POV-Ray : Newsgroups : povray.advanced-users : Intersection of town and floor? Server Time
10 Nov 2025 19:14:30 EST (-0500)
  Intersection of town and floor? (Message 1 to 7 of 7)
Subject: Intersection of town and floor?
Date: 12 Aug 2015 23:39:01
Message: <55cc1155$1@news.povray.org>
I have a model of a town I made in LDraw. How do I make it so the floor
(a checkered plane) only exists where the town doesn't exist along the
x+z plane? The reason I can't just use a plane is that parts of the town
(such as the road surface) are slightly beneath the plane, and a plane
would hide these areas. What should I do?
Thanks!
Mike
Subject: Re: Intersection of town and floor?
Date: 13 Aug 2015 02:03:15
Message: <55cc3323@news.povray.org>
> Thanks!
> Mike
Academic answer: use CSG difference on your floor.
Academic problem: twice the memory is used for the town, and render time
is slowed. (and town must have an interior, and under-floor road should
extend their interior toward the sky... maybe doubling the path of roads
with an invisible container... at least for the troublesome sections
below the ground)
#declare Town = ...
#declare Floor = ...
object { Town }
difference { Floor Town }
Date: 13 Aug 2015 03:09:32
Message: <55cc42ac$1@news.povray.org>
> below the ground)
> #declare Town = ...
> object { Town }
This would slow things down too much. Too bad I can't just difference
the objects' bounding boxes.
Mike
Date: 13 Aug 2015 22:15:01
Message: <web.55cd4ebfa62186ce5e7df57c0@news.povray.org>
> Mike
Um, can you pre-make some sort of town with a mesh object, and then use that for
the CSG difference?  Or just a slice of the town encompassing the height where
the road will be?
I haven't ever used meshes or stored objects read in from disk, etc...
I may be thinking about this all wrong, or backwards..... or is that "Keyword:
inverse" ?  :D
Date: 13 Aug 2015 22:38:52
Message: <55cd54bc$1@news.povray.org>
>> Mike
> the road will be?
> inverse" ?  :D
I'm looking for a method that I can automate. I don't know how I could
make such a mesh without doing it all by hand.
Mike
Date: 16 Aug 2015 12:57:54
Message: <55d0c112$1@news.povray.org>
> Thanks!
> Mike
If your town is square, use a plane diferienced with a box used as a
standin for the town:
difference{
  plane{y,0}
  box{<-100,0.1,-100><100,-1,100>} //adjust to the dimentions of the town.
  pigment{checkers}
If the town is not square, you can substitute a prism for the box.
Date: 17 Aug 2015 14:38:03
Message: <55d22a0b$1@news.povray.org>
>> Thanks!
>> Mike
> difference{
>   plane{y,0}
>   pigment{checkers}
> Alain
I made some modifications, and the town is now rectangular which makes
things a lot easier. A rectangular box should be sufficient now.
Mike
