POV-Ray : Newsgroups : povray.advanced-users : Camera scaling and focal_blur? Server Time
15 Jun 2024 15:41:38 EDT (-0400)
  Camera scaling and focal_blur? (Message 1 to 10 of 28)
Subject: Camera scaling and focal_blur?
Date: 10 Feb 2018 19:46:41
Message: <5a7f9271$1@news.povray.org>
What effect does scaling a camera have on focal_blur?
I have two cameras, and they should both produce the same result. But
they don't.
// focal blur camera
   location  <0,0,-5>
   look_at   <0,0,0>
   up y
   aperture 1.0           // [0...N] larger is narrower depth of field
(blurrier)
   blur_samples 10        // number of rays per pixel for sampling
   focal_point <0,0,0>    // point that is in focus <X,Y,Z>
   confidence 0.95        // [0...<1] when to move on while sampling
(smaller is less accurate)
   variance 1/200         // [0...1] how precise to calculate (smaller
is more accurate)
   scale 2
   location  <0,0,-10>
   look_at   <0,0,0>
   up y
(blurrier)
is more accurate)
Subject: Re: Camera scaling and focal_blur?
Date: 10 Feb 2018 21:35:00
Message: <5a7fabd4$1@news.povray.org>
Also, what if I scale the camera before I add the focal_blur? I am
having trouble with a scene in which the center never appears in focus
like I want it to.
> they don't.
> camera {
>    location  <0,0,-5>
>    look_at   <0,0,0>
>    up y
> (blurrier)
> is more accurate)
>    scale 2
> camera {
>    location  <0,0,-10>
>    look_at   <0,0,0>
>    up y
> (blurrier)
> is more accurate)
Date: 10 Feb 2018 22:35:54
Message: <5a7fba1a$1@news.povray.org>
I've been reading this
https://en.wikipedia.org/wiki/Miniature_faking
and have been wondering how to achieve the effect in POV-Ray. Obviously,
there is no true scale in POV-Ray, so there's no need to "fake" the
effect. But I don't know how to construct the correct camera.
Any ideas?
Mike
Date: 10 Feb 2018 23:32:25
Message: <5a7fc759$1@news.povray.org>
I still don't understand exactly what's happening, but I removed the
scaling and just increased the numbers directly, and things are working
out much better.
Mike
Date: 11 Feb 2018 08:06:52
Message: <5a803fec$1@news.povray.org>
> Any ideas?
See:
http://news.povray.org/povray.binaries.images/thread/%3C57e14051%241%40news.povray.org%3E/
for a technique using a not yet adopted parser change which allowed
image_maps to be used directly in density {} blocks.
Mention it because though our documentation
http://wiki.povray.org/content/Reference:User_Defined_Pattern
doesn't yet disclose it, the new-ish 3.7.1/3.8 pigment { user_defined {
} } capability was implemented by Christoph in a way so it works for
density blocks too. Of course only the R,G,B functions do anything where
used with density {}.
This means it should be possible to implement the tilt shift technique
in the first reference by building up functions which grab the r,g,b
channels via #declare Fn... = function { pigment { image_map {...} } }
and using those functions in two density { user_defined { } } blocks in
a density_map. It's a more awkward means than using the image_maps
directly in the density blocks, but it should work.
The technique uses media blending between two densities. One blurred via
turbulence and one not.
Bill P.
Date: 11 Feb 2018 10:14:41
Message: <5a805de1$1@news.povray.org>
Am 11.02.2018 um 04:36 schrieb Mike Horvath:
> Any ideas?
Yep: Crank up the focal blur `aperture` setting like mad.
Date: 11 Feb 2018 19:00:00
Message: <web.5a80d8243abb6b9ea47873e10@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> ..for a technique using a not yet adopted parser change which allowed
That is *definitely* an interesting and useful idea (as is your current
workaround.) Any idea if this image_map thing is going to be included in a newer
v3.8.x alpha or beta?
Date: 11 Feb 2018 22:08:11
Message: <5a81051b$1@news.povray.org>
>> Any ideas?
The problems I was having involved scaling/transforming the camera. Once
I stopped doing that, things started working properly. I don't really
understand why, but I will post some test scenes in the other forum.
Mike
Date: 11 Feb 2018 22:40:00
Message: <web.5a810c7d3abb6b9ea47873e10@news.povray.org>
> out much better.
I've never tried *scaling* a camera before, but it's an interesting idea.
Using your 'scale 2' camera, what it looks like is that the focal_blur's
focal_point of <0,0,0> (the focal 'plane')is actually shifting to <0,0,-5>. In
other words, it's keeping the same original 5-unit distance from the CAMERA--
not scaling to 2*5 = 10-units. That's what I see from a simple test, anyway.
Date: 11 Feb 2018 22:46:22
Message: <5a810e0e@news.povray.org>
>> out much better.
I posted my scene in p.t.s-f. Could you take a look at that?
Thanks.
Mike
