I have the following bit of code:
union
#for (i, 1, Trees_Number)
#local Trees_Object = union
PlantPatch()
scale 1/64
Populate_Triangle(Trees_Object, 1, Seed, Flip)
The result of the PlantPatch() and Populate_Triangle() macros are
additional unions. However, I get the error, "No matching } in 'union',
union found instead". Is there something wrong with the scene? I thought
unions could contain other unions. Thanks.
Mike
Am 19.02.2016 um 03:51 schrieb Mike Horvath:
> union
> PlantPatch()
> scale 1/64
> #end
You might want to have a closer look at the macros.
> union
> PlantPatch()
> scale 1/64
> #end
Change PlantPatch to an intersection and Populate_Triangle to a difference.
The object will be broken but it will parse, and that might lead you to
which is your offending macro. One of those has an extra }
>> union
>> PlantPatch()
>> scale 1/64
>> #end
Excuse me, but changing an union to an intersection or difference?
There is no way that can give the same result, ever. It will also render
MUCH slower.
My guess is that one of those macros produce an union that may be
missing it's closing brace.
> MUCH slower.
No, the point is not to render it, it's just to parse it to figure which
of the 3 nested unions is missing the }. If one changes a union to a
difference, maybe it says "missing } in difference" and buys one a clue
to where the problem is.
dik
>> MUCH slower.
> dik
I changed this:
PlantPatch()
scale 1/64
to this:
#local Trees_Object = object
PlantPatch()
scale 1/64
Now it works. Thanks guys!
Mike
