I'm trying to write a script that gets its objects from arrays. However,
some of these arrays are empty, and cause parsing to stop. Why are zero
length arrays not allowed? This is not true of most of the programming
languages I am familiar with, and means I have to write a lot of extra
code to handle this situation.
Mike
Am 05.02.2016 um 02:56 schrieb Mike Horvath:
Because.
In C# (which I mostly use) if there is any chance there will be zero
elements then I normally use a List rather than an array. I believe
there is something similar in C++, and probably in other languages too.
If I have an array that may be of size 0, then I just don't define it
and later check for #ifdef when I want to use it.
This means I will have to rewrite Chris Colefax's CityGen, since he uses
arrays to store lots of stuff. :(
Why? This seems perfectly legal in C#:
double[] x = new double[0];
Console.WriteLine(x.Length); // 0
Then why does CityGen work in its original state? Or so I remember from
the past...
