POV-Ray : Newsgroups : povray.advanced-users : L*C*h(uv) color solid Server Time
20 Jun 2026 17:44:33 EDT (-0400)
  L*C*h(uv) color solid (Message 61 to 70 of 82)
Subject: Re: L*C*h(uv) color solid
Date: 28 Nov 2016 03:28:21
Message: <583beaa5$1@news.povray.org>
On 11/28/2016 3:23 AM, scott wrote:
>>> May I ask the stupid question, "why not"?
>>> I would expect the Lch colour space to encompass all the RGB colour
>>> space, so the boundaries of the latter should be sufficient to bound the
>>> shape.
>>> My guess is that the issues you see with the shape are due to bogosities
>>> in your colour conversion functions.
>> L, C and H are supposed to form a cylinder. There are some very small
>> sRGB bits poking outside of the cylinder. I guess I could show the bits
>> as well, as long as I explain what they are.
> If sRGB is poking out of your cylinder, then Adobe RGB is going to poke
> out even more, and the entire human visual range is going to be much
> larger. Are you sure you've got the radius of your cylinder correct to
> match your colour calculations? Also it would be surprising to me if the
> human visual range came out exactly as a cylinder (after a brief glance
> of the maths involved), are you sure about this?
Yeah, I explain the mistake I made in this thread:
http://news.povray.org/583bd889%241%40news.povray.org
Mike
Date: 28 Nov 2016 03:33:52
Message: <583bebf0$1@news.povray.org>
The human visual range has a very irregular shape.
https://en.wikipedia.org/wiki/File:Cie_Chart_with_sRGB_gamut_by_spigget.png
There's a lot of blank empty space around it in every color space. (The
one in the picture is called CIExyY I think.
I would like to learn how to plot this irregular shape in the near future.
Mike
Date: 28 Nov 2016 03:53:53
Message: <583bf0a1$1@news.povray.org>
You just need the XYZ colour-matching functions in terms of wavelength.
Look here (just click the first "Submit" to get a basic table):
http://cvrl.ioo.ucl.ac.uk/cmfs.htm
This table then gives you the exact XYZ values for each pure wavelength.
XYZ is a linear representation of absolute colour, so you can do a lot
of math with them (eg adding, averaging, mixing etc).
To get the graph you linked to, you just need to calculate x and y for
each of those wavelengths.
x = X/(X+Y+Z)
y = Y/(X+Y+Z)
You'll then find that the x,y pairs give the outline of the graph you
linked to, which are the pure wavelengths. The internal area is formed
by mixing pure wavelengths, so roughly speaking the further you are away
from the boundary the more "wideband" the light is.
Date: 28 Nov 2016 04:11:41
Message: <583bf4cd$1@news.povray.org>
>> future.
> x = X/(X+Y+Z)
> y = Y/(X+Y+Z)
Well, I don't understand that. Clipka did most of the work for me last
time...
Maybe you could take a look at the code on the LCH image's page on
Wikimedia and make some suggestions.
Mike
Date: 28 Nov 2016 04:13:28
Message: <583bf538@news.povray.org>
> x = X/(X+Y+Z)
> y = Y/(X+Y+Z)
Also, I'm more interested in the 3-dimensional solid than the 2D
chromaticity diagram.
Mike
Date: 28 Nov 2016 04:24:37
Message: <583bf7d5$1@news.povray.org>
The 3D solid of the Yxy shape is just the 2D shape you linked to
extruded upwards as a prism. That's why you don't normally see Yxy or
Yuv shown in 3D - it doesn't give any benefit over the 2D shape.
Date: 28 Nov 2016 04:25:06
Message: <583bf7f2$1@news.povray.org>
>>> future.
>> x = X/(X+Y+Z)
>> y = Y/(X+Y+Z)
Which bit?
Date: 28 Nov 2016 17:21:47
Message: <583cadfb$1@news.povray.org>
I thought there was some tapering as the Y increases? This image
suggests that is the case.
http://www.math.ubc.ca/~cass/courses/m309-03a/m309-projects/bajwa/images/cie_3d.gif
Mike
Date: 28 Nov 2016 18:06:00
Message: <583cb858$1@news.povray.org>
Am 28.11.2016 um 23:21 schrieb Mike Horvath:
That's not the limit of the xyY space.
That's the theoretical limit of _reflective_ colours illuminated by
standard illuminant C, plotted in xyY space.
Date: 28 Nov 2016 18:33:20
Message: <583cbec0$1@news.povray.org>
Yes, that is fine. Not sure whether to use C or D65, though.
https://en.wikipedia.org/wiki/Illuminant_D65
These images on Wikipedia use D65, so I may just stick with that.
https://en.wikipedia.org/wiki/File:CIE1931xy_gamut_comparison.svg
https://en.wikipedia.org/wiki/File:Lab_color_space.png (I think)
Mike
