Hash: SHA256
Le 10/05/2015 16:11, Thomas de Groot a écrit :
> You may have followed the discussion in p.newusers (can't i rotate
> a pigment?).
> My question here is: is the described issue with the rotation of a
> slope pattern a bug (my initial thought) or is it not?
> Personally, I really don't know.
History, it's all about history.
And overcharging a pattern (there is "<direction vector>" and
"point_at <position vector>" )
In megapov, it was "aoi" pattern (and it was already special too: with
or without a point, the behavior was different)
And to summarise the answer: there is no right answer.
Some might want to reorient the pattern once transformed, and some
might want to keep it as it is; It would need a kind of
"reset_children" option (a warp that appeared in megapov 0.6, now gone)
So far, if you want to rotate the slope pattern, you need to apply the
transformation to the parameters of the slope pattern... but shearing
transformation will never apply as expected (as the value is due to
the normal of the object, so shearing the object also change the normal)
Reorienting the slope direction or point might be easy, but the
control of low & high altitude, as well as low and high slope make
such update very difficult to perform automatically.
Did I say it was an overcharged pattern ? with a direction, the
altitude is another extension of it too!
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlVPfBIACgkQhKAm8mTpkW1L7gQAnBNK5GLuvI8bYOgZ9nP2vBDt
uX7CbywDbrA001nsJ6knEWEF9Ky5ImWnvdX0iDo+twbU1J/g5humoKf8w9yVuFLW
Nps2N9lx3mp//F5ec9udi1urSRUU7vWyRr6mGt+lkXKKuNJ4NqrNcyllDzmUTOXa
+6N4YcoYzYxTooyWkpc=
=+CgP
-----END PGP SIGNATURE-----
