POV-Ray : Newsgroups : povray.advanced-users : CIE xyY color space Server Time
17 Oct 2026 21:45:35 EDT (-0400)
  CIE xyY color space (Message 1 to 18 of 18)
Subject: CIE xyY color space
Date: 10 Mar 2017 13:19:12
Message: <58c2ee20@news.povray.org>
What value ranges are appropriate for this color space? I'm guessing Y
(uppercase) ranges from 0 to 100. But what about x and y? Thanks.
Mike
Subject: Re: CIE xyY color space
Date: 10 Mar 2017 13:21:13
Message: <58c2ee99$1@news.povray.org>
> Mike
Never mind. I just figured out they go from 0 to 1. Doh!
Mike
Date: 10 Mar 2017 13:48:11
Message: <58c2f4eb@news.povray.org>
Am 10.03.2017 um 19:21 schrieb Mike Horvath:
>> Mike
Yup.
With the additional constraint that x+y<=1.
Y technically ranges from 0 to infinity, with no well-defined scale, and
will often be normalized so that the chosen whitepoint has Y=1 or Y=100[%].
Date: 12 Mar 2017 00:04:16
Message: <58c4d6d0$1@news.povray.org>
> Mike
I tried rendering something in this color space. I've tried all the
methods suggested so far, but am still getting "disappearing" areas of
the shape. See the "Holes in isosurface 3" thread in p.t.s-f.
Mike
Date: 15 Mar 2017 15:10:01
Message: <web.58c9911355b89017c437ac910@news.povray.org>
Mike,
With all of your experience with the various color spaces, do you think one
better lends itself to analyzing color images than the others?
For instance, see what I mean here:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5792c33271d66b005e7df57c0%40news.povray.org%3E/
Date: 15 Mar 2017 19:43:50
Message: <58c9d1b6$1@news.povray.org>
On 3/15/2017 3:08 PM, Bald Eagle wrote:
> Mike,
I'm not sure 100% what you're trying to achieve in that thread. Some
sort of histogram of colors used in a photo?
Anyway, this shape is a personal favorite:
https://commons.wikimedia.org/wiki/File:HSL_sphere_color_solid.png
Mike
Date: 16 Mar 2017 04:01:40
Message: <58ca4664$1@news.povray.org>
Am 15.03.2017 um 20:08 schrieb Bald Eagle:
> Mike,
If by "analyzing" you mean anything that is related to human perception
(as opposed to anything that is related to physics), then a somewhat
perceptually uniform colour space would certainly be advantageous, such
as CIE L*a*b or CIE L*u*v, or the even newer DIN99 series of colour spaces.
Date: 16 Mar 2017 08:00:00
Message: <web.58ca7dc555b89017c437ac910@news.povray.org>
Probably true.
I recall spending much time observing your experiments with color gradients and
gamma.
(I think it would be nice to "remap" a color space from HSV to expand the very
narrow red region, and fix any other perceptually non-uniform characteristics.
Just for fun  ;) )
As for my original intent, my "analysis" is an effort to rapidly get a more
pleasing result from sampled colors for use in color maps when trying to
procedurally texture things.  You may recall my lamentations about trying to
replicate the beautiful honey-yellow coloration of a wood floor, since my color
maps only produced pale, washed-out results that weren't anywhere near what I
wanted.
A pipe-dream feature would be to have the RGB values of an area selected in the
render window (like the current re-render selected area feature) written to an
output file, which could then be used as a prototypical color mapping data set.
The edges of my brain's tentacles suggest that 3D fourier transform of that data
may well highlight the major contributing "3D" RGB vectors better than any
visualized histogram in a color space would.
Or I may just be overcomplicating the task.  ;)
I'm also wondering what algorithms various automatic pallette-generating apps
use (Android / Windows Store apps for interior decorating, selecting paint
colors, etc.)
Date: 16 Mar 2017 09:40:11
Message: <58ca95bb@news.povray.org>
Am 16.03.2017 um 12:57 schrieb Bald Eagle:
> wanted.
To be honest, no, I don't remember those lamentations.
Sounds pretty much like a gamma issue to me.
Date: 16 Mar 2017 10:10:01
Message: <web.58ca9bfe55b89017c437ac910@news.povray.org>
It was Oct 2014, so not surprising.
http://news.povray.org/web.5435881bcbb3d8155e7df57c0%40news.povray.org
Date: 16 Mar 2017 10:45:18
Message: <58caa4fe$1@news.povray.org>
Am 16.03.2017 um 15:06 schrieb Bald Eagle:
`[0.4 rgb <184/255, 115/255, 48/255> * Tone]`
Yeah. Any expression starting with "rgb" and containing integer numbers
divided by 255 screams "gamma issue!" at the top of its lungs.
Integer numbers divided by 255 are a sign that the colour were
originally encoded as a byte triplet, most likely raw image values, e.g.
as picked from an image using external tool.
Raw image values typically use non-linear colour values, the best bet
being sRGB.
To specify sRGB colours, you need to use the `srgb` keyword instead of
`rgb`, otherwise you get the colour's gamma wrong.
Unless your scene uses `assumed_gamma srgb` (or an approximate value,
such as `assumed_gamma 2.2`), in which case your entire image suffers
from gamma issues.
(It should be noted that `srgb <184/255, 115/255, 48/255> * Tone`
doesn't give you exactly what you are asking for. Theoretically it
should be `(srgb <184/255, 115/255, 48/255>) * Tone`, but that's
currently not allowed by the parser.)
Date: 16 Mar 2017 11:47:03
Message: <58cab377$1@news.povray.org>
>> Mike
> Mike
I was able to get it to work. Render times were much longer than
previous scenes in this series, however. At 2048x2048 pixels, it took 6
hours to get to 80%, and an extra 24 hours to get from 80% to 100%.
Mike
Date: 16 Mar 2017 13:00:01
Message: <web.58cac3b955b89017c437ac910@news.povray.org>
Excellent information, as always.
Al ways, always, always learning something new and useful here.   :)
So something along the lines of this would be necessary:
(untested, needs handling of optional transmit and filter values)
#macro RGB2SRGB (C_linear)
 // https://en.wikipedia.org/wiki/SRGB
 // C_linear is a standard rgb color vector
 #local RGB = array[3] {C_linear.red, C_linear.green, C_linear.blue};
 #local SRGB = array[3];
 #local _a = 0.055;
 #local _Threshold = 0.0031308;
 #local _Gamma = 2.4;
 #for (Component, 0, 2)
  #if (RGB[Component] <= _Threshold)
   #local SRGB[Component] = 12.92 * RGB[Component];
  #else
   #local SRGB[Component] = ((1 + _a) * pow (RGB[Component], 1/_Gamma)) - _a;
  #end // end if
 #end // end for Component
 #local C_srgb = <SRGB[0], SRGB[1], SRGB[2]>
 C_srgb
#end // end macro RGB2SRGB
Date: 16 Mar 2017 14:08:31
Message: <58cad49f$1@news.povray.org>
>  #local _a = 0.055;
>   #else
>   #end // end if
>  C_srgb
Are you trying to come up with a way to interpolate between different
sRGB values? I think clipla said sRGB space is nonlinear.
Mike
Date: 16 Mar 2017 14:55:00
Message: <web.58cade7855b89017c437ac910@news.povray.org>
> sRGB values?
Nope.  Convert from RGB to srbg
Yup.  That's why there's the exponential term.
Date: 16 Mar 2017 20:08:55
Message: <58cb2917$1@news.povray.org>
Am 16.03.2017 um 17:56 schrieb Bald Eagle:
No, what would be necessary is just the opposite: A mechanism to convert
from sRGB to linear. Because picked colours tend to be in sRGB, and what
POV-Ray needs deep down in its heart is linear.
Which is precisely what the `srgb` keyword was designed to do (presuming
you're using `assumed_gamma 1.0` like you should).
The only drawback is that you can't put `srgb` in brackets to multiply
that expression (which would be a linear colour) with a `Tone` factor.
And if you omit the bracket you get a multiplication in sRGB space
(effectively `srgb (<...>*Tone)`), which isn't exactly what you need.
Date: 17 Mar 2017 15:20:00
Message: <web.58cc35cc55b89017c437ac910@news.povray.org>
Have you considered doing an overlay or an animated fade-in/fade-out of all the
color spaces you've rendered?
Date: 17 Mar 2017 16:38:24
Message: <58cc4940$1@news.povray.org>
I was thinking of showing the sRGB gamut and visible gamut next to each
other, or overlaid. Need to finish working out how to do the visible
gamut, first.
Mike
