POV-Ray : Newsgroups : povray.advanced-users : A bunch of feature requests! Server Time
18 Oct 2026 01:56:23 EDT (-0400)
  A bunch of feature requests! (Message 1 to 50 of 69)
Goto Latest 50 Messages Next 19 Messages >>>
Subject: A bunch of feature requests!
Date: 19 Jun 2010 19:29:09
Message: <4c1d52c5$1@news.povray.org>
If you search for tasks by SharkD at the bug tracker you'll see a bunch
of feature request I've made.
http://bugs.povray.org/
Here's a list if you don't want to do the search:
Master scene unit system variable
Set and get font metrics
Add "POV-Ray" metatags to images
Table of Contents in each page of the docs
More library paths, wildcards
Option to render pixels randomly, or in Nth pixel
#ELSEIF statement
variable number of parameters in macros
System variable to track whether a file has been included
Explicit #RETURN statement inside macros
Expandable arrays
Mixed-type arrays
Hash arrays
Ability to change the order of editor tabs by dragging them
Native support for mesh-based surface approximations
Subdivision support
INI option to overlay render information on output image
Right-click menu when clicking on editor tab
String concatenation operator
atand function
"Rename" option in File menu
I'd like to see some thoughts/comments on these requests.
http://isometricland.com
Subject: Re: A bunch of feature requests!
Date: 19 Jun 2010 19:43:18
Message: <4c1d5616$1@news.povray.org>
Here's two more:
"Delete" option in File menu - for deleting (and closing) the current file
"Reload" option in File menu - for reloading the current file from disk,
discarding any changes since the last save
Date: 19 Jun 2010 20:42:34
Message: <4c1d63fa@news.povray.org>
Seconded.
> Expandable arrays
As in dynamic? Oh yeah, that would be nice.
Would it be like an isosurface object?
> Subdivision support
This is /soooo/ needed it's ridiculous.
You left out camera pigment, projection pigment, explicit image filename
output for animations (for stuff like CA), last image buffer access... I
guess I should make a few requests of my own. If I could patch POV-Ray
myself, I would!
Date: 19 Jun 2010 21:11:48
Message: <4c1d6ad4@news.povray.org>
> SharkD wrote:
> Subdivision support
There was a great unofficial version... POV-Sub... which did this. As I
recall, it was very fast. I would still be using it today, but 3.7b does
more, and runs on more cores. One cool thing about that particular
enhancement was that you could perform smoothing on any custom mesh
without having to puzzle out what normal vector a particular point
needed. It did this even without actually needing to subdivide a mesh.
http://www.cise.ufl.edu/~xwu/Pov-Sub/
Date: 19 Jun 2010 22:51:51
Message: <4c1d8247$1@news.povray.org>
c> Table of Contents in each page of the docs
> #ELSEIF statement
a> variable number of parameters in macros
> Expandable arrays
> Mixed-type arrays
> Hash arrays
b> Ability to change the order of editor tabs by dragging them
> Subdivision support
> atand function
b> "Rename" option in File menu
a) You can pass include files as strings and then check #isdef for
variables you want to be optional.
b) I second them
c) How about a link to the TOC instead?
Date: 20 Jun 2010 03:34:58
Message: <4c1dc4a2$1@news.povray.org>
"SharkD" <pos### [at] gmailcom> schreef in bericht
news:4c1d52c5$1@news.povray.org...
***> More library paths, wildcards
> #ELSEIF statement
***> variable number of parameters in macros
***> System variable to track whether a file has been included
***> Explicit #RETURN statement inside macros
> Expandable arrays
> Mixed-type arrays
> Hash arrays
***> Ability to change the order of editor tabs by dragging them
***> Subdivision support
***> Right-click menu when clicking on editor tab
> atand function
***> "Rename" option in File menu
I suppose I second this list although I am not sure what all requests can
do. I certainly would like more library paths or the possibility to use
wildcards there, for instance. I put *** by those I particularly like.
Date: 20 Jun 2010 04:54:47
Message: <4c1dd757@news.povray.org>
This feature was already discussed before - and rejected. POV-ray is a
unit-less system by design.
You cannot set them because there is nothing to set in a finished font. You
can only set font metrics in a font editor. If you want to apply effects to
text objects, you can transform individual characters with a macro. Getting
the essential font metrics is already possible with clever use of the
min_extent and max_extent functions.
Already there, supplied by the system in Windows help docs (given you report
for Windows). You can also use the PDF docs, which have this, as do the Mac
help docs.
There was information missing in your feature request. Please add it there.
You are misunderstanding that macros are not functions. There is no such
thing as a return from a macro.
> Mixed-type arrays
Already possible.
This is Windows only, I suppose.
You can already do this with a macro. Native support would have no benefit -
the probable assumption that a high quality mesh would be faster to generate
and then render compared to a native object (i.e. an isosurface) is incorrect.
On Windows, I guess?
> atand function
This is the degree based version of atan. Use the radians and degrees functions.
	Thorsten
Date: 20 Jun 2010 04:57:00
Message: <4c1dd7dc$1@news.povray.org>
> Thomas
About half the requests got bulk-closed by Thorsten Fröhlich, so alas
there is no way of bringing your opinions to anyone's attention (at
least "officially").
Date: 20 Jun 2010 05:14:48
Message: <4c1ddc08@news.povray.org>
> You can only set font metrics in a font editor. If you want to apply
> effects to text objects, you can transform individual characters with a
> macro. Getting the essential font metrics is already possible with
> clever use of the min_extent and max_extent functions.
"Clever use" means tedious work that gets repeated by users over and
over and over again. If it's so good then the devs can be "clever"
enough to add the feature.
As for setting/overriding metrics, even an HTML coder can override
things like x height using things like font-size-adjust and font-stretch.
> report for Windows). You can also use the PDF docs, which have this, as
> do the Mac help docs.
I was talking about sub-topics within extremely long pages. No, the
Windows help docs can't help you there as they don't track what topic
you're reading at any given moment.
What information?
OK, I see now that a return statement wouldn't work in a macro. A macro
can return an arbitrary block of code that could be completely unstructured.
>> Mixed-type arrays
> Already possible.
Really? You mean the following will work?
#local new_array = array[3]
	"foo", bar(), 20
Why is that? Are Linux users too primitive to benefit from this feature?
> benefit - the probable assumption that a high quality mesh would be
> faster to generate and then render compared to a native object (i.e. an
Pray tell me then why people have taken the time to write these complex
macros if there is no benefit? Just this week I've been told at least a
half a dozen times that my scenes would render faster if I replaced my
objects with meshes.
Guess why?
>> atand function
> functions.
There are already sind, tand, cosd, tan2d, etc. Why not also tand? Too
conspicuous for you?
Date: 20 Jun 2010 05:25:16
Message: <4c1dde7c@news.povray.org>
The requests were not "bulk-closed". There is an explanation for each and
every one of them. Several of the features you requested are outside the
scope of POV-Ray as a renderer, such as editing fonts, others were
misconceptions about macros, and yet others were requests for already
existing features, like being able to pass degrees to atan. And yet another
request was a duplicate of an existing feature request.
Also, please note that you previously made feature requests, but when
prompted for what you actually wanted with them, remained silent, such as
for feature request #63. It may seem tempting to create one line ideas, but
what that really shows is that you have never actually thought about the
usefulness of the idea.
A bit more is required than a single sentence or very short paragraph if you
want to start any sort of discussion beyond "I like this" or "I don't like
that". The point of such discussion is that sometimes it will reveal that
the person who made the suggestion had a misconception about how a feature
works, or that there might even be a trivial existing solution. Your atand
feature request would be such an example where you could have profited from
a discussion before suggesting the feature that already exists by means of
the radians function, and can be extremely quickly added for convenience,
should you really desire it:
#declare atand = function(a) { atan(radians(a)) }
	Thorsten
Date: 20 Jun 2010 05:36:13
Message: <4c1de10d$1@news.povray.org>
Le 20/06/2010 11:14, SharkD nous fit lire :
> unstructured.
BS: a macro does *NOT* return, it get expanded.
It can be expanded to any thing.
If you think of macro as functions, you are deceiving yourself and
preparing for more problems.
Hello.... anybody inside ? There is no Linux front-end.
(But povclipse is a nice module for eclipse & povray)
The problem is that you have to take into account the time to generate
the mesh itself (otherwise it would be cheating)... or work like other
renderers: with mesh file (already generated) only.
Mesh is a cheap inaccurate solution when you can have an exact
mathematical shape instead. They have their interest, but are not panacea.
When all you have is a hammer, everything looks like a nail.
That's what happens within other renderer: all they support is a
triangle, so only meshes are available.
(even Nurbs get transformed into collection of triangles)
Date: 20 Jun 2010 05:45:00
Message: <4c1de31c$1@news.povray.org>
Well, I would be all for someone contributing a set of macros for the
POV-Ray 3.7 include file collection to avoid any repetition.
Yes, it is called "scale" in POV-Ray ;-)
Hmm, I am not sure how a table of contents at the top of such a page (as you
suggested) would help you keep track of where you are on that page. I know
that PDF table of content views get updated as you move through the
document, but I am not aware of any HTML feature (sans JavaScript) that
could do this interactively.
>> there.
> What information?
Please refer to the bug report. What is needed is the version of POV-ray you
are using, and the error message displayed. The background here is (as
explained in the comment for that feature request) that the code does not
have a limit of 20 paths internally, so the problem must be coming from some
platform specific code that has not been updated. - It is correct that there
was such a limit in 3.6, but you reported the problem against 3.7 beta where
it should be exist. That is also my I changed the "feature request" to
"possible bug".
> unstructured.
Yes.
>>> Mixed-type arrays
>> Already possible.
> "foo", bar(), 20
No, this syntax will not work. I actually just noticed that i added the
explanation to report 127 (rather than 128). Among other things, you can do
things like this:
#declare foo = array[2];
#declare foo[0] = array[2];
#declare foo[1] = array[7];
#declare foo[0][0] = 2;
#declare foo[1][6] = sphere{1,1}
Reformatting this syntax to something close to what you are looking for is
possible. You might want to open another thread here for such a discussion,
or discuss it here.
Yes, they are! They have no editor supplied by POV-Ray!
By whom, and where?
>>> atand function
>> functions.
Well, I see now. You really need to write more than "There already exist
atan, atan2 and atan2d functions, why not atand?" as a feature request. Both
"atan" and "atan2" are built in functions. "atand" is not. Now that you
mentioned the other ones, I had a chance to notice that these functions are
indeed defined - in "math.inc". That would have been the minimum additional
necessary information needed to figure out what you were up to. Now I know,
and indeed have simply added it. So in the next beta you should find a
#declare atand = function (x) {degrees(atan(x))}
in "math.inc".
	Thorsten
Date: 20 Jun 2010 05:48:19
Message: <4c1de3e3$1@news.povray.org>
> and every one of them. Several of the features you requested are outside
> the scope of POV-Ray as a renderer, such as editing fonts, others were
> another request was a duplicate of an existing feature request.
Sorry, I though more than the 8 of my requests got closed. As for the
items one by one:
As for font metrics, the request was for getting /and/ setting the values.
The request was for a native "atan" function. Since the function doesn't
exist, I can't see how it's an "existing feature".
There was no duplicate request. One request was for metadata inside the
image metatag parameters. The other request was for scene data overlaid
on top of the image.
> as for feature request #63. It may seem tempting to create one line
> ideas, but what that really shows is that you have never actually
> thought about the usefulness of the idea.
That's the only request anyone "prompted" me about as far as I can see.
Judging by the other replies people seem to have understood the request
properly.
> you want to start any sort of discussion beyond "I like this" or "I
> don't like that".
I'm willing to discuss things, but if no one replies other than one-line
closing message there's not much I can do.
Date: 20 Jun 2010 06:07:45
Message: <4c1de871$1@news.povray.org>
> items one by one:
Yes, but as was explained there by Christoph Lipka and me, you cannot set
them in POV-Ray because they are part of the font. What you can do though is
use a macro for both getting them and modifying a text object accordingly.
That is pretty much how they are displayed by other programs as well. I.e.
to change the spacing between characters, in POV-Ray you write a macro that
takes a string and then creates text objects for each character (internally
a POV text object is nothing else but a collection of character objects)
with a different spacing.
Because you confused functions declared in "math.inc" with built-in
functions. Your feature request simply suffered from a lack of detail and
confusion of functionality built-in functions vs ones declared in math.inc).
There is a native "atan" function. What is - well, was - not there is a
"atand" function returning degrees. That, similar to asind and acosd needs
to be added to "math.inc".
So at a minimum, your feature request should have read "There are already
asind, acosd, atan2d in 'math.inc'. Please add the function 'atand' to
'math.inc' as well." rather than the rather aggressive question with
multiple factual errors "There already exist atan, atan2 and atan2d
You also need to follow the comments/discussion of the feature requests.
> properly.
Well, still Christoph Lipka had to close it because you never said so. The
logical assumption here then is that given Grimbert Jérôme (Le Forgeron)
provided a solution with existing SDL that the issue was resolved.
>> don't like that".
Well, you need to supply more than a one-line feature request then! To get
more than one-line response to a one-line request would require
mind-reading, as people would have to guess what ideas are hiding behind
your request. Usually such speculation leads nowhere, hence it isn't done.
     Thorsten
Date: 20 Jun 2010 06:18:32
Message: <4c1deaf8$1@news.povray.org>
Sure. And until then there's no reason for its removal from bugtracker.
See:
http://webdesignernotebook.com/css/the-little-known-font-size-adjust-css3-property/
Scaling based on x height is not as easy as scaling based on font
height. It requires knowledge of said font metrics.
> you suggested) would help you keep track of where you are on that page.
> I know that PDF table of content views get updated as you move through
> the document, but I am not aware of any HTML feature (sans JavaScript)
> that could do this interactively.
Sure it would help. All I would have to do is press the Home key to go
to the top of the page and then click on the sub-heading link. Same as
if I were visiting Wikipedia or something.
> you are using, and the error message displayed. The background here is
> (as explained in the comment for that feature request) that the code
> does not have a limit of 20 paths internally, so the problem must be
> coming from some platform specific code that has not been updated. - It
> is correct that there was such a limit in 3.6, but you reported the
> problem against 3.7 beta where it should be exist. That is also my I
> changed the "feature request" to "possible bug".
In this case I went by the docs alone and didn't think to test the
behavior in the beta first. Sorry.
> do things like this:
Very, very ugly. The char count of the above code jumped from 45 chars
to 135 chars. And, there's now an introduced chance of an undetected
error occurring if one were to type/change the indices incorrectly that
povray would never report.
Didn't realize this, sorry.
I originally meant this to be for the simple native CSG objects only,
not for complex CSG combinations. I.e. spheres, cones and cylinders, as
well as isosurfaces and parametric objects. Not for intersections or
other CSG combinations. Basically equivalent to what Moray is capable of
doing.
> By whom, and where?
"Shape help" in p.g
"Chris Colefax's Object Bender -- SLOW!!!" in p.a-u
"Spinner" space colony (2)" in p.b.i
> Both "atan" and "atan2" are built in functions. "atand" is not. Now that
> you mentioned the other ones, I had a chance to notice that these
> functions are indeed defined - in "math.inc". That would have been the
> minimum additional necessary information needed to figure out what you
> were up to. Now I know, and indeed have simply added it. So in the next
> in "math.inc".
Yeah, sorry, I didn't see that it was in "math.inc" either.
Date: 20 Jun 2010 06:33:55
Message: <4c1dee93$1@news.povray.org>
>> values.
> set them in POV-Ray because they are part of the font. What you can do
> though is use a macro for both getting them and modifying a text object
> accordingly. That is pretty much how they are displayed by other
> programs as well. I.e. to change the spacing between characters, in
> POV-Ray you write a macro that takes a string and then creates text
> objects for each character (internally a POV text object is nothing else
> but a collection of character objects) with a different spacing.
Let's discuss this on bugtracker instead. That is the "proper" place is
it not?
> and confusion of functionality built-in functions vs ones declared in
> math.inc). There is a native "atan" function. What is - well, was - not
> there is a "atand" function returning degrees. That, similar to asind
> and acosd needs to be added to "math.inc".
...and this conclusion could as well have been reached via discussion on
bugtracker instead of here _if_ the topic had remained _open_ instead of
closed.
What is that supposed to mean? Is it preferable to discuss multiple
requests in a single entry? Usually people want a separate report for
each item.
>> properly.
> The logical assumption here then is that given Grimbert J�r�me (Le
> Forgeron) provided a solution with existing SDL that the issue was
> resolved.
Grimbert was not suggesting a solution using SDL, he was suggesting a
/course of action/ on how the feature should be implemented by devs!
> get more than one-line response to a one-line request would require
I assume people are going to ask if they don't understand something or
request further comment. And I presume people are going to state their
conclusions based on a request _prior_ to closing it so that people can
solicit further comment. There's a "comment" button next to each task,
after all, near the "close" button maybe.
Date: 20 Jun 2010 07:10:14
Message: <4c1df716$1@news.povray.org>
Its not removed. It is closed. All closed bugs are still visible.
The link is about aspect ratios when substituting fonts. In effect what is
describes is just a clever algorithm to scale characters in one font such
that they take about as much space as another font. You can do the same with
min_extent and max_extent in POV-Ray, and then scale another font accordingly.
It is just an example I had at hand.
> doing.
Someone suggested meshes instead of CSG? That is not very sensible at all.
To speed up CSG obejcts, you should use manual bounding.
>> By whom, and where?
> "Shape help" in p.g
The object binder macro (I saw that thread, no time to read the others) is a
rather complex solution to modifying objects in ways that are not really
possible without, well, changing their mathematical representation. A mesh
is a workaround for such an object to be modified within POV in a way that
you would normally modify it in a 3D modeler. Those models usually work with
meshes and hence make the modifications possible because the triangle meshes
have certain properties that make non-linear transformation mathematically
"easy". So the suggestion in that thread more or less is to use a modeler.
Using the object bender macros on a mesh in POV-Ray would not make it any
faster.
     Thorsten
Date: 20 Jun 2010 07:21:59
Message: <4c1df9d7@news.povray.org>
> closed.
A feature request should be complete in and by itself. A single line is not
complete.
> each item.
No, it is not a suggestion to suggest multiple features in one report, but
if a feature request has resulted in the very same discussion already, no
summary or conclusion should be made in a new feature request, but instead
the existing one should be changed. This implies contributing ideas to the
feature request discussion, and then coming up with a single coherent idea,
not leaving it at two half-finish ideas.
>> resolved.
No, the solution was purely SDL based because all the features mentioned
were SDL primitives that already exist. He just did not supply the SDL itself.
If you flood the bug reporter with one-line feature requests, you cannot
expect more than one-line responses. Don't expect people to worm all
information out of you. Reports should be as complete and coherent as
possible. This is the minimum courtesy you have to pay to those reading your
ideas: In short, you want others to do something for you that they have no
obligation to do for you. The best way to reach that goal is showing that
you respect their valuable time. You expected the opposite.
	Thorsten
Date: 20 Jun 2010 09:25:00
Message: <web.4c1e15d155d1933dfdff507e0@news.povray.org>
SharkD <pos### [at] gmailcom> wrote:
> Expandable arrays
> Mixed-type arrays
> Hash arrays
This reminds me of the idea of adding support for an external scripting language
in POV4.
> Subdivision support
I like this, but is it natively thread safe? I very much like to see smp POV-Ray
released, and then add more features that need development time to work with
multi-threads.
Stephen S
Date: 20 Jun 2010 10:35:17
Message: <4c1e2725$1@news.povray.org>
Am 20.06.2010 01:29, schrieb SharkD:
I'd like to encourage everyone to have a look there (not only on Shark's
requests of course), and /vote/ on the features you like to see most.
It's easier to track than sifting through newsgroup postings.
Date: 20 Jun 2010 10:40:42
Message: <4c1e286a$1@news.povray.org>
Am 20.06.2010 12:33, schrieb SharkD:
>> resolved.
I don't think so...
Date: 20 Jun 2010 11:03:47
Message: <4c1e2dd3$1@news.povray.org>
Am 20.06.2010 11:14, schrieb SharkD:
You're forgetting that HTML browsers' main job is to display text.
POV-Ray's main job is to render 3D images, which /occasionally/ may
include text. Please understand that POV-Ray can therefore not
double-act as a desktop publishing software.
But I do agree that a proper way to /get/ font metrics is a prerequisite
to implement macros providing higher-level text layout capability.
As for font-size-adjust, this can easily achieved in POV-Ray by relative
scaling; as for font-stretch, this can either be achieved by non-uniform
scaling (e.g. faux condensed or faux expanded), or by choosing the
appropriate font file (condensed or expanded font face, i.e. with
individually designed glyphs).
Well, /POV-Ray for Linux/ is "too primitive" for users to benefit from
the feature, because it doesn't come with a GUI at all.
Date: 20 Jun 2010 11:18:59
Message: <4c1e3163$1@news.povray.org>
Am 20.06.2010 15:21, schrieb StephenS:
>> Subdivision support
> multi-threads.
There's still a difference between rejecting a feature request (which to
me reads, "never going to happen"), and just keeping it unimplemented
for now.
I think at present /all/ feature requests must be expected to be
postponed until SMP POV-Ray (aka 3.7 final release) is out of the door,
and any exception to this is just... well, an exception. So I see no
reason to close feature requests on a "won't implement in 3.7" basis.
Date: 20 Jun 2010 12:22:53
Message: <4c1e405d$1@news.povray.org>
You're mistaken. font-size-adjust tweaks fonts in ways we can't do in
Povray without knowing font metrics - specifically the font's x height.
Date: 20 Jun 2010 12:24:47
Message: <4c1e40cf@news.povray.org>
Visitors will specifically have to search for closed feature requests,
as otherwise they won't see all of them.
Date: 20 Jun 2010 12:26:08
Message: <4c1e4120$1@news.povray.org>
OK, so it can be resolved with a set of macros. Is there any point of
keeping the feature request closed then?
Date: 20 Jun 2010 12:29:49
Message: <4c1e41fd$1@news.povray.org>
> your ideas: In short, you want others to do something for you that they
> have no obligation to do for you. The best way to reach that goal is
> showing that you respect their valuable time. You expected the opposite.
> Thorsten
Look, I made most of my feature requests within the span of a week after
having been *told* to go there under the assumption that there would be
discussion, and you closed them within the span of a day with little or
no discussion. If there was a problem with request descriptions being
too short you could have just said so. And I don't see much evidence
that *other* people besides you had much difficulty understanding them.
Date: 20 Jun 2010 12:36:55
Message: <4c1e43a7$1@news.povray.org>
Am 20.06.2010 18:22, schrieb SharkD:
That's exactly why I did concede that - quote - "a proper way to /get/
font metrics is a prerequisite to implement macros providing
higher-level text layout capability."
And it's also a great example of why the actual layout functionality
doesn't belong inside POV-Ray: Hey, I'm a 3D enthusiast, not a font
expert. All I know is that font-size-adjust uniformly scales the font,
so to me it's essentially a scaling operation, and I don't bother where
the factor comes from.
Leave 3D magic to the 3D geeks & POV-Ray developers, and font magic to
the font geeks & SDL macro programmers.
Date: 20 Jun 2010 12:39:10
Message: <4c1e442e$1@news.povray.org>
Am 20.06.2010 18:24, schrieb SharkD:
... and of course they won't be able to vote on them, yes. Such is life.
Date: 20 Jun 2010 14:20:00
Message: <web.4c1e5b1355d1933d42ae90b20@news.povray.org>
We're not primitive.  We just enjoy using far superior text editors.  Both vim
and emacs kick povray's Windows editor's butt major time, complete with syntax
highligh, generalized textual completion and user code templates.  No point
degrading. :)
I don't think it'd be useful for povray developers to try to duplicate such
functionality either, just give us the glorious backend.
Date: 20 Jun 2010 15:04:35
Message: <4c1e6643@news.povray.org>
> degrading. :)
I made that statement based on the faulty assumption that Linux users
*do* in fact have a dedicated IDE/frontend.
Date: 20 Jun 2010 15:55:00
Message: <web.4c1e717655d1933d42ae90b20@news.povray.org>
> > degrading. :)
I know.  My point is that we don't need a weak frontend. :)
Date: 21 Jun 2010 08:30:12
Message: <4c1f5b54@news.povray.org>
  Given that meshes which approximate the same shape as a complex CSG
composed of other primitves sometimes renders faster than that CSG object,
I don't see how an isosurface would be even faster than that. On the
contrary, an isosurface with the same shape as the complex CSG most probably
would render at least an order of magnitude slower than the original CSG
object.
  Tesselating an isosurface to a mesh would probably be a slow'ish process,
but certainly not slower than rendering the isosurface. Then rendering the
mesh would in most cases be orders of magnitude faster than rendering the
original isosurface (after all, the rendering speed of a mesh is something
like logarithmically related to the amount of triangles, so even really
complex surfaces are going to render quite fast).
  Also there are advantages of tesselation other than faster rendering.
Among others, it would open up possibilities to efficiently simulate
non-linear transformations (applying a non-linear transformation to a CSG
is impossible, and on an isosurface makes the rendering slower, while on a
mesh it has little effect because the amount of triangles stays the same),
uv-mapping and exporting shapes to other formats.
  Of course the *major* problem here is: Which tesselation algorithm to use,
and how to implement it? And who is going to implement it?
  AFAIK the marching triangles algorithm is one of the best in existence
(while the marching cubes algorithm is one of the worst), and it's especially
suited for efficiently tesselating isosurfaces ("efficiently" meaning that it
generates an optimal amount of triangles, creating more on places with high
curvature and less in places with low curvature). It might also be usable
with CSG objects (although there are going to be surprising problems there.)
However, somebody would have to implement it.
Date: 21 Jun 2010 11:12:06
Message: <4c1f8146$1@news.povray.org>
> object.
Not sure where you read isosurfaces are faster than CSG. Oh well :-(
	Thorsten
Date: 21 Jun 2010 12:00:14
Message: <4c1f8c8e@news.povray.org>
> degrading. :)
FWIW, I use vim under Windows to do most of my original POV coding. The POV
editor is nice for tweaks once the basic scene is running, tho. :-)
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 21 Jun 2010 12:01:10
Message: <4c1f8cc6@news.povray.org>
> > object.
  "the probable assumption that a high quality mesh would be faster to
generate and then render compared to a native object (i.e. an isosurface)
is incorrect."
  If you claim that rendering an isosurface is faster than generating a
mesh from it and then rendering it, you are also implying that rendering
an isosurface is faster than rendering a (complex) CSG because there are
cases where meshes are faster to render than CSG. If meshes are faster than
CSG and isosurfaces are faster than meshes, it logically follows that
  I don't really understand what you base your original claim that
isosurfaces are faster to render than generating a mesh and then rendering
the mesh on.
  There may be extreme cases where a really fast isosurface (one which is
extremely simple, ie. has a very low gradient, such as a sphere) is faster
to render than generating a mesh from it and then rendering the mesh because
of the overhead of the tesselation process (after all, the tesselation
algorithm requires some processing itself). However, that probably only
happens in extremely simple cases.
  In more complex cases tesselating the isosurface is more or less akin
to rendering it at low resolution (because usually it's enough to generate
a mesh which has triangles larger than pixels when projected onto the final
image). Also, when tesselating the isosurface probably needs to be solved
once per mesh vertex, while rendering it might be involve solving it several
times per pixel (eg. in self-reflection, refraction and shadowing situations).
If ray-mesh intersections are faster to compute than ray-isosurface
intersections, then in these cases tesselation + mesh rendering ought to
be faster than direct isosurface rendering.
  Even *if* for some reason tesselating the isosurface would be significantly
slower than rendering it, there may still be advantages of doing that because
the resulting mesh can be stored in a file and then read from there in
subsequent renders. Hence even in that case tesselation would be useful.
Date: 21 Jun 2010 13:03:48
Message: <4c1f9b74$2@news.povray.org>
>>> object.
> is incorrect."
A very interesting conjecture. However, I have a real life, so you will have
to discuss your conjecture with someone else.
	Thorsten
Message: <4c1f9b74$3@news.povray.org>
>>> object.
> is incorrect."
	Thorsten
Date: 21 Jun 2010 13:06:45
Message: <4c1f9c25$1@news.povray.org>
Fine. Then there's no reason for it to be _closed_ on bugtracker. Smart guy.
Date: 21 Jun 2010 13:12:45
Message: <4c1f9d8d$1@news.povray.org>
> have to discuss your conjecture with someone else.
> Thorsten
Great. So items on bugtracker will survive based on whether a person has
time in "real life" or, as implied in the other thread, on the attitude
of the person who submitted the item. That sounds EXACTLY like the
intended purpose of a software bug tracking system. In fact, why not
also delete SVN branches because said person mentioned something about
your mother?
Date: 21 Jun 2010 13:16:31
Message: <4c1f9e6f@news.povray.org>
> >>> object.
> > is incorrect."
  I wonder if this will be a permanent pattern from this time forward:
Every time you make a post and I respond to it, you see me attacking you,
regardless of what my intentions truly are and what the topic in question
is, and when I try to explain myself, you invariable resort to some kind
of meta-discussion instead of discussing about the relevant subject at hand.
Date: 21 Jun 2010 13:16:37
Message: <4c1f9e75$1@news.povray.org>
> guy.
You real think insulting me will get you any further? You already misbehaved
twice. First by vandalizing the Wiki, the by vandalizing the bug tracker. No
need to vandalize the newsgroups as well.
	Thorsten
Date: 21 Jun 2010 13:20:04
Message: <4c1f9f44$1@news.povray.org>
It's because you're invading his precious territory.
Date: 21 Jun 2010 13:55:00
Message: <web.4c1fa75b55d1933d18dfcc4d0@news.povray.org>
oh, the last one is easy:  I vote for the pov-team. :)
Date: 21 Jun 2010 16:09:44
Message: <4c1fc708$1@news.povray.org>
I'd like to throw my 10c in here WRT to this thread (which is getting a
little long so I won't attempt to cover all the issues).
The way the bugtracker works with regard to 'closed' bugs isn't easily
altered (in that they don't turn up in searches by default). I will attempt
to rectify this later.
Comments on closed bugs were previously not available; they are now -
hopefully this will allow easier feedback.
When reporting a bug or making a feature request please try to be detailed
and especially include platform and version details.
Also, it would help us a bit if closely-related feature requests were
grouped together; e.g. the recent requests for Windows UI enhancements with
respect to the editor could reasonably have been put into a single request
(all at once or via editing a bug later).
Before posting a feature or bug request, it might be useful to sound it out
with other users first. This doesn't mean you have to run it by us, but
getting other user's feedback can help improve the quality of the requests
we get. This isn't a hard and fast rule, it's just a suggestion.
Please keep in mind that we (like most open-source projects) are
under-manned so doing things in such a way as to make it easier for us to
track helps. The bugtracker is of course there for that reason, but as I've
pointed out it's important to make the reports as useful for us as
reasonably possible. Higher quality reports == more chance we'll pay close
attention.
-- Chris
Date: 22 Jun 2010 19:11:03
Message: <4c214307$1@news.povray.org>
No, as per the bug reporting instructions which say, "Only report one
bug or request one feature per task."
Date: 23 Jun 2010 12:18:17
Message: <4c2233c9@news.povray.org>
>> with
>> request
You know whom you are talking to, don't you? - This reminds me of my
favourite quote: "The ability to speak does not make you intelligent."
I wonder if this also applies to writing? Hmm...
Anyhow, here is how you could have summarized feature requests 138, 139 and
140 in a single report. It is really easy, I am sure next time you can
follow these instructions:
1. Power up brain.
2. Wait for brain to boot.
3. Enable ability to think.
4. Think about the features "Rename file", "Delete file", "Reload file".
5. Make sure brain concludes the features belong in the "File" menu.
6. Think about the "File" menu and conclude it groups file functions.
7. Think about feature request to extend the "File" menu.
8. Make sure to name "Rename", "Delete" and "Reload" possible extensions.
9. Let brain command body to type and submit feature request.
10. Disable ability to think.
11. Power down brain.
12. Wait for brain to power down.
13. Return to normal zombie activities.
	Thorsten
Date: 23 Jun 2010 12:54:01
Message: <4c223c29$1@news.povray.org>
...and someone could just as easily have bitched about /not/ reporting
them as separate tasks. Was there a way to know this beforehand? No. Are
you an asshole? Yes.
Date: 23 Jun 2010 13:08:35
Message: <4c223f93$1@news.povray.org>
There is a discussion area in bugtracker for this, no?
Date: 23 Jun 2010 14:27:01
Message: <4c2251f5$1@news.povray.org>
Am 23.06.2010 19:08, schrieb SharkD:
>> it out
>> requests
Not really.
There is a feature to allow other users and/or developers to comment on
bugs & feature request, but this is primarily intended for providing
additional information, or feedback on the current status. For proper
discussions, it lacks the necessary publicity. (When was the last time
you just browsed the bugtracker just to see if there was some
interesting discussion going on in some of the entries?)
As someone else already said, the POV-Ray community is strongest in the
newsgroups.
