvious question: Is there a way to tweak the map and make it
conform to an ellipsoid? E.g. perpendicular to the ellipsoid's tangents?
Mike
Download 'cone_of_latitude_mono_uvmap_b.png' (52 KB)
Preview of image 'cone_of_latitude_mono_uvmap_b.png'
Date: 24 Jul 2018 04:55:35
Message: <5b56e987$1@news.povray.org>
Am 24.07.2018 um 10:30 schrieb Mike Horvath:
>> Yes.
You can scale the pigment. If you scale it vertically by the quotient of
the ellipsoid's minor and major diameters d/D (or if you create the
object as a pigmented sphere and then turn it into an ellipsoid by
scaling), you'll get the same effect as projecting from the sphere to
the ellipsoid vertically.
If you scale it vertically by a factor somewhere between 1 and d/D,
you'll get other projections from sphere to ellipsoid, though I'm not
sure if any one of them happens to match the projection you've depicted.
If all else fails, you can roll your own projection by using the new
`user_defined` pattern, and employ functions that fetch their values
from suitable locations in the original image map (via the pattern
function mechanism).
Date: 24 Jul 2018 05:23:17
Message: <5b56f005$1@news.povray.org>
I screwed up the last drawing unfortunately. I will post another later.
I will check the docs as that looks interesting.
Mike
Date: 24 Jul 2018 05:45:52
Message: <5b56f550$1@news.povray.org>
Am 24.07.2018 um 11:23 schrieb Mike Horvath:
A propos:
https://youtu.be/xdIjYBtnvZU
Maybe that geometric property might be of use to you.
Date: 24 Jul 2018 05:50:20
Message: <5b56f65c@news.povray.org>
Here are all three images again.
> A propos:
I will watch this in the morning. Thanks!
Mike
Download 'cone_of_latitude_mono_uvmap_a.png' (45 KB) Download 'cone_of_latitude_mono_uvmap_b.png' (52 KB) Download 'cone_of_latitude_mono_uvmap_c.png' (40 KB)
Preview of image 'cone_of_latitude_mono_uvmap_a.png'
Preview of image 'cone_of_latitude_mono_uvmap_c.png'
Date: 24 Jul 2018 17:49:21
Message: <5b579ee1$1@news.povray.org>
So, I can alter the original image map (the bitmap featuring continents,
oceans, etc.) in this manner?
Mike
