POV-Ray : Newsgroups : povray.advanced-users : function select logic Server Time
17 Oct 2026 21:47:41 EDT (-0400)
  function select logic (Message 1 to 17 of 17)
Subject: function select logic
Date: 23 Nov 2016 01:59:17
Message: <58353e45$1@news.povray.org>
I have the following three functions:
#declare correctRGB_R = function(R,G,B) {min(max(R,0),1)}
#declare correctRGB_G = function(R,G,B) {min(max(G,0),1)}
#declare correctRGB_B = function(R,G,B) {min(max(B,0),1)}
They each process input and output one component of an R,G,B color vector.
However, instead of the above, I want the entire vector discarded if
*any* of R, G or B is less than zero or greater than one.
I'm not sure how to form the select statement. What is the best way to
do this?
Mike
Subject: Re: function select logic
Date: 23 Nov 2016 07:55:00
Message: <web.583590e8a279be30c437ac910@news.povray.org>
> do this?
> Mike
Wrap all three #declares in a conditional block?
#if (R>1 | R<0 | G>1 | G<0 | B>1 | B<0)
     // do nothing, or whatever else you want
#else
or something along those lines....
Date: 23 Nov 2016 09:30:26
Message: <5835a802$1@news.povray.org>
>> do this?
>> Mike
What do you mean by discarded? A function must always return a value,
there is no "discarded" option. Where/how are you going to use these
three functions and what do you want the final result to be if the input
RGB is out of range? You could return a special value like -1 to
indicate a "discarded" vector - but it depends what you're going to do
next with the result.
> #else
> #end
That's just going to decide whether or not to declare the functions in
the scene, on some unrelated RGB variables (RGB in the function
definitions are just parameters). It won't affect the behaviour of the
function when it is actually used later on (apart from getting an error
that it is undefined).
Date: 23 Nov 2016 10:05:01
Message: <web.5835afe1a279be30c437ac910@news.povray.org>
That was my concern as well.
I thought of a similar -1 or other "flag" value - and then he could set transmit
to 1 so it's essentially invisible.
Well that was the "or..." part of the "do nothing" conditional result.
#declare RGB = color rgbt <1, 1, 1, 1>;
would be a default "hide / 'discard' this out of range result"
Date: 23 Nov 2016 10:40:14
Message: <5835b85e$1@news.povray.org>
I think you misunderstand my point. Any #if, #declare etc will only get
evaluated once when the scene is parsed. You'll end up with either your
function declared or not declared. When you come to use that function in
a pigment or isosurface or whatever your #if #declare statements won't
be executed again. Any logic needs to go inside the function declaration
using the select function, not #if.
Using the transmit channel is a good idea though. You could define
another function for calculating the transmit value, that just returns 1
if any of RGB parameters are out of range, or zero otherwise. This needs
to be a select statement inside a function though, not using #if.
Date: 23 Nov 2016 11:00:01
Message: <web.5835bcf1a279be30c437ac910@news.povray.org>
True.
Though I was looking at "equations" not any declared functions.
I think that Mike is going to have a devil of a time trying to get that to go
with an isosurface.  That needs to be an implicit surface, no?
I'm leaning towards a parametric using splines defined by points resulting from
his stack-of-blocks code.
Maybe someone more clever, and with more round-tuits has a more elegant
solution....
Date: 23 Nov 2016 11:09:42
Message: <5835bf46$1@news.povray.org>
> True.
If this is the case then it's very easy, no need to use any functions or
select at all ... sorry, blatant copy&paste of your example :-)
#else
      // we know here that RGB are all within the 0...1 range, so no need
      // to clamp with min/max
      object{ blah blah pigment{ color rgb <R,G,B>} }
But I got the impression from Mike's post that he needed a function to
do this for use later (maybe in a pigment?).
Date: 23 Nov 2016 12:20:01
Message: <web.5835cfbaa279be30c437ac910@news.povray.org>
Does this work?
#version 3.7;
global_settings {assumed_gamma 1.0}
#declare LimitRange = function (Number) {
 select (Number,      // Input
 666,        // special flag value for values less than zero
 select (1-Number, 666, Number)  // second select operation
 )        // 1 - 0 = 1
}         // 1 - 1 = 0
         // 1 - 1.1 = - 0.1
         // so using (1 - Number) then filters out numbers greater than 1
#for (Number, -1, 2, 0.5)
 #declare Result = LimitRange (Number);
 #debug concat( "Number = ", str(Number, 3, 1),  "     Result = ", str(Result,
3, 1), "\n")
Date: 23 Nov 2016 12:20:15
Message: <5835cfcf$1@news.povray.org>
It's for an isosurface, actually, not a color. It just so happens I'm
modeling a color solid. So color = shape. Sorry.
When any of R, G or B are outside the range 0..1, then I do not want it
to be part of the shape. I think a select statement can do this.
Mike
Date: 23 Nov 2016 15:50:24
Message: <58360110$1@news.povray.org>
>  )        // 1 - 0 = 1
> }         // 1 - 1 = 0
>          // 1 - 1.1 = - 0.1
> 3, 1), "\n")
> #end
Can this be used to generate an isosurface? Will the 666 break an
isosurface?
Mike
Date: 23 Nov 2016 17:18:35
Message: <583615bb$1@news.povray.org>
Am 23.11.2016 um 21:50 schrieb Mike Horvath:
>>  )        // 1 - 0 = 1
>> }         // 1 - 1 = 0
>>          // 1 - 1.1 = - 0.1
>> str(Result,
>> 3, 1), "\n")
>> #end
> isosurface?
Don't listen to that man.
Isosurfaces need contiguous functions, and the key to "discarding" some
set of coordinates from an isosurface is via the threshold.
You want to find a function f(x,y,z) and a threshold T so that
f(x,y,z)<T if all of R, G and B are within the range 0..1, f(x,y,z)>T if
any is outside that range, and f(x,y,z)=0 if any is exactly on a border
of the range. You also want f(x,y,z) to increase reasonably steadily
near the borders.
In other words, you need a function that gives you a kind of estimate
how close you are to the border, with f<T indicating that you are on the
inside, f>T that you are on the outside.
If you only had R and the upper bound of 1 to worry about, the task
would be easy-peasy: All you'd need is a threshold, and a reasonably
smooth function that is below that threshold for inside points, and
above the threshold for outside points. You already have that:
    T = 1
    f(x,y,z) = R(x,y,z)
If you only had R and the lower bound of 0 to worry about, the task is
also not too difficult: Again you already have a threshold; the function
R won't fit as-is though, as it would be below the threshold outside,
and above the threshold inside. But that can easily be fixed:
    T = 0
    f(x,y,z) = -R(x,y,z)
However, if you have to worry about both the upper and lower bound, you
need a function that "dips" below the threshold between the bounds; The
mathematical absolute is a good basis for this; for example, the
following would test for the bounds -1 and 1:
    T = 1
    f(x,y,z) = abs(R(x,y,z))
This doesn't perfectly fit your problem, as the lower bound is wrong.
Now we don't have any trivial single operation that could fix that, but
changing the threshold will change the total width of the interval while
keeping its center unaffected, and adding a constant to the abs()
parameter will change the center while keeping its total width
unaffected. So after some deliberation, we'll end up with:
    T = 0.5
    f(x,y,z) = abs(R(x,y,z)-0.5)
At R=0 this evaluates to:
    f = abs(0-0.5) = abs(-0.5) = 0.5 = T
and at R=1 it evaluates to:
    f = abs(1-0.5) = abs(0.5) = 0.5 = T
Now that we have figured out how to test for R being inside the bounds,
we can move on to G and B: Obviously the basic principle is the same, so
all we need to figure out is how to combine the three:
    T = 0.5
    fR(x,y,z) = abs(R(x,y,z)-0.5)
    fG(x,y,z) = abs(G(x,y,z)-0.5)
    fB(x,y,z) = abs(B(x,y,z)-0.5)
We need to find a single function f(x,y,z) so that f<T if all of
fR,fG,fB are smaller than T, but f>T if any is larger than T.
It turns out that max(fR,fG,fB) should give us exactly that. So we end
up with:
    T = 0.5
    f(x,y,z) = max (
      abs(R(x,y,z)-0.5),
      abs(G(x,y,z)-0.5),
      abs(B(x,y,z)-0.5)
Date: 23 Nov 2016 17:53:04
Message: <58361dd0$1@news.povray.org>
>     T = 1
>     f(x,y,z) = R(x,y,z)
Unfortunately, my R(x,y,z), G(x,y,z) and B(x,y,z) are not producing a
visible shape.
Only 1-R(x,y,z), 1-G(x,y,z) and 1-B(x,y,z) are doing so, and they all
look identical for some reason.
Mike
Date: 23 Nov 2016 18:28:42
Message: <5836262a$1@news.povray.org>
> do this?
> Mike
Here is the code I came up with:
// utility
#declare selectRGBa = function(C,D) {select(C,0,D)}
#declare selectRGBb = function(C,D) {select(C-1,D,D,0)}
// input R: between 0 and 1
// input G: between 0 and 1
// input B: between 0 and 1
// output R: between 0 and 1
// output G: between 0 and 1
// output B: between 0 and 1
#declare correctRGBa1 = function(R,G,B)
{selectRGBa(R,selectRGBa(G,selectRGBa(B,R)))}
#declare correctRGBa2 = function(R,G,B)
{selectRGBa(R,selectRGBa(G,selectRGBa(B,G)))}
#declare correctRGBa3 = function(R,G,B)
{selectRGBa(R,selectRGBa(G,selectRGBa(B,B)))}
#declare correctRGBb1 = function(R,G,B)
{selectRGBb(R,selectRGBb(G,selectRGBb(B,correctRGBa1(R,G,B))))}
#declare correctRGBb2 = function(R,G,B)
{selectRGBb(R,selectRGBb(G,selectRGBb(B,correctRGBa2(R,G,B))))}
#declare correctRGBb3 = function(R,G,B)
{selectRGBb(R,selectRGBb(G,selectRGBb(B,correctRGBa3(R,G,B))))}
The selectRGBa and selectRGBb functions are new helper functions.
Mike
Date: 23 Nov 2016 18:39:51
Message: <583628c7$1@news.povray.org>
Am 24.11.2016 um 00:28 schrieb Mike Horvath:
>> vector.
>> do this?
>> Mike
And do you have any idea what it actually does? ;)
Because I have a hunch you're still struggling with the basic concepts
you're trying to employ.
My recommendation would be to toy around with the isosurface tutorial a
bit, to get a better understanding of what isosurfaces actually do,
before you try to apply them to your problem.
Date: 23 Nov 2016 19:20:27
Message: <5836324b$1@news.povray.org>
No I don't. In fact I don't understand why a parametric wouldn't work
better. Except that it is limited to u and v, whereas I need a third
parameter L.
But you said isosurfaces were the way to go.
Mike
Date: 23 Nov 2016 20:16:45
Message: <58363f7d@news.povray.org>
Am 24.11.2016 um 01:20 schrieb Mike Horvath:
> parameter L.
Yes. Because parametrics are kind of the other way round.
In isosurfaces, you use a function that maps 3D space to something.
In parametrics, you use a set of functions that map something to 3D space.
In the isosurface approach to your problem, you basically design a
function that performs the mapping
    3D cartesian -> Lch -> RGB -> "distance" to boundaries
and let the isosurface iterate over 3D space to find the points that
fall inside valid RGB space.
In the parametrics approach to your problem, you basically design a
family of functions that perform the mapping
    RGB -> Lch -> 3D cartesian
and let a set of six(!) parametrics iterate over two dimensions of RGB
space (RG, RB and GB, respectively), with the third dimension set to one
of the limits (0 or 1, respectively) to find out where those faces end
up in 3D space.
You may note that the isosurface approach will give you a volume, and is
therefore fully suited for use in CSG, whereas the parametrics approach
will give you surfaces only, and therefore will only work properly in
unions.
Date: 24 Nov 2016 03:04:09
Message: <58369ef9$1@news.povray.org>
Ignore all our guesses then as to what you wanted - clipka already
posted what you should do.
