POV-Ray : Newsgroups : povray.advanced-users : looks_like (again) Server Time
26 Sep 2024 19:31:12 EDT (-0400)
  looks_like (again) (Message 1 to 6 of 6)
Subject: looks_like (again)
Date: 10 Mar 2018 17:36:27
Message: <5aa45deb$1@news.povray.org>
I have the following settings. However, I can't get the sun_object to
appear visible. What am I doing wrong? Thanks.
Mike
// Universe
#declare feet_units			= 20;							// LDU per foot
#declare mile_units			= 5280 * feet_units;
#declare plate_size			=   32 * feet_units;
#declare earth_fudge		= 1/10;							// precision issues in POV-Ray
necessitate this
#declare earth_radius		= 3959 * mile_units * earth_fudge;
#declare earth_circum		= floor(2 * pi * earth_radius / plate_size) *
plate_size;
#declare earth_radius		= earth_circum/2/pi;
#declare longitude_div		= earth_circum/plate_size;
#declare sun_fudge			= 1/100000;
#declare sun_radius			=   432288 * mile_units * sun_fudge;
#declare sun_distance		= 92960000 * mile_units * sun_fudge;
#declare cloud_min_radius	=  1 * mile_units * earth_fudge;
#declare cloud_max_radius	=  2 * mile_units * earth_fudge;
#declare atmos_max_radius	= 10 * mile_units * earth_fudge;
// Lights
#include "sunpos.inc"
#declare light_source_location	= <1,-1,1> * sun_distance * SunPos(2018,
3, 6, 9, 15, -75, 43.2087409, -71.7123404);	// Year, Month, Day, Time
(24hr), Lstm, LAT, LONG
#declare sun_object = sphere
	<0,0,0>, sun_radius
	pigment {color rgb 1}
	finish {emission 1}
light_source
	rgb 1
	looks_like
		sun_object
	parallel
	point_at <0,0,0>
Subject: Re: looks_like (again)
Date: 10 Mar 2018 19:00:01
Message: <web.5aa4709df45d15ce9c5d6c810@news.povray.org>
Well, I think it's a problem with distance.
If the location is divided by 10 billion, or multiplied by 1e-10 (one ten
billionth) it will show the sun when a camera at <0,0,0> is set to look_at the
sun location.
light_source
 light_source_location*1e-10
 rgb 1
 looks_like
  sun_object
 parallel
 point_at <0,0,0>
 location <0,0,0>
 look_at light_source_location
Date: 10 Mar 2018 19:29:48
Message: <5aa4787c$1@news.povray.org>
> sun location.
> light_source
>   rgb 1
>   looks_like
>    sun_object
>   parallel
>   point_at <0,0,0>
> camera {
>   location <0,0,0>
I was able to work it out. Thanks for your help!
Mike
Date: 10 Mar 2018 19:29:58
Message: <5aa47886$1@news.povray.org>
Disregard.
Date: 10 Mar 2018 19:33:44
Message: <5aa47968$1@news.povray.org>
> sun location.
> light_source
>   rgb 1
>   looks_like
>    sun_object
>   parallel
>   point_at <0,0,0>
> camera {
>   location <0,0,0>
This happen when the dimensions range become to large. You get hit with
precision loss.
Try to keep your range of scales to less than 1e6 if at all possible.
If your smallest object is about 1 unit in size, the farthest object
should be located at less than 1000000 unit away.
If dividing the Sun's location by 1e10 makes the sun_object visible,
it's obvious that your scale range is WAY to large !
When using a parallel light, you can always safely place it much closer,
if you also take care to scale it down proportionally.
Date: 13 Mar 2018 00:07:55
Message: <5aa74e9b$1@news.povray.org>
>> look_at the
>> sun location.
>> light_source
>>   rgb 1
>>   looks_like
>>    sun_object
>>   parallel
>>   point_at <0,0,0>
>> camera {
>>   location <0,0,0>
> Mike
The problem was that "sunpos.inc" was returning values that were already
scaled to a large degree. When I vnormalized these values things started
working correctly.
Mike
