POV-Ray : Newsgroups : povray.advanced-users : Memory usage Server Time
10 Nov 2025 15:11:26 EST (-0500)
  Memory usage (Message 1 to 10 of 10)
Subject: Memory usage
Date: 30 Jan 2018 14:46:00
Message: <5a70cb78$1@news.povray.org>
There are several programs that convert LDraw models to POV-Ray. I'm
wondering if there are differences in memory usage between the various
types of output. How would I measure the memory usage? Would it be
better to measure peak usage? Average usage over time? Thanks.
Mike
Subject: Re: Memory usage
Date: 31 Jan 2018 15:15:47
Message: <5a7223f3$1@news.povray.org>
> Mike
I meant memory usage inside POV-Ray, if I was not clear.
Mike
Date: 31 Jan 2018 18:37:15
Message: <5a72532b$1@news.povray.org>
> Mike
They all convert to mesh/mesh2 from the same data.
The only difference would be if you perform any subdivision step prior
to the conversion itself.
Date: 31 Jan 2018 19:44:39
Message: <5a7262f7$1@news.povray.org>
>> Mike
Okay thanks.
Mike
Date: 1 Feb 2018 06:49:08
Message: <5a72feb4$1@news.povray.org>
Am 01.02.2018 um 00:37 schrieb Alain:
>> Mike
Some programs can make use of the LGEO parts library; in that case the
result is CSG for any part that is in the library.
For small models, or models that use a gazillion of different parts,
that may be more memory-efficient. Haven't tested it though. The main
advantage of the LGEO parts library is that it is more precise.
Date: 1 Feb 2018 16:50:00
Message: <web.5a738b42b6086a7fc949581a0@news.povray.org>
If high memory usage is your problem, I think it is mainly caused by the LGEO
library as an OpenGL mesh export only (as done by my LDCad) uses just 32MB (yes
mega not giga) during rendering in POV-Ray on my system.
This using your datsville scene (rev528, datsville_master/datsville.ldr)
But I have seen it use over 20GB in the past when doing a LGEO based export
through LDView's export).
Date: 2 Feb 2018 15:23:35
Message: <5a74c8c7$1@news.povray.org>
That's odd, because I run out of memory (8GB) unless I use LDBoxer first
to cut down on triangles.
Mike
Date: 2 Feb 2018 15:33:28
Message: <5a74cb18$1@news.povray.org>
Here is the top of my POV-Ray file.
Mike
// Generated by L3P v1.4 BETA 20131202 (Win32)  (C) 1998-2013 Lars C.
Hassing SP.### [at] AMhassingsdk
// L3P website:  http://www.hassings.dk/l3/l3p.html
// LDraw.org:    http://www.ldraw.org
// Date:         Thu Jan 18 04:57:32 2018
// Input file:
D:\Datsville\datsville_inlined\datsville_rev531_noinline_boxed_none.xmpd
// Title:        Datsville
// Author:       John VanZwieten, Michael Horvath, Tore Eriksson
// ModelDir:     D:\Datsville\datsville_inlined
// WorkDir:      D:\Datsville\helper_scripts\povray
// LDRAWDIR:     C:\Users\Public\Documents\LDraw (LDRAWDIR environment
variable)
// SearchDirs:   (Default)
// SearchDir1:   D:\Datsville\datsville_inlined\ (0x10)
// SearchDir2:   C:\Users\Public\Documents\LDraw\P\ (0x9)
// SearchDir3:   C:\Users\Public\Documents\LDraw\PARTS\ (0x4)
// ldconfig.ldr: C:\Users\Public\Documents\LDraw\ldconfig.ldr
// Commandline:  "E:\Programs Windows\LDraw\l3p14beta\L3P20131202.EXE"
-o l3p_datsville_rev531_noinline_boxed_none.pov -il -ic
Date: 2 Feb 2018 16:15:00
Message: <web.5a74d3dcb6086a7fc949581a0@news.povray.org>
This is the one I rendered yesterday (@1920x1080 in about 12 mins using only
32MB)
http://www.melkert.net/action/download/datsville528MasterPov.7z
6MB 7zip containing 84MB pov file
Haven't used L3P in a very long time, but I think L3P generated meshes for every
single .dat, in LDCad I generate meshes per high level part (basically just
dumping the OpenGL data).
This export was done with the upcomming LDCad 1.6b, but you can also use 1.6a to
make your own export. You only might need to fix some missing object references
resulting from empty models used (I fixed that in 1.6b)
Date: 2 Feb 2018 20:38:07
Message: <5a75127f$1@news.povray.org>
> 32MB)
Wow, that is so much better! I don't even have to inline the model or
replace parts with boxes.
The render time is roughly the same. But the parse time is just a few
seconds versus 10-15 minutes. And it barely uses any memory!
Thanks so much!
Mike
