POV-Ray : Newsgroups : povray.advanced-users : Quadtrees/Octrees: Possible with POV's SDL? Server Time
11 Nov 2025 00:43:25 EST (-0500)
  Quadtrees/Octrees: Possible with POV's SDL? (Message 1 to 10 of 18)
Subject: Quadtrees/Octrees: Possible with POV's SDL?
Date: 31 Mar 2011 14:39:15
Message: <4d94ca53$1@news.povray.org>
I'm trying to find an efficient way to test all points within a set
against each other. Quadtrees/octrees seem like the way to go, but... it
appears that I need arrays containing vectors with other arrays mixed
in. POV doesn't allow that sort of thing.
Would something like this work for quad/octrees?
#declare Array =
  array[2]{
   array[1]{
    <0,0,0>
   array[2]{
    array[1]{
     <0,0,0>
    array[1]{
     <0,0,0>
Am I assuming the worst? What would be a good way to structure my data?
Can it even be done in POV? This would be my first foray into using such
data structures, so I'm totally lost here :(
~Sam
Subject: Re: Quadtrees/Octrees: Possible with POV's SDL?
Date: 31 Mar 2011 14:54:19
Message: <4d94cddb@news.povray.org>
  The current SDL isn't expressive enough to easily create such data
structures. The next SDL will have, if it ever comes to be, but until
them you'll just have to use arrays or use some scripting/programming
language to generate the scene.
Date: 31 Mar 2011 15:15:47
Message: <4d94d2e3@news.povray.org>
Argh, that's what I was afraid of :(
I'll keep looking into the matter...
Date: 31 Mar 2011 15:26:31
Message: <4d94d567@news.povray.org>
...and thanks for the reply, Warp!
Date: 31 Mar 2011 15:35:00
Message: <web.4d94d6ffdc51ece981c811d20@news.povray.org>
> Hi,
> #declare Array =
>   array[2]{
>    array[1]{
>     <0,0,0>
>    array[2]{
>     array[1]{
>      <0,0,0>
>     array[1]{
>      <0,0,0>
> ~Sam
When you say testing points against each other, what exactly are you trying to
do?  Find equal points?
-tgq
Date: 31 Mar 2011 15:59:12
Message: <4d94dd10$1@news.povray.org>
You might be better off exporting data from another programming
language. Also, how to proceed might depend on whether your main
focus is on non-intersection (where you only need to track close
neighbors) or gravity simulation (where you need to consider
points that are farther away as well. Better than efficient
tests is of course if you can avoid having to test each
point against every other point.
Your scene reminds me a bit of astronomical simulations for
star/galaxy formation and the likes. Their point counts are now
over the 10 billion makr (i.e. 10^10) ;) Typically these use
a hierarchical data structure, i.e. you group points into
clumps of matter and over longer distances only consider
the total attraction between increasingly larger clumps,
ignoring the constituent points.
Date: 31 Mar 2011 16:17:42
Message: <4d94e166$1@news.povray.org>
>> against each other.
Basically I want to find close neighbors. They don't even have to be the
nearest ones for what I'm doing.
One case would involve placing spheres in 3D space without having any
one sphere intersect another. I *could* simply reference all the points
every time a point is added, but the parse time is compounded as new
points are introduced.
In another case I would have a number of points generated from a mesh.
For each point there would be a blob, and each blob would be subtracted
by blob components based on close points.
For the second scenario I might take up Christian Froeschlin's idea of
sorting everything along one direction and then just testing the array
in a padded fashion. That would probably be the easiest implementation,
but for higher-density point sets and blobs with large radii, it might
not be very efficient.
Directional sorting has got to be better than what I'm doing now, though...
Sam
Date: 31 Mar 2011 16:56:17
Message: <4d94ea71@news.povray.org>
>> it appears that I need arrays containing vectors with other arrays
>> mixed in. POV doesn't allow that sort of thing.
Currently all I want to do is find close neighbors. If I export that
data I would probably have one array for the point vectors and another
array as a list of pointers tracking said neighbors. I might even be
able to use one of the Voronoi libraries, depending on how accessible
the data is.
The animation I posted was just an interesting side effect caused by a
small adjustment. If I take it any further, I would keep the attractive
force of each point localized, with a radius slightly larger than the
repulsive force. In this way I could model certain fluids. I would then
only really need to track the close neighbors...
Wow, that sounds very interesting!
Date: 31 Mar 2011 20:20:00
Message: <web.4d95196edc51ece9b05ef170@news.povray.org>
Have a look at this thread from a few years ago
http://news.povray.org/povray.advanced-users/thread/%3C446b33a3@news.povray.org%3E/?ttop=356390&toff=300
-tgq
Date: 31 Mar 2011 20:55:01
Message: <web.4d95222bdc51ece9b05ef170@news.povray.org>
> -tgq
Odd, link doesn;t show up in the web interface.
-tgq
