POV-Ray : Newsgroups : povray.advanced-users : Stop rendering using a break statement Server Time
10 Nov 2025 21:03:19 EST (-0500)
  Stop rendering using a break statement (Message 1 to 10 of 13)
Subject: Stop rendering using a break statement
Date: 8 Feb 2015 14:26:02
Message: <54d7b84a$1@news.povray.org>
Is there a easy way to stop rendering based on a condition, sort of like
a break statement in a loop? I know I can wrap my entire scene in a
condition, but I am hoping there is something simpler. Thanks.
Subject: Re: Stop rendering using a break statement
Date: 8 Feb 2015 14:43:26
Message: <54d7bc5e$1@news.povray.org>
The scene is parsed 100% before the render starts. So, no, from the SDL
you cannot control the interruption of the rendering.
On Unix/linux, you can send a signal to the process, and it will catch
it, and stop a few moments after (the front-end thread will stop giving
works to the back-ends' ones... sort of, then collect them all and exit:
if you are rendering at 1pph or less, a few moments can still take a
long time)
I do not know for the window's port. I used to see a "stop" button
somewhere.
Notice that interrupting a render will not, on any platform, provide a
partial picture-file output. NOT.
Date: 8 Feb 2015 15:18:29
Message: <54d7c495$1@news.povray.org>
> long time)
> somewhere.
Stopping the parsing (and thus the render too) is what I meant.
Date: 8 Feb 2015 15:20:32
Message: <54d7c510$1@news.povray.org>
Am 08.02.2015 um 20:26 schrieb Mike Horvath:
POV-Ray is quite a fascinating thing: It provides ways to do plenty
different things, sometimes in more than one fashion.
Therefore, rather than ask about a very specific mechanism, it is often
a more promising approach to ask about the goal you ultimately want to
achieve; the mechanism you have in mind for it might be unavailable, but
there might be other ways around it.
Date: 8 Feb 2015 15:32:10
Message: <54d7c7ca$1@news.povray.org>
One thing I want to do is stop parsing when frame_number equals some
number. I've created an animation with duplicates that I don't need. But
I can think of other instances where this could be handy.
Date: 8 Feb 2015 16:18:38
Message: <54d7d2ae@news.povray.org>
You just want the +EF option ( end-frame, followed by the number of the
frame after which to stop the rendering of the range.)
Look also at SF (start frame) to start after the first one.
Date: 8 Feb 2015 19:31:02
Message: <54d7ffc6$1@news.povray.org>
No. For example I may want frames 1-3 and 5-6 parsed and rendered, but
not frame 4. Your suggestion doesn't work in this case.
Date: 9 Feb 2015 02:18:46
Message: <54d85f56@news.povray.org>
Am 09.02.2015 um 01:31 schrieb Mike Horvath:
So what you're after is not really stopping a render, but skipping
individual frames in it.
No, at the moment I can't think of any mechanism by which POV-Ray might
support this (other than rendering only subsets of the animation in the
first place). The "#error" directive came to my mind, but it does not
only abort parsing of the current frame, but also the entire render job.
Date: 9 Feb 2015 03:14:25
Message: <54d86c61$1@news.povray.org>
Do you not want frame 4 rendered to save time, or because you physically
don't want the file to be created?
If you want to save time, but don't mind the file being there, then just
let it render an empty scene with no objects for the frames you don't
want, it will only add a fraction of a second.
It should be easy if you could render another .pov file, and put
something like this in it:
#if(frame_number<>4) // or whatever condition
  #include "mainPOVscene.pov"
Date: 9 Feb 2015 03:23:43
Message: <54d86e8f$1@news.povray.org>
If frame 4 has already a output file, I wonder if the -C (or is it +C ?
I know they are opposite of each other, but cannot remember which one
would try to look if the output image already exist and is complete)
option would not skip the render of it when detecting that it is already
complete ?
Just because nobody complains does not mean all parachutes are perfect.
