POV-Ray : Newsgroups : povray.advanced-users : width of a ttf object Server Time
10 Nov 2025 21:03:18 EST (-0500)
  width of a ttf object (Message 1 to 4 of 4)
Subject: width of a ttf object
Date: 22 Jan 2014 18:43:52
Message: <52e057b8$1@news.povray.org>
I have a scene concept involving centred text, and I want to try it with
many different fonts (using a Python program to write the .pov files).
Is there a way to center text without measuring its width by eye, every
time?  Perhaps a function that returns the dimensions of a bounding box?
*\\* Anton Sherwood *\\* www.bendwavy.org
Subject: Re: width of a ttf object
Date: 22 Jan 2014 19:25:48
Message: <52e0618c$1@news.povray.org>
Am 23.01.2014 00:43, schrieb Anton Sherwood:
Not exactly, but the functions min_extent(MyObj) and max_extent(MyObj)
do indeed return the "lowest" and "highest" corner, respectively, of the
bounding box, so the following line should do the job:
#local Width = (max_extent(MyTextObj)-min_extent(MyTextObj)).x;
Date: 22 Jan 2014 22:50:58
Message: <52e091a2$1@news.povray.org>
Thank you, that works perfectly.
Date: 23 Jan 2014 19:25:23
Message: <52e1b2f3$1@news.povray.org>
Note you can also just write out an array of font names you want to
try and setup a pov script to render all images as an animation. Might
be more convenient, especially when changing the pov code later.
