POV-Ray : Newsgroups : povray.advanced-users : Stochastics expertise needed Server Time
23 Nov 2026 05:21:27 EST (-0500)
  Stochastics expertise needed (Message 1 to 26 of 26)
Subject: Stochastics expertise needed
Date: 25 Aug 2016 20:15:43
Message: <57bf8a2f$1@news.povray.org>
Folks, I could need a bit of help with a maths problem.
I need an algorithm to generate random points on the surface of a
sphere, conforming to the following criteria:
- The distribution must be radially symmetric around the Y axis.
- The sample density should be roughly uniform, except for a pronounced
peak centered at +Y (but not -Y!)
- For each random point generated, the algorithm also needs to compute
the theoretical sample density at that location.
- The algorithm must be reasonably fast.
Ideally, the algorithm should also have the following properties:
- The density should fall off smoothly from the peak.
- The algorithm should have a parameter to govern the "tightness" of the
peak.
- The sample density away from the peak should approach (but not reach!)
zero.
Subject: Re: Stochastics expertise needed
Date: 26 Aug 2016 04:30:00
Message: <web.57bffd228629941bdadd19850@news.povray.org>
> peak.
> zero.
I suppose no. 16 on http://mathworld.wolfram.com/SpherePointPicking.html hints
at the solution: You "just" need a space defined by a vector that meets the
above criteria. The "distortion" of the space at the selected point will then
allow computation of a scalar that should have some relation to the sample
density. Basically, with the shape of the unit hull you can also shape the
sample density by projecting it back on a unit sphere.
However, I am not sure if the "incorrect" example on that page won't
already solve most of your problem.
Date: 26 Aug 2016 05:36:31
Message: <57c00d9f@news.povray.org>
Am 26.08.2016 um 10:28 schrieb Thorsten Froehlich:
"_hints_ at the solution"... "_some_ relation to the sample density"...
(emphasis added)... I think I see a pattern there ;)
Not exactly:
- It has samples bunching up at both poles, not just +Y.
- The tightness of the bunching-up cannot be tweaked.
- The off-peak density does not approach zero.
Date: 26 Aug 2016 11:45:00
Message: <web.57c063998629941bb488d9aa0@news.povray.org>
I'm busy at the moment, but:
define a sphere with radius 0.5
pow(x,2) + pow(y,2) = 0.5
so pow(y,2) = 0.5 - pow(x,2)
and y = sqrt ( 0.5 - pow(x,2))
translate y*0.5
y = sqrt ( 0.5 - pow(x,2)) +0.5
make your function equal to the sin of that times pi/2 so that the function
smoothly increases from 0 to 1
add the smallest number POV will work with to that (1E-whatever)
Multiply that by a line equation, the slop of which is the tightness
I will give this some more thought
Date: 26 Aug 2016 12:50:01
Message: <web.57c072418629941bb488d9aa0@news.povray.org>
Try this as a starting point
// spherical pattern
// Bald Eagle 2016
#version 3.7;
global_settings {assumed_gamma 1.0}
#include "textures.inc"
#include "rand.inc"
 location <0, 0.5, -2>
 look_at  <0, 0.5, 0>
light_source {<20, 50, -100> White shadowless}
#declare R = 0.5;
#declare Tiny = 0.000001;
#declare Stream = seed (123);
#for (Point, 1, 5000)
    #declare Variable = (VRand_On_Sphere(Stream)*0.5 + <0, 0.5, 0>);
    #debug concat( "Variable = ", vstr(3, Variable, ", ", 3, 3), " \n")
    #declare Color = <abs(pow (Variable.y, 1))+Tiny, 0, 0>;
    #debug concat( "Color = ", vstr(3, Color, ", ", 3, 3), " \n")
    sphere {Variable, 0.01 pigment {rgb Color}}
Date: 26 Aug 2016 13:15:01
Message: <web.57c078cf8629941b69e826dc0@news.povray.org>
> peak.
> zero.
I see a certain contradiction because a uniform distribution cannot fall off
smoothly to zero. My first idea is to use a 2D-normal distribution and project
it onto the sphere. One can play with the sigma(s) to sharpen the peak and/or
use weighted averages of such distributions.
Best regards,
Michael
Date: 26 Aug 2016 14:05:01
Message: <web.57c083f28629941bb488d9aa0@news.povray.org>
I see the "probability" aspect of this now...
no time to code it at the moment.
define a spline with a probability function
sparse near 0, denser near 1, maybe exponentially peaking at 1
choose rand between 0 and 1
pluck out y value from spline
then it's just a sphere in that y gradient
Date: 26 Aug 2016 16:20:00
Message: <web.57c0a3b08629941b7a3e03fe0@news.povray.org>
> peak.
> zero.
Let me simulate it in Blender. I use a system of particles and particle_map.
We have invented a bicycle.
Blender - your problem?
Date: 26 Aug 2016 16:40:00
Message: <web.57c0a88b8629941bb488d9aa0@news.povray.org>
likely.  ;)
// Log spherical pattern
// Bald Eagle 2016
#version 3.7;
#include "rand.inc"
#declare R = 5;
 location <0, R, -15>
 look_at  <0, R, 0>
#declare Stream2 = seed (456);
#declare Stream3 = seed (789);
#declare Sphere_Spline =
  spline {
    linear_spline
   -0.25, <-0.25, 0.0, 0>,
    0.00, <0.00000000000000000001, 0.0, 0>,
    1.00, <1, 0, 0>
    1.1 , <1.1, 0, 0>
#declare Sphere1 =
union {
    #for (Point, 1, 1000)
        #declare Phi =  RRand(0, 2*pi, Stream);
        #declare Variable2 = RRand(1.00000001, 10, Stream2);
        #declare Theta = -pi*Sphere_Spline(1-log(Variable2))+(pi/2);
    #declare X = R * cos (Theta.x) * sin (Phi);
    #declare Z = R * cos (Theta.x) * cos (Phi);
    #declare Y = R * sin (Theta.x) + R;
    sphere {<X, Y, Z>, 0.01 pigment {Red} }
object {Sphere1}
Date: 26 Aug 2016 17:45:00
Message: <web.57c0b8258629941b7a3e03fe0@news.povray.org>
> likely.  ;)
Tomorrow you will be asked to another location formula. The day after tomorrow
another. In each case the formula. Tired, you want to relax.
I have shown in the screenshots universal way: image_map.
Draw Mandelbrot grayscale on any object - no problem. :)))))
Date: 26 Aug 2016 18:40:01
Message: <web.57c0c5018629941b5e7df57c0@news.povray.org>
Yes, my Russian friend, but we ask many things of our good friend Christoph, and
he works hard for us to deliver the goods.
I'm always glad to help a friend, and I always look forward to seeing your
interpretations and experiments, translating between Blender and POV-Ray.
I think that he wants a function, an algorithm, that can be called in the source
code of POV-Ray, in order to perform a certain task.
It needs to be a method whereby any given point can be selected at random, and
the function will evaluate a probability density on the sphere.
It seems a lot to me like a highlight model.
I had many things to do today, and did the best I could on short notice, just to
illustrate the basic idea.  With some refinements, perhaps this evolve into
what's needed.
I am not sure I understand the banding on your image map method.
I think clipka needs something that is a very dense cluster at y=1 and hardly
anything at all near y=0.  I'm not sure my model is accurate, but it was a quick
brainstorming exercise.
Date: 26 Aug 2016 19:20:00
Message: <web.57c0ce5f8629941b7a63dc9f0@news.povray.org>
> peak.
> zero.
You parametrize your sphere by t,y using the formula  x= r cos t, y,z= r sin t
with  y in [-1,1] and r=sqrt(1-y^2).
Then you choose t uniformly, and for y, you choose your distribution as you want
(this is you free parameter). Then the density around a point x,y,z depends only
on y.
If you want an explicit density with associated random points on the sphere in
povray, you may choose a density d(y) pieciwise affine : constant equal to c1>0
on an interval [-1,p] and growing from c1 to c2 when y is  in [p,1].  Then you
choose randomly and uniformly  (y,v) in [-1,1]x[0,c2]. If v>d(y), throw your
point away. If v<=d(y), choose t randomly and put the point P(t,y) on the
sphere.
This shoud satisfy all your needs if I'm not wrong.
Date: 26 Aug 2016 22:21:19
Message: <57c0f91f$1@news.povray.org>
Am 27.08.2016 um 00:38 schrieb Bald Eagle:
You've hit the nail right on the head :)
This is intended to become part of a stochastic sampling mechanism,
intended to compute both diffuse interreflections (as currently computed
by radiosity) /and/ blurred reflections (as currently computed by a
dedicated algorithm in UberPOV) in one go.
A simple procedure to achieve that would be as follows:
(1) Pick a random direction, using a uniform distribution.
(2) Trace a ray in that direction to compute how much light comes from
other objects in that driection.
(3) Pretending that we have a light source in that direction, use the
established algorithms for diffuse, specular and phong to compute the
effective brightness the surface would exhibit if it was illuminated
only from this direction.
(4) Repeat, summing up the effective brightness for illumination from a
handful of directions.
(5) Divide the computed sum by the number of rays shot.
However, while this approach is ok for materials where the diffuse
contribution dominates, it's far from ideal when highlights are the
dominant component, since in that case we waste a lot of energy on
directions that contribute virtually nothing.
What we need to do is change the probability distribution of the random
directions. Ideally, the distribution should match the combined BRDF of
the diffuse, specular and phong components, but that might be difficult
to achieve, and besides all we need is a somewhat /similar/
distribution. So that's what I'm searching for.
Obviously however, if we just plug in a different random distribution
into the above mechanism, the regions with high distribution will tend
to be overrepresented in the the result; the solution to that is to
weigh the individual directions' contributions by the inverse of the
probability for picking that particular direction. But that's where I
start to struggle.
To keep things simple, I've decided /not/ to aim for a distribution that
matches a certain combined BRDF, but rather use two different
distributions: One custom-tailored for highlights, and one
custom-tailored for diffuse (cos-weighted should be ideal there). I
would then choose between the two distributions alternatingly or at random.
Date: 26 Aug 2016 22:40:00
Message: <web.57c0fd6f8629941b5e7df57c0@news.povray.org>
Here's my crappy code, but best looking distribution for the day (based on my
abyssmal histograph).
I think it's a matter of defining the function / spline / clustering of the
random vector - everything else looks fairly straightforward.
I especially wanted to avoid the wasteful hit-or-miss style algorithm - so I
made sure every random number returns a "valid" result.
I'd say this looks like a statistics specialty, or given the spherical-based
distribution - a quantum mechanics-type function.
I hope this acts as a first pointer in the right direction.
{I started to struggle right at Theta and Phi.   ;)  :D   }
// spline / sqrt spherical pattern
// Bald Eagle 2016
#version 3.7;
#include "rand.inc"
#declare R = 5;
 location <0, R, -20>
 look_at  <0, R, 0>
 up y
#declare Stream2 = seed (456789);
  spline {
    linear_spline
   //-0.25, <-0.25, 0.0, 0>,
 0.1 <0.9, 0, 0>,
    1.00, <1, 0, 0>
   // 1.1 , <1.1, 0, 0>
#declare Samples = 10000;
#declare Histograph = array [60]
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0};
#declare Sphere1 =
union {
    #for (Point, 1, Samples)
        #declare Variable2 = RRand(0, 1, Stream2);
        //#declare Variable2 = RRand(1.00000001, 10, Stream2);
  //#declare Theta = (pi*Sphere_Spline(Variable2).x)-(pi/2);
  #declare Theta = (pi*sqrt(Sphere_Spline(Variable2).x))-(pi/2);
        //#declare Theta = (-pi*(1-Sphere_Spline(log(Variable2)).x))+(pi/2);
        //#declare Theta = (-pi*abs(Sphere_Spline(pow(1-log(Variable2),
3)).x))+(pi/2);
 #declare Histograph [int((Y/(2*R))*59)] = Histograph [int((Y/(2*R))*59)]+1;
object {Sphere1}
cylinder {<0, 0, 0>, <6, 0, 0>, 0.05 pigment {Blue} }
cylinder {<0, 0, 0>, <0, R, 0>, 0.05 pigment {Blue} }
#for (GraphX, 0, 60-1)
 sphere {<GraphX/10, Histograph[GraphX]/10, 0>, 0.1 pigment {Green}}// translate
-y*R}
Date: 26 Aug 2016 23:49:51
Message: <57c10ddf$1@news.povray.org>
Am 27.08.2016 um 01:18 schrieb lelama:
> on y.
Gee, I you have indeed nailed it!
Date: 27 Aug 2016 02:24:09
Message: <57c13209$1@news.povray.org>
Am 27.08.2016 um 05:49 schrieb clipka:
>> on y.
Hm... this still leaves me with a quest for an easy-to-generate random
distribution in the range [0..1) with a nicely configurable peak at 0,
and an easy-to-compute probability density function.
I guess I want the derivative of the probability density function to be
zero at the peak, and ideally also at 1.
Date: 27 Aug 2016 05:30:00
Message: <web.57c15b268629941b7a63dc9f0@news.povray.org>
> >> on y.
There is a proposal at the end of my previous message. Using uniform
distribution for y,t,d and throwing away some "bad" points, you get
whatever distribution you want. If you don't like the piecewised
affine d that I suggested (the derivative of the density probabilty is not zero
at y=1, so maybe not suitable for you), you can choose any positive function d
instead with the same construction.
By the way, the parameter c1 is not useful in my formula for the function d. One
can take c1=1 and adjust only the parameters p ( p close to 1 means that the
peak is very localised around y=1 ) and c2 ( the higher the c2, the bigger the
difference of intensity between y=1 and the zone with low uniform intensity).
have a good day,
Date: 27 Aug 2016 06:13:24
Message: <57c167c4$1@news.povray.org>
Am 27.08.2016 um 11:26 schrieb lelama:
> Hi,
The monte-carlo approach of generating arbitrarily distributed random
numbers is only practical if the points to throw away are reasonably
few, in other words if d(y)>>0 for most of the function. Unfortunately
that's specifically not the case I'm aiming for -- I want d(y)>>0 only
in a small portion near y=0.
Date: 27 Aug 2016 07:05:01
Message: <web.57c172d08629941b7a63dc9f0@news.povray.org>
> > Hi,
Hmm, Yes, I see your objection.
A possibility then is to divide the surface under the graph of the function d
into smaller parts. For instance, in the piecewise affine case, the area under
the graph can be decomposed as a union of a rectangle R with measure r and a
triangle T with measure t . It is not too hard to make a uniform distribution
for points in R and an other uniform distribution for points in T.
Let t0,r0 be integers such that (t0,r0) is a vector proportional to the
measusrements (t,r) of the triangle and the rectangle.
Then choosing alternativly t points in the Triangle and r points in the
Rectangle with the uniform distributions discussed above yield the required
distribution without the problem you mentioned.
hth,
Laurent.
Date: 27 Aug 2016 07:40:00
Message: <web.57c17b018629941b5e7df57c0@news.povray.org>
I have to be out for most of the day today, but I figured if we were searching
for a "bicycle" that already exists, then a search ought to pick up a nice
parametrizable equation.
I started off with blackbody and Maxwell-Boltzmann distributions, but then
enough coffee kicked in...   ;)
https://www.google.com/#q=brdf+code
http://graphicrants.blogspot.com/2013/08/specular-brdf-reference.html
https://support.solidangle.com/pages/viewpage.action?pageId=5800819
https://www.google.com/#q=highlight+reflection+distribution
What's the "input" for this algorithm?  A vector?   I'm assuming that the output
is just the vector on the unit sphere.  I'm trying to visualize where this
"plugs in" to the pixel-evaluation chain of events.
Date: 27 Aug 2016 08:41:49
Message: <57c18a8d$1@news.povray.org>
Am 27.08.2016 um 13:35 schrieb Bald Eagle:
Congratulations, it seems like you've just found out what a BRDF is...
now to my problem of generating random numbers with a distribution that
is reasonably close to a given BRDF (in order to get an efficient
sampling), while keeping track of the probability of the numbers we're
generating (in order to compensate for the virtually inevitable mismatch) ;)
Date: 1 Sep 2016 18:20:00
Message: <web.57c8a8e08629941b5e7df57c0@news.povray.org>
Thanks!   Do I win a prize?   :D
So, after skimming some of the literature, I have a much better idea of what
you're specifically looking for - some form of Importance Sampling.
If you can post a graph of the BRDF that you're trying to simulate for the
purposes of your sampling algorithm, or a means of plotting it themselves, then
that might give anyone following along a nudge forward.
It seems that for any given function plotted between A and B, the probability of
having X land in that interval is the integral (S) of that function.
So, for my square root spline sampling function, f(x) = pow(x, 0.5)
so S(pow(x, 0.5) = 1/1.5 * pow(x, 1.5).
Also,
My apologies, but I'm trying to figure out what you actually mean when you say
"keep track of the probability..."
Do you tallying up the actual results of the random sampling so that you can do
a summation and then divide by the number of random samples?
Date: 2 Sep 2016 01:30:30
Message: <57c90e76$1@news.povray.org>
Am 02.09.2016 um 00:17 schrieb Bald Eagle:
Yes, that's what the experts call it.
I can't. That's the crux of the matter: The algorithm needs to cope with
varying BRDFs. It might be Lambertian with a Phong highlight, or
Oren-Nayar with a Blinn-Phong highlight, or (in the future) maybe
Cook-Torrance, He-Torrance, Ward, Schlick, Lafortune, or whatever smart
brains may still come up with and someone decides to implement in POV-Ray.
I therefore intend to use a very simple approximation to generate my
sampling distribution, and compensate for the difference to the BRDF
(which, by the way, may actually not even be a true BRDF, such as
anything involving POV-Ray's brilliance model) by multiplying the
computed colour of the sample with the BRDF (which will actually be
hidden away in the sample computation) and then dividing it by the
probability that my sampling direction generator spits out that
particular sampling direction.
What exact formula to use is something I leave up to whoever can provide
a viable solution.
To give you a rouhg idea at what I'm aiming for, you might try the Phong
model:
    f(L,V) = k (Lm . V) ^n
where Lm is L mirrored at the surface normal.
> Also,
What I mean by that is that I want to know the probability density
function of the sample directions.
Something along those lines, yes. But I need to weigh the individual
samples by the probability density function of the sample direction
generator (or, more precisely, by the reciprocal thereof).
Date: 2 Sep 2016 02:39:06
Message: <57c91e8a@news.povray.org>
...or a BRDF created by interpolating real-life measurement data :-)
Date: 2 Sep 2016 03:38:48
Message: <57c92c88$1@news.povray.org>
Am 02.09.2016 um 08:39 schrieb scott:
>>> for the
>>> themselves, then
>> POV-Ray.
> ....or a BRDF created by interpolating real-life measurement data :-)
Or that, yes.
(And would that then be a naive interpolation of a data array, or maybe
a spherical harmonics-based approximation?)
Date: 2 Sep 2016 07:40:00
Message: <web.57c963eb8629941b5e7df57c0@news.povray.org>
Well, for now, you can - if there were a set of equations for the BRDF's that
could be easily plotted over the range 0-1 or 0-pi, then the shape might inspire
an equation to mimic them.   Presumably you already have a few such equations
working with POV-Ray, and some of the special development versions.
I've thought about this a bit and will have some more to say and ask, but for
now:
Is there a way to take the models available and fit a curve to them?
Polynomials, or Taylor series, or something like that?
And now I'm off to work.
