POV-Ray : Newsgroups : povray.advanced-users : Camera scaling and focal_blur? Server Time
4 Nov 2026 00:02:54 EST (-0500)
  Camera scaling and focal_blur? (Message 1 to 28 of 28)
Subject: Camera scaling and focal_blur?
Date: 10 Feb 2018 19:46:41
Message: <5a7f9271$1@news.povray.org>
What effect does scaling a camera have on focal_blur?
I have two cameras, and they should both produce the same result. But
they don't.
// focal blur camera
   location  <0,0,-5>
   look_at   <0,0,0>
   up y
   aperture 1.0           // [0...N] larger is narrower depth of field
(blurrier)
   blur_samples 10        // number of rays per pixel for sampling
   focal_point <0,0,0>    // point that is in focus <X,Y,Z>
   confidence 0.95        // [0...<1] when to move on while sampling
(smaller is less accurate)
   variance 1/200         // [0...1] how precise to calculate (smaller
is more accurate)
   scale 2
   location  <0,0,-10>
   look_at   <0,0,0>
   up y
(blurrier)
is more accurate)
Subject: Re: Camera scaling and focal_blur?
Date: 10 Feb 2018 21:35:00
Message: <5a7fabd4$1@news.povray.org>
Also, what if I scale the camera before I add the focal_blur? I am
having trouble with a scene in which the center never appears in focus
like I want it to.
> they don't.
> camera {
>    location  <0,0,-5>
>    look_at   <0,0,0>
>    up y
> (blurrier)
> is more accurate)
>    scale 2
> camera {
>    location  <0,0,-10>
>    look_at   <0,0,0>
>    up y
> (blurrier)
> is more accurate)
Date: 10 Feb 2018 22:35:54
Message: <5a7fba1a$1@news.povray.org>
I've been reading this
https://en.wikipedia.org/wiki/Miniature_faking
and have been wondering how to achieve the effect in POV-Ray. Obviously,
there is no true scale in POV-Ray, so there's no need to "fake" the
effect. But I don't know how to construct the correct camera.
Any ideas?
Mike
Date: 10 Feb 2018 23:32:25
Message: <5a7fc759$1@news.povray.org>
I still don't understand exactly what's happening, but I removed the
scaling and just increased the numbers directly, and things are working
out much better.
Mike
Date: 11 Feb 2018 08:06:52
Message: <5a803fec$1@news.povray.org>
> Any ideas?
See:
http://news.povray.org/povray.binaries.images/thread/%3C57e14051%241%40news.povray.org%3E/
for a technique using a not yet adopted parser change which allowed
image_maps to be used directly in density {} blocks.
Mention it because though our documentation
http://wiki.povray.org/content/Reference:User_Defined_Pattern
doesn't yet disclose it, the new-ish 3.7.1/3.8 pigment { user_defined {
} } capability was implemented by Christoph in a way so it works for
density blocks too. Of course only the R,G,B functions do anything where
used with density {}.
This means it should be possible to implement the tilt shift technique
in the first reference by building up functions which grab the r,g,b
channels via #declare Fn... = function { pigment { image_map {...} } }
and using those functions in two density { user_defined { } } blocks in
a density_map. It's a more awkward means than using the image_maps
directly in the density blocks, but it should work.
The technique uses media blending between two densities. One blurred via
turbulence and one not.
Bill P.
Date: 11 Feb 2018 10:14:41
Message: <5a805de1$1@news.povray.org>
Am 11.02.2018 um 04:36 schrieb Mike Horvath:
> Any ideas?
Yep: Crank up the focal blur `aperture` setting like mad.
Date: 11 Feb 2018 19:00:00
Message: <web.5a80d8243abb6b9ea47873e10@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> ..for a technique using a not yet adopted parser change which allowed
That is *definitely* an interesting and useful idea (as is your current
workaround.) Any idea if this image_map thing is going to be included in a newer
v3.8.x alpha or beta?
Date: 11 Feb 2018 22:08:11
Message: <5a81051b$1@news.povray.org>
>> Any ideas?
The problems I was having involved scaling/transforming the camera. Once
I stopped doing that, things started working properly. I don't really
understand why, but I will post some test scenes in the other forum.
Mike
Date: 11 Feb 2018 22:40:00
Message: <web.5a810c7d3abb6b9ea47873e10@news.povray.org>
> out much better.
I've never tried *scaling* a camera before, but it's an interesting idea.
Using your 'scale 2' camera, what it looks like is that the focal_blur's
focal_point of <0,0,0> (the focal 'plane')is actually shifting to <0,0,-5>. In
other words, it's keeping the same original 5-unit distance from the CAMERA--
not scaling to 2*5 = 10-units. That's what I see from a simple test, anyway.
Date: 11 Feb 2018 22:46:22
Message: <5a810e0e@news.povray.org>
>> out much better.
I posted my scene in p.t.s-f. Could you take a look at that?
Thanks.
Mike
Date: 11 Feb 2018 23:15:00
Message: <web.5a8113d93abb6b9ea47873e10@news.povray.org>
.... and changing the focal_point to <0,0,5> does indeed bring the focal plane
back to the original <0,0,0>.
Although, for a camera position that's not just <0,0,0> but something like
<3,13,-9>, it appears that the interplay between scaled camera and 'new' focal
plane gets much more complicated.
But I tried something weird, which seems to work(!) ...
The initial simple test:
original camera position: <0,0,-5>
original focal_point: <0,0,0>
With scale 2:
new camera position: <0,0,-10>
new focal_point set to: <0,0,5>
Now, with a more complicated camera position:
original camera position: <3,13,-9>
original focal point: <0,0,0>
With scale 2:
new camera position: <...? ...> (I'm too lazy to figure it out)
new focal_point set to: <-13,-3,9>
That appears to bring the original 'focal plane' of <0,0,0> back into sharp
focus! (Although, that plane is always perpendicular or orthogonal(?) to the
camera view.) The math for the new focal_point looks to be quite simple as well.
Date: 12 Feb 2018 01:06:07
Message: <5a812ecf$1@news.povray.org>
> With scale 2:
> With scale 2:
Thanks! That means:
     #local NewCameraFocalPoint = -1 * OldCameraLocation *
(NewCameraScale - 1);
But is this only true if the OldCameraFocalPoint is <0,0,0>? What
happens when the OldCameraFocalPoint is <5,20,-1>?
Would it be more intuitive if the focal point location automatically
scaled scaled with the camera position? E.g.
     #local NewCameraFocalPoint = OldCameraFocalPoint * NewCameraScale;
Mike
Date: 12 Feb 2018 08:10:01
Message: <web.5a818fe93abb6b9ea47873e10@news.povray.org>
> Thanks! That means:
Off the top of my head, I would imagine that it's just a matter of adding or
subtracting the correct differences in values, kind of like my scale 2 example.
I haven't tested that idea though. (I'm also not totally sure if your equation
can work with an odd scaling factor of, say, 4.7 rather than 2 or 3 or 4. Maybe
it can!)
BTW: Having three active newsgroup threads, all generally about the same topic,
is kind of confusing; I'm not sure where to post follow-ups now. In future, it
would be best to have only one (or maybe an extra one for posting actual code,
if it happens to be quite long), and let the comments roll in. ;-)
Date: 12 Feb 2018 08:35:00
Message: <web.5a8197ef3abb6b9ec437ac910@news.povray.org>
I think you need to look at it from the perspective of points, or vectors and
how they behave when scaled.
You have your camera position at a non-origin position, and then you scale it.
So it MOVES.
I'd say the same goes with the look_at point.
Try using a vector transform on a "point" and see if the scaling transform on
two vectors defined to be your camera position and look_at points give you
results that make sense.
#declare MyTransform = transform { scale { ... } }
#declare Foo2 = vtransform(Foo1,MyTransform);
http://news.povray.org/povray.newusers/thread/%3Cweb.56d370be14d864ee5e7df57c0%40news.povray.org%3E/?ttop=418731&toff=5
0
Date: 12 Feb 2018 10:22:02
Message: <5a81b11a$1@news.povray.org>
> So it MOVES.
> from:
> 0
Yes, look at the code I posted in p.t.s-f. That's why I posted it.
Mike
Date: 12 Feb 2018 14:00:02
Message: <5a81e432@news.povray.org>
> they don't.
> camera {
>    location  <0,0,-5>
>    look_at   <0,0,0>
>    up y
> (blurrier)
> is more accurate)
>    scale 2
> camera {
>    location  <0,0,-10>
>    look_at   <0,0,0>
>    up y
> (blurrier)
> is more accurate)
The amount of focal blur depends on the ratio between (1) the distance
between the camera's location and the focal point location and (2) the
actual aperture.
So, with everything else been the same, the second camera have twice the
focal length for the same aperture, resulting in half the focal blur or
twice the sharpness depth.
To get the same results, you need to scale the aperture by the same
amount as the rest of the camera use for the second camera :
aperture 2.0
Date: 12 Feb 2018 14:02:09
Message: <5a81e4b1$1@news.povray.org>
> Any ideas?
> Mike
Use a larger aperture. Something like
vlength(Camera_Location, Focal_point)/4
If that's not enough, use a smaller divisor.
Date: 12 Feb 2018 16:01:53
Message: <5a8200c1$1@news.povray.org>
>> they don't.
>> camera {
>>    location  <0,0,-5>
>>    look_at   <0,0,0>
>>    up y
>> (blurrier)
>> is more accurate)
>>    scale 2
>> camera {
>>    location  <0,0,-10>
>>    look_at   <0,0,0>
>>    up y
>> (blurrier)
>> is more accurate)
> actual aperture.
> aperture 2.0
> Alain
You're wrong, and Kenneth already figured out why up-thread.
Mike
Date: 12 Feb 2018 16:03:42
Message: <5a82012e$1@news.povray.org>
>> Obviously, there is no true scale in POV-Ray, so there's no need to
>> "fake" the effect. But I don't know how to construct the correct camera.
>> Any ideas?
>> Mike
Yeah, I got it working. But it doesn't look as good in POV-Ray as it
does in photography. I'll post some test renders soon.
MIke
Date: 13 Feb 2018 10:05:17
Message: <5a82fead$1@news.povray.org>
I've no idea. I've since closed the image_map specific pull request. As
a request it was submitted - as suggested - in place of another adding
image_maps and pigment_maps to density { }. I myself use the latter
branch with both enhancements and maintaining the image_map one was
always extra work for me as I 'git re-based' my branches over time.
In general, I've pruned back on the github pull requests I leave sitting
in the queue though I still publish any branches I think reasonably
solid that others building their own POV-Ray might find useful.
Having a lot of pull requests backed up on github itself becomes a
burden to the build test machines, it slows me down on re-basing and it
generates a lot of email noise especially for the most connected
developers.
Aside: I am sometimes frustrated by the pace at which changes are
adopted - while also understanding it. We must have knowledgeable gate
keepers and planners for the code base and they have only so much time.
Christoph, especially, has often enough saved me from my own ignorance
or improved upon an idea and my actual implementation. We need the pinch
point, the bottleneck for change - and to reasonably pace change given
many have development code efforts running alongside the master branch.
Bill P.
Date: 13 Feb 2018 19:06:34
Message: <5a837d8a$1@news.povray.org>
>>> Any ideas?
>>> Mike
> MIke
As the ratio aperture/focal_length increase, you also need more samples.
Otherwise, the image will get very noisy.
Date: 13 Feb 2018 20:55:01
Message: <web.5a8396e13abb6b9e5cafe28e0@news.povray.org>
Can you
a) mimic and actual camera lens with glass / ior?
b) look through a clear sheet that has a perturbation or normal that gets
progressively stronger toward the edges?
c) look though a partially transparent image map of the scene that somehow gets
rotated a little further the farther out toward the edge you get?
d) otherwise use overlapping image maps to imitate the photographic "circle of
confusion"?
Date: 13 Feb 2018 23:39:34
Message: <5a83bd86$1@news.povray.org>
On 2/13/2018 8:54 PM, Bald Eagle wrote:
> Can you
> confusion"?
I don't know how to do any of these things. It would probably be easier
to just do post-processing in Photoshop.
Mike
Date: 14 Feb 2018 01:27:20
Message: <5a83d6c8$1@news.povray.org>
>> Can you
>> somehow gets
>> "circle of
>> confusion"?
> Mike
I forgot about the fact that my scenes have some tall objects, and the
Photoshop post-processing doesn't work properly in cases like this.
Will a transparent glass really make much of a difference?
Mike
Date: 14 Feb 2018 11:55:43
Message: <5a846a0f@news.povray.org>
Le 18-02-13 à 20:54, Bald Eagle a écrit :
> Can you
Yes. Tou place an object shaped as the desired lense with the desired
ior just in front of the camera. You can also add some dispersion.
This have been actually used.
You can use camera perturbation or use some actual transparent object
with a perturbed normal or some actual displacement.
Then, it's just a question of modulating the pattern.
There are some samples scenes that show how it can be done.
> confusion"?
Date: 14 Feb 2018 17:20:00
Message: <web.5a84b5923abb6b9ea47873e10@news.povray.org>
I just noticed a dumb error I made-- some switched vector coordinates:
> With scale 2:
With scale 2, it should be...
new focal_point set to: <-3,-13,9> // the CORRECT vector
I hope my mistake didn't totally confuse the idea...
Date: 21 Feb 2018 06:28:16
Message: <5a8d57d0$1@news.povray.org>
> Can you
I'm surprised no one has created a library of simulated cameras/lenses
already. POV-Ray has been around for, what, two decades?
Mike
Date: 21 Feb 2018 07:19:10
Message: <5a8d63be@news.povray.org>
>> Can you
Edouard Poor...
Download 'edouard poor - 35mm camera.zip' (51 KB)
