POV-Ray : Newsgroups : povray.advanced-users : 2D graphical elements Server Time
4 Nov 2026 04:52:16 EST (-0500)
  2D graphical elements (Message 1 to 20 of 20)
Subject: 2D graphical elements
Date: 10 Feb 2011 20:25:08
Message: <4d548ff4$1@news.povray.org>
I think it would be good to have a series of 2D graphical elements to
use to display on-screen elements like text, arrows, guidelines, etc.
for creating diagrams and such. But, it would be kind of complicated
with POV-Ray's existing 3D elements.
Anyone want to help with such a project?
I'm thinking that copying SVG's syntax would be good. Positing them on
the screen would also be difficult.
http://isometricland.com
Subject: Re: 2D graphical elements
Date: 11 Feb 2011 03:58:12
Message: <4d54fa24$1@news.povray.org>
Flyspray #63 get closed because of lack of answer from OP (guess who
opened it ?) (more about SVG in it!)
Have you investigated the screen.inc from the distribution ?
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 11 Feb 2011 08:40:00
Message: <web.4d553b451ecabac281c811d20@news.povray.org>
> around.
> it's free.
The problem with screen.inc or any other method that places an actual object on
the image, is that it falls apart when using focal blur.
It would be nice to have a way of adding 2D elements to the image that can be
done easily, and are not affected by the camera.
-tgq
Date: 11 Feb 2011 09:12:27
Message: <4d5543cb@news.povray.org>
Huh ?
If it is not to be affected by the camera, it will not stand with focal
blur.
Oh! *Some thoughts get into a brain somewhere lost deep in the universe*
if you just want a way to add 2D elements to an image, I would suggest
learning imagemagick script and using the post-render script facility of
povray (does it work yet within 3.7RC3 ?).
Do not ask a 3D renderer to do the job of a 2D picture editor.
around.
it's free.
Date: 11 Feb 2011 09:29:49
Message: <4d5547dd@news.povray.org>
Am 11.02.2011 14:36, schrieb Trevor G Quayle:
There is: Use an SVG tool to convert to rasterized image with alpha
channel, and use an image processing tool to overlay...
(Hit: There do exist such tools for batch processing, so you can
instruct POV-Ray to automatically run those after rendering of each frame.)
Remember that POV-Ray is not a swiss army knife for image generation -
it's a 3D renderer.
Date: 11 Feb 2011 10:40:01
Message: <web.4d55577b1ecabac281c811d20@news.povray.org>
> Huh ?
> blur.
I wouldn't really ask it to do much, but something I would use it for is
labelling images when I'm running test renders.  Simetimes I do this in batches
and would like paramters used printed directly on the image for reference.  I
know there are other ways to do it, and it can be faked in POV with certain
restrictions.
EG, in these images
(http://news.povray.org/povray.binaries.images/attachment/%3Cweb.4d52afc268e3dc0b81c811d20%40news.povray.org%3E/envmape
x.png)
I used POV to print the note on the bottom for ease (I know I could do it in an
external program).  I can live without it, but it's just something nice to have
available.
As an aside, megaPOV had a "camera_view" pigment, where you can the pigment is a
POV camera.   I used this to make cross-stereo images in one shot: Use an
orthographic camera on a box and texture each half of the box with a slightly
different camera perspective on the actual scene (just had to make sure my box
didn't impede in the scene.  This was also able to be used to do 2D labelling by
reverse: orthographic camera on a box textured with camera pigment, with any 2D
text layered over.
-tgq
Date: 11 Feb 2011 16:11:53
Message: <4d55a619$1@news.povray.org>
If you want to do this without external tools, you can
separate 2d postprocessing from the actual image rendering
using render 2 passes.
Date: 12 Feb 2011 01:55:01
Message: <web.4d562e9f1ecabac2edd3f3390@news.povray.org>
> Huh ?
> blur.
> around.
> it's free.
The problem with third party tools is that if you are sharing your files you
have to show the users how to set up and use them.
Also, if you make modifications to the original scene, then you have to update
all your 2D images to match it. And you have to do that each time.
Major pain in the a**, IMO.
Date: 12 Feb 2011 02:00:06
Message: <web.4d562f101ecabac2edd3f3390@news.povray.org>
> -tgq
I was wondering if the best way were to create geometry (i.e. an intersection of
3D objects with a plane), or to create everything somehow using image maps.
Date: 12 Feb 2011 02:00:10
Message: <web.4d562f3b1ecabac2edd3f3390@news.povray.org>
What the heck does this have to do with Flyspray? I'm not making a feature
request.
Date: 6 Mar 2011 20:30:00
Message: <web.4d7434f01ecabac28693b1390@news.povray.org>
I guess I should have said "in scene" instead of "on screen". I.e. it should be
possible to place the 2D elements *anywhere* in the scene - not just parallel to
the viewing plane.
Date: 6 Mar 2011 23:50:12
Message: <4d746404$1@news.povray.org>
Am 07.03.2011 02:29, schrieb posfan12:
I guess a macro library would be the way to go there. Making the objects
effectively 2D could be achieved by using an almost-zero depth, or
intersecting with a simple 2D shape such as a disk or two triangles
arranged as a square or something.
Date: 7 Mar 2011 00:00:01
Message: <web.4d74663e1ecabac2b05ef170@news.povray.org>
If a true zero depth, 2-D object is desired, then the simplest would probably be
to make the 3D version and intersect it with a 2D box (box with one dimension
zero)
-tgq
Date: 7 Mar 2011 13:12:14
Message: <4d751ffe@news.povray.org>
> zero)
> -tgq
There IS a zero depth object already available beside the triangle. It's
called a polygon.
It can have an arbitrary number of edges, receive any pigment, like an
object pattern for example.
Once created, it can easily be scalled, rotated and mooved around just
like any other object.
No, a disk is NOT a true 2D object. It have a definite interior just
like a plane. That interior does extend lateraly beyong the visible part
and thus will interfere with medias.
Date: 8 Mar 2011 12:41:54
Message: <4d766a62$1@news.povray.org>
Am 07.03.2011 19:12, schrieb Alain:
Didn't know that. Yuck.
Date: 8 Mar 2011 14:22:15
Message: <4d7681e7$1@news.povray.org>
Le 08/03/2011 18:41, clipka nous fit lire :
It's a "bug" from the very first days of povray.
Probably a copy-paste of code at that time.
Date: 11 Mar 2011 22:45:01
Message: <web.4d7aeb3a1ecabac28693b1390@news.povray.org>
What are good candidate 3D objects? They should be smooth and also render fast.
9.2 The ‘rect’ element
9.3 The ‘circle’ element
9.4 The ‘ellipse’ element
9.5 The ‘line’ element
9.6 The ‘polyline’ element
9.7 The ‘polygon’ element
From the W3C:
http://www.w3.org/TR/SVG/shapes.html
Plus the 'path' element, which can be any of:
+ straight lines
+ two types of Bezier curves
+ circular and elliptic arcs
-Mike
Date: 12 Mar 2011 05:17:29
Message: <4d7b4839$1@news.povray.org>
Le 12/03/2011 04:40, posfan12 nous fit lire :
Already seen in FS#63
    * Rectangles can have rounded corners
    * Polygons have last point connected to first
circle = disc
ellipse = disc + scale
polygon = polygon !
rect = flat box, but rounded corners would be a bonus
line = flat box + rotate, but need a pen size!
polyline = sequence of flat box & connecting disc, also need a pen size
> From the W3C:
> + straight lines
Spline! (and it will suck for circular & elliptic arcs)
and you will need a text processing to load the fonts, split each letter
apart and put them along the spline.
Date: 12 Mar 2011 15:20:22
Message: <4d7bd586@news.povray.org>
2 options: 4 sided polygon or very thin box.
The polygon can easily give you a trapeze, parallelogram, or odd quadrangle.
A disk with hollow
An unevenly scalled disk, also with hollow
A thin and narrow box
Already exists.
>  From the W3C:
Look at the spline.
> + straight lines
> -Mike
Date: 13 Mar 2011 09:35:00
Message: <web.4d7cc7481ecabac22e148fbc0@news.povray.org>
> circle = disc
> polygon = polygon !
1. I'm not 100% all of these are usable when you take into consideration the
fact that SVG can have separate fill and stroke parameters, several types of
curved and/or boxy "line endings" (can't remember the correct term for
these...), and so on.
2. I've been considering instead using triangle meshes for everything, possibly
using one of the various parametric object approximation macros/tools people
have created over the years. It would make things a lot simpler since you could
just plug in the formulas and have the macros/tools take care of the rest. (In
fact, I think most software that renders SVG in real-time tends to operate in a
manner more similar to this technique.) Of course, the visual quality might be
inferior in several instances, but it is possible in most cases to tweak the
fidelity/granularity with which the objects and formulas are approximated and
replaced by meshes.
Some food for thought.
-Mike
