POV-Ray : Newsgroups : povray.advanced-users : sunpos.inc Server Time
29 Jun 2026 06:42:56 EDT (-0400)
  sunpos.inc (Message 1 to 6 of 6)
Subject: sunpos.inc
Date: 6 Mar 2018 09:29:25
Message: <5a9ea5c5$1@news.povray.org>
How do I figure out the Lstm value for this macro?
// Lstm:  Meridian of your local timezone (+1 hour =  +15 deg)
//        in degrees (east = positive, west = negative)
I am in UTC−05:00.
Thanks!
Mike
Subject: Re: sunpos.inc
Date: 6 Mar 2018 11:06:42
Message: <5a9ebc92$1@news.povray.org>
hi,
> I am in UTC−05:00.> Thanks!
> Mike
being naive, I'd use 5 * 15, and subtract if in the US of A.
regards, jr.
Date: 6 Mar 2018 13:00:01
Message: <web.5a9ed70d9d3ded52c437ac910@news.povray.org>
Here's what I used for my watch/compass scene
#declare Feet = 12;
#declare Miles = 5280*Feet;
// radius of Earth
#declare EarthRad = 3959*Miles;
#declare SunRad = 432288*Miles;
#declare SunDist = 92960000*Miles;
#declare SunCorrection = SunDist/1000000000; // correct distance to sun defined
in sunpos.inc
// North +z
// South -z
// East +x
// West -x
#declare Year = 2016;
#declare Month = 7;
#declare Day = 11;
#declare Hour = int(clock);  // 24-hour clock
#declare Minute = (clock-int(clock))*60;
// (UTC-05:00) Eastern Time (US & Canada)
// (+1 hour =  +15 deg)
#declare Lstm = 15*(-5);
// Hopkinton / Contoocook, NH
#declare LAT = 43.2087409;
#declare LONG = -71.7123404;
light_source {SunPos(Year, Month, Day, Hour, Minute, Lstm, LAT,
LONG)*SunCorrection rgb <1, 1, 0> parallel point_at <0, 0, 0>} // added
'parallel' and 'point_at <0, 0, 0>'
Date: 6 Mar 2018 17:39:56
Message: <5a9f18bc$1@news.povray.org>
> #declare Feet = 12;
> // radius of Earth
> in sunpos.inc
> // North +z
> // South -z
> // East +x
> // West -x
> #declare Month = 7;
> #declare Day = 11;
Very good, thanks!
Mike
Date: 6 Mar 2018 17:44:37
Message: <5a9f19d5$1@news.povray.org>
Have you calculated how big the sun should appear in the sky? I'm also
hesitant to use an area light, because my scene is already slow.
Mike
Date: 6 Mar 2018 21:30:59
Message: <5a9f4ee3@news.povray.org>
> Mike
Use about 1% of the distance that you use.
So, if the "Sun" is located 10000 units away, it should be 100 units in
diameter.
As this is relatively small relative to the distance and general scale
of the scene, start by using adaptive 0. This greatly improve the speed
when using area_light.
ONLY increase that if you get artefacts that you can't hide.
In some cases, you can elliminate some artefacts just by rotating the
light around the axis from <0,0,0> and the light's location.
Easy when the light is located on an axis and the array is set
perpendicular to it : Rotate around that axis, then rotate to the
desired location.
light_source{<0,0,-10000> rgb 1 area_light x,y 33 33 circular adaptive 0
rotate 15*z}
