POV-Ray : Newsgroups : povray.advanced-users : Divide by zero Server Time
27 Jul 2026 14:49:14 EDT (-0400)
  Divide by zero (Message 1 to 10 of 10)
Subject: Divide by zero
Date: 19 Jul 2010 13:44:35
Message: <4c448f03@news.povray.org>
Hello,
In one of my macros, I'm finding the slope of a 2D line, and sometimes I
get that warning about dividing by zero. Since it seems that diving any
number by zero results in an infinite number, would something like this
be a good fix?
#if(A.x-B.x != 0)
  #local m1 = (A.y-B.y)/(A.x-B.x);
#else
  #local m1 = 1e10;
It seems to get rid of the warnings, but I wonder if there's a better way.
This poor hack was (understandably) giving me artifacts:
(A.x-B.x+0.000001)
I guess the other option is to jitter my points slightly, but that would
introduce problems into the whole setup, and total infallibility would
still not be ensured.
Sam
Subject: Re: Divide by zero
Date: 19 Jul 2010 14:04:01
Message: <4c449391$1@news.povray.org>
Le 19/07/2010 19:44, stbenge nous fit lire :
> Hello,
> be a good fix?
> #if(A.x-B.x != 0)
> #else
>  #local m1 = 1e10;
> #end
> (A.x-B.x+0.000001)
Why do you need the sloperate of your 2D line ?
why not computing the angle of the slope instead, using atan2 ?
With the angle instead of the slope, no more issue with vertical line.
(atan2() result would be in radian, just in case you would be wondering)
Date: 19 Jul 2010 14:19:13
Message: <4c449721@news.povray.org>
It's for a 2D line intersection macro, and the way I learned how to
perform that makes use of classic Coordinate Geometry.
Date: 19 Jul 2010 16:51:14
Message: <4c44bac2@news.povray.org>
stbenge wrote:
> (A.x-B.x+0.000001)
That fails when A.x is a tiny bit larger than B.x :-)
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Date: 19 Jul 2010 17:55:01
Message: <web.4c44c8d58188d4686d1d5f70@news.povray.org>
You should use 2D vectors rather than slopes. That way "infinite slope" is just
the vector <0,1> which can be used in calculations without problems.
Date: 20 Jul 2010 00:24:37
Message: <4c452505@news.povray.org>
Darren New wrote:
> stbenge wrote:
>> (A.x-B.x+0.000001)
Yeah, it was a horrible fix. I thought I might run into problems because
of it. Setting the slope to 1e10 seems to be working just fine, so
unless I discover more inconsistencies, I'll keep it that way for now.
Date: 20 Jul 2010 00:36:23
Message: <4c4527c7@news.povray.org>
It's probably easier than I think, but I was rushing to get to the good
part and just plugged in a formula:
#macro LineIntersect2D(A,B,C,D)
  #local m2 = (C.y-D.y)/(C.x-D.x);
  #local b1 = A.y - m1*A.x;
  #local b2 = C.y - m2*C.x;
  #local slope_intercept_x = (b2-b1)/(m1-m2);
  #local slope_intercept_y = m1*slope_intercept_x + b1;
  <slope_intercept_x, slope_intercept_y>
That's minus the #if statements I put in there as a patch. I'm sure
there's a much simpler solution, but my momentum has been sending me
toward farther goals, so I haven't worked it out yet.
Date: 20 Jul 2010 03:30:01
Message: <web.4c4550108188d4686d1d5f70@news.povray.org>
There you go. Not really simpler but it wont give you divide by zero errors.
  #local det = (D.y-C.y)*(B.x-A.x)-(D.x-C.x)*(B.y-A.y);
  #local c = (D.x-C.x)*(A.y-C.y)-(D.y-C.y)*(A.x-C.x);
  #if(det != 0)
    #local slope_intercept_x = A.x+c/det*(B.x-A.x);
    #local slope_intercept_y = A.y+c/det*(B.y-A.y);
  #else
    #if(c != 0)
      //handle parallel case
    #else
      //handle coincident case
> #end
Date: 20 Jul 2010 17:22:09
Message: <4c461381@news.povray.org>
>   #if(det != 0)
>   #else
>     #if(c != 0)
>     #else
>     #end
>   #end
> #end
Thanks! I'll test it out. For the parallel and coincident cases, I
suppose just returning <0,0> would suffice?
Date: 21 Jul 2010 02:15:01
Message: <web.4c468fb78188d4681095fea60@news.povray.org>
> >   #if(det != 0)
> >   #else
> >     #if(c != 0)
> >     #else
> >     #end
> >   #end
> > #end
Depends on what you want to use the macro for. In the coincident case every
point is a intersection point so you could for example return <A.x,A.y>. In the
parallel case there is no intersection point at all. Returning <0,0> in that
case isn't a very good idea though, as an intersection could actually happen at
<0,0>.
You could return <slope_intercept_x, slope_intercept_y,0> in case of an
intersection and <0,0,1> in the parallel case and then check against the third
return value.
