POV-Ray : Newsgroups : povray.advanced-users : Pattern showing *change* in slope Server Time
18 Oct 2026 02:58:29 EDT (-0400)
  Pattern showing *change* in slope (Message 1 to 26 of 26)
Subject: Pattern showing *change* in slope
Date: 28 Aug 2009 06:52:54
Message: <4a97b706$1@news.povray.org>
How can I create a pattern that shows the *change* in slope of a
heightfield. I.e., brighter where the "curvature" is greater.
Thanks!
-Mike
Subject: Re: Pattern showing *change* in slope
Date: 28 Aug 2009 07:25:22
Message: <4a97bea2$1@news.povray.org>
You can create this from the image you use for the height field
To begin with, make a pigment from the image; make from that a function F.
Now, create a function G computing the curvature from five function
values from F, spaced apart by (at least) 1/BITMAP_SIZE, to compute the
"difference in difference" both vertically and horizontally:
#declare D = 1/BITMAP_SIZE; // insert actual size of your bitmap here
#declare Sqr = function(x) { x*x }
#declare G = function(x,y,z) {
   sqrt(
     Sqr( F(x-D,y,z) + F(x+D,y,z) - 2*F(x,y,z) ) // squared curvature X
     Sqr( F(x,y-D,z) + F(x,y-D,z) - 2*F(x,y,z) ) // squared curvature Y
finally, apply this function as a pattern to your height field.
Date: 28 Aug 2009 07:40:32
Message: <4a97c230@news.povray.org>
I used that for my hf2iso experiment:
global_settings{hf_gray_16}
#include "functions.inc"
// file to extract slope from
#declare hf_file="your_hf_here"
// sloped texture with autoilluminated finish
#declare t_terrain_slope=
texture{
  pigment{
   slope y
   color_map{
    [0.00 rgb 0]
    [0.50 rgb 1]
    [0.67 rgb 1]
    [0.75 rgb 0]
    [1.00 rgb 0]
  finish{brilliance 0 ambient 1}
// create a heightfield from the bitmat
#declare terrain=
height_field{
  tga hf_file
  translate -.5
  scale <2,1,2>
  texture{t_terrain_slope}
object{terrain}
// take a square shot
camera{
  orthographic
  location <0,0,-1>
  up 1*y right 1*x
  angle 90
  look_at 0
  rotate 90*x
Jaime
Date: 28 Aug 2009 07:45:22
Message: <4a97c352@news.povray.org>
> texture{
>   pigment{
>    slope y
  That shows the slope of the heightfield, not the *change* in slope,
which is a bit more involved (it would require the derivative of the
function which indicates the slope of the heightfield; since the slope
function is the derivative of the heightfield function, the change in
slope would thus be the double derivative of the heightfield function).
  Maybe the original poster really wanted to actually see the slope,
rather than the change in slope, in which case your answer would be
the correct one.
Date: 28 Aug 2009 09:38:51
Message: <4a97ddeb@news.povray.org>
> the correct one.
Nope. I want the double derivative.
-Mike
Date: 28 Aug 2009 09:39:53
Message: <4a97de29$1@news.povray.org>
>   sqrt(
I'll give it a shot, thanks.
-Mike
Date: 28 Aug 2009 10:33:34
Message: <4a97eabe$1@news.povray.org>
>> texture{
>>   pigment{
>>    slope y
> the correct one.
Is there a function in POV that will allow me to automatically take the
derivative of another function?
-Mike
Date: 28 Aug 2009 11:12:05
Message: <4a97f3c5@news.povray.org>
  Then your only option is to generate the heightfield using a function
and then use the double derivative of that function with respect to x and
another with respect to y and combine them appropriately to create the
desired pattern, which you then can use to create the pigment.
Date: 28 Aug 2009 11:13:36
Message: <4a97f41f@news.povray.org>
  Calculating the derivative of a function analytically is not trivial
and has such low demand that povray obviously doesn't offer such a thing.
  A numerical approximation could be easier, but still the demand is so
low that no such luck.
  But I think the user-defined functions are expressive enough for you to
do it in SDL.
Date: 28 Aug 2009 11:52:04
Message: <4a97fd24$1@news.povray.org>
> do it in SDL.
Date: 28 Aug 2009 11:52:30
Message: <4a97fd3e@news.povray.org>
> do it in SDL.
OK, so how would I go about doing it?
-Mike
Date: 28 Aug 2009 12:05:34
Message: <4a98004e$1@news.povray.org>
OK, here's what I have:
//START
#local hf_function1 = function {pigment {hf_pigment3}}
#local dv_D = 1/1024;
#local dv_Sqr = function(x) {x * x}
#local dv_G = function(x,y,z)
	sqrt
		dv_Sqr(hf_function1(x - dv_D,y,z) + hf_function1(x + dv_D,y,z) - 2 *
hf_function1(x,y,z))
		dv_Sqr(hf_function1(x,y - dv_D,z) + hf_function1(x,y - dv_D,z) - 2 *
//END
However, I get the error: "Parse Error: Expected '.', + found instead"
-Mike
Date: 28 Aug 2009 12:09:26
Message: <4a980135@news.povray.org>
> > do it in SDL.
http://en.wikipedia.org/wiki/Derivative
Date: 28 Aug 2009 12:10:02
Message: <4a98015a$1@news.povray.org>
clipka wrote:
>   sqrt(
Also, there's supposed to be an operator between the first and second
instances of the function "Sqr". Which operator is it?
-Mike
Date: 28 Aug 2009 12:16:08
Message: <4a9802c8@news.povray.org>
Please point me to the part where it describes POV SDL.
Thanks.
-Mike
Date: 28 Aug 2009 12:31:00
Message: <4a980644$1@news.povray.org>
SharkD schrieb:
> clipka wrote:
>>   sqrt(
Oops, sorry - should be "+".
The idea behind it is that each terms inside the Sqr() computes the
curvature in a particular dimension; if you interpret that as a vector,
the sqrt(Sqr()+Sqr()) computes the "absolute" of the curvature.
Date: 28 Aug 2009 12:35:40
Message: <4a98075c$1@news.povray.org>
> 2 * hf_function1(x,y,z))
Sorry, I forgot that with that hf_function1 being a pigment function,
you'll need to evaluate a particular color component, so instead of
     hf_function1(...)
you need to write:
     hf_function1(...).grey
(or .red, .green or .blue, but if I'm not mistaken the height_field
object uses the combined grey value as well, so the same should be used
as the basis for the curvature computations.)
Date: 28 Aug 2009 12:43:37
Message: <4a980939$1@news.povray.org>
>     hf_function1(...)
> you need to write:
Thanks! However, all I see is black. Here are the relevant portions of
my scene.
-Mike
//START
#local hf_pigment1 = pigment
	image_map {png "hf_big.png"}
	rotate x * 180		// flipped
#local hf_function1 = function {pigment {hf_pigment1}}
	sqrt
		dv_Sqr(hf_function1(x - dv_D,y,z).gray + hf_function1(x +
dv_D,y,z).gray - 2 * hf_function1(x,y,z).gray)
		dv_Sqr(hf_function1(x,y - dv_D,z).gray + hf_function1(x,y -
dv_D,z).gray - 2 * hf_function1(x,y,z).gray)
height_field
	function 1024, 1024 {hf_function1(x,y,z).gray}
	smooth
	texture
		pigment
			function {dv_G(x,y,z)}
			color_map
				[0 rgb 0]
				[1 rgb 1]
		finish {ambient 1}
	translate <-1/2,0,-1/2,>
//END
Date: 28 Aug 2009 13:01:54
Message: <4a980d82$1@news.povray.org>
> my scene.
Ah, yes... looks like I forgot that you need to multiply the sqrt() term
with the image's size again (and then scale to taste).
Date: 28 Aug 2009 18:25:00
Message: <web.4a9858dd38d8f2bb457ff4630@news.povray.org>
> my scene.
> -Mike
> //START
>  sqrt
The dy component is being subtracted twice, when it should be subtracted for one
value, then added.
    1/dv_D *
    sqrt
        dv_Sqr(   hf_function1(x - dv_D,y,z).gray
                + hf_function1(x + dv_D,y,z).gray
                - 2 * hf_function1(x,y,z).gray )
       +dv_Sqr(   hf_function1(x,y - dv_D,z).gray
                + hf_function1(x,y + dv_D,z).gray
Also, isn't that the first derivative (i.e. slope), not the second?  The
function is roughly analogous to what you would want to do with, say, the
surface normal of the object (i.e. measure the normal's rate of change), or the
values that are returned from the slope pattern.
If you use this directly as a pigment, you should clip it between 0 and 1.
Personally, I would also probably rotate the image and evaluate in the xz plane
because it is easier for me to think of, but either way will work.
-Reactor
Date: 28 Aug 2009 23:54:11
Message: <4a98a663@news.povray.org>
> -Reactor
There are unfortunately some weird striations in the resulting image:
http://i421.photobucket.com/albums/pp292/SharkD2161/Support/hf_striations.png
At least I can *see* something. :)
-Mike
Date: 29 Aug 2009 00:09:47
Message: <4a98aa0b@news.povray.org>
The factor to multiply the sqrt() term with is obviously too high,
leading to the banded pattern.
In addition, it appears to me that your input file is suffering from
JPEG artifacts, causing those regular-spaced vertical stripes.
Date: 29 Aug 2009 00:15:29
Message: <web.4a98aa4038d8f2bb16a06750@news.povray.org>
> > -Reactor
> -Mike
The striations are do to the values going outside of the 0...1 range.  It can be
clipped using min() and max().
Are you using the change in slope to decide where to place objects?  I've been
working on a macro for that, trying to get it to decide where to place rocks
for stream beds.  It works ok, but I think it needs to average the normals in a
small radius for each point to get a more accurate test of concavity.
-Reactor
Date: 29 Aug 2009 18:04:34
Message: <4a99a5f2@news.povray.org>
Not JPEG artifacts, but artifacts from increasing the dimensions of a
low resolution heightfield. I thought L3DT had eliminated them, but it
didn't. Thanks.
-Mike
Date: 29 Aug 2009 19:40:53
Message: <4a99bc85$1@news.povray.org>
> -Reactor
Sort of. I am rendering the image to act as a guide. Based on the guide
I place the objects manually in a separate application.
-Mike
Date: 8 Sep 2009 16:59:01
Message: <4aa6c595$1@news.povray.org>
The derivative of a surface is really 2D, but here's the
x component. It's just the change in the slope (dx) with
the interval xstep. With an image it really isn't smooth up
close, so you need to make sure that the interval is large
enough to avoid the artefacts, and small enough to still
get an accurate slope.
  orthographic
  location <0,0,1>
  look_at  <0,0,0>
  right 1*x
  up 1*y
// input heightfield image
#declare fn1 = function {pigment {image_map {png "plasma3.png"}}};
// derivative
#declare xstep = 0.01;
#declare dx = function { (fn1(x,y,z).grey-fn1(x-xstep,y,z).grey) -
                         (fn1(x+xstep,y,z).grey-fn1(x,y,z).grey) };
// remap to drawable colors
#declare fcolor = function { select( dx(x,y,z)+0.5, 0,
                             select( dx(x,y,z)-0.5, dx(x,y,z)+0.5,1))};
box { // this box fits exactly in view
  <-0.5, -0.5, 0>, <0.5, 0.5, 0>
       image_map {
          function 200,200 {fcolor(x-0.5,y-0.5,z)}
