POV-Ray : Newsgroups : povray.advanced-users : Vector to Angle Server Time
7 Mar 2026 05:45:36 EST (-0500)
  Vector to Angle (Message 1 to 10 of 24)
Subject: Vector to Angle
Date: 29 May 2017 15:42:25
Message: <592c79a1$1@news.povray.org>
I'm trying to master converting a vector to an angle in 3D with no luck
(2D sure, I got that).
I tried two different formulas with varying degrees of not success.
In the code below, the secret to my success will be the VtoA macro.
The result should be, the Cyan sphere, whose position is generated from
the VtoA macro, should be locked in the center of the screen behind the
Red sphere, which is locked to the center of the screen, because it is
look_at.  The current odd return from VtoA is the closest I can get.
This works good if I move from 0 in only one axis at a time.
Help?
dik
Download 'test.inc.txt' (2 KB) Download 'animtest.ini.txt' (1 KB)
Subject: Re: Vector to Angle
Date: 29 May 2017 22:58:49
Message: <592cdfe9$1@news.povray.org>
Am 2017-05-29 15:42, also sprach dick balaska:
Of course I figured it out after finally asking:
// Convert this vector into its angle
#macro VtoA(V)
	#local _V=vnormalize(V);
	#local rZ=degrees(acos(_V.z));
	#local rY=0;
	#if (_V.y != 0)
		#local rY=degrees(atan2(_V.x,_V.y));
	#debug concat("rY/Z=", str(rY,0,2), ", ", str(rZ,0,2), "\n")
	<-rZ,0,-rY>
dik
Date: 31 May 2017 02:06:43
Message: <592e5d73$1@news.povray.org>
Help, Math wizards, you're my only hope.
Ok. I'm stuck. I'm missing something.
My goal is to position an object in a fixed position on the screen, like
carrying a flashlight. Or a gun, like in a video game.
So I need to calculate the angle of Lookat-Camera and act on that.
My primary macro works, but I'm missing something in determining the
position of an object that is not exactly on the look_at.  I can't
figure out if I need to subtract an angle or a vector or from whom.
For example, in this screen shot,
http://www.buckosoft.com/tteoac/video/testRenders/test001.png
the red ball is look_at,
the cyan ball is the angle correctly derived from (look_at-camera),
but the green ball is only correctly 1 unit horizontally to the right of
the cyan ball for this angle <0,0,0>. Otherwise it spins incoherently
(to me) around the cyan ball. Interestingly, it keeps the correct distance.
http://www.buckosoft.com/tteoac/video/testRenders/test.mp4
argh. I keep trying to work it out on paper, but I'm not feeling it.
dik
Download 'test.inc.txt' (3 KB) Download 'animtest.ini.txt' (1 KB)
Date: 31 May 2017 07:55:01
Message: <web.592eae6e3905ed8fc437ac910@news.povray.org>
I was looking through the docs, and there really is SO MUCH in the include files
and macros and functions, that I can hardly keep track of where I started once I
reach the end.
I'd say start by looking over the vector functions like VAngleD(),
VProject_Axis(), VProject_Plane()etc and see if you can maybe blindly plug in
vectors and get it to work.  There might be some scenes in the distribution that
have some good code snippets.
There might also be some good code snippets from things like sunpos.inc and
scenes like my watch animation that handle data like you're talking about.
I have been there SO many times.
I will try to draw it out on paper and see what I can tell you - unless someone
else jumps on this before then.
Date: 31 May 2017 09:20:01
Message: <web.592ec2d03905ed8fc437ac910@news.povray.org>
OK, the way I see it is that you need to take the atan2 of your _distance_
between the 2 points and the x or y value of the look_at
The key is that you need to take into account the x AND y variation of your
vector when you calculate the x and y angles.   So use the whole vector length
in your atan2 function.
so, that would be something like
degrees(atan2(Vlength(LA-Cam), LA.x)) and degrees(atan2(Vlength(LA-Cam), LA.y))
or expanded:
degrees(  atan2 ( sqrt( ((LA.x-Cam.x)^2)+((LA.y-Cam.y)^2)+((LA.z-Cam.z)^2) ),
LA.x  ))
LA.y  ))
(worked out in OpenOffice, so they _may_ some editing need (like the N^2
notation) )
Good luck, YMMV   :D
Date: 31 May 2017 12:07:48
Message: <592eea54$1@news.povray.org>
Try the attached.
Download 'test16.pov.txt' (3 KB)
Date: 31 May 2017 14:40:00
Message: <web.592f0daf3905ed8fc437ac910@news.povray.org>
Oh, a single rotational angle.
That makes sense.
I wasn't sure what he was after - it's hard to tell with something symmetric
like a sphere.
I'm guessing he wants to avoid:
http://www.mathwords.com/a/angle_depression.htm
Date: 31 May 2017 18:50:25
Message: <592f48b1$1@news.povray.org>
Am 2017-05-31 12:07, also sprach scott:
> Try the attached.
Yeah baby! There's nothing like a copy/paste solution that I almost
understand, but does exactly what I want. ;)
I can't wait to try it out on non-solid, non-spherical shapes.
Thanks!
dik
Date: 31 May 2017 19:00:36
Message: <592f4b14$1@news.povray.org>
Am 2017-05-31 07:52, also sprach Bald Eagle:
One of my favorites was, my wife took a picture of me with my chin on
the dining room table, playing with a Lego cow and a ruler.  Which, if
you've seen my animation of the running non-articulated horses, you'll
understand what I was trying to accomplish. ;)  Usually, it's just paper
with random circles and triangles and lines and points.
She: "Do you understand any of that?"
Me: "Not really."
dik
Date: 1 Jun 2017 07:45:00
Message: <web.592ffd473905ed8fc437ac910@news.povray.org>
I can't tell you how many things I measure on a regular basis.
Rulers, tape measures, eye-and-thumb, protractor, or back-estimating from
photos....
Speaking of Legos - you ought to check out the Antikythera mechanism this guy
built entirely from Lego.   :O
Yes.   I have piles and piles of paper with lines and circles and ellipses and
triangles, and then there are the ones where there's a rat's nest of curves and
5 pages of equations...
"WTF are you ***DOING***????!!!"
"Well, ..."
"No. never mind. OMG."
:D
BTW
I think if you just look at the rotation angle like a clock hand on the screen,
centered around your camera location, then all you're doing is calculating the
angle, given the x and y coordinates.
So that's just degrees ( atan2(LookAt.y-Cam.y, LookAt.x-Cam.x) )
