POV-Ray : Newsgroups : povray.advanced-users : Pigment along a sphere_sweep Server Time
11 Nov 2025 13:53:05 EST (-0500)
  Pigment along a sphere_sweep (Message 1 to 8 of 8)
Subject: Pigment along a sphere_sweep
Date: 18 Feb 2007 11:59:07
Message: <45d885db$1@news.povray.org>
Hi!
Is it possible to color a sphere_sweep along the spline? I.e. with a
gradient that follows the spline instead of fixed direction. As the
spline twists in all directions I can't fake it by using a standard
gradient. I tried to transform the spline coordinates to something more
accessible, but that fails because one has no possibility to know how
far on the spline a given point (x,y,z) is. But perhaps I'm missing
something :)
Florian
Subject: Re: Pigment along a sphere_sweep
Date: 18 Feb 2007 15:53:23
Message: <45d8bcc3@news.povray.org>
> something :)
I don't think there is an easy solution for this. Actually you'd
like to have uv_mapping which does not seem to be supported by
the sphere_sweep object.
Possible workarounds include:
o Split your sweep into multiple shorter sweeps, for each of which a
   linear gradient may be a good enough approximation for texturing
o Switch to an object which supports uv_mapping such as "parametric"
o Implement uv_mapping for sphere_sweep and publish a patch ;)
Date: 18 Feb 2007 16:29:07
Message: <45d8c523$1@news.povray.org>
> ... I tried to transform the spline coordinates to something more
This macro can estimate the distance between points on a spline
by summing the linear distance between a number of sub-points.
#macro Len_Spline(Espl begin_at stop_at num)
   #local c = 1/num;
   #local V1 = Espl(begin_at);
   #local result = 0;
   #while (c <= 1)
      #local V2 = Espl( c*(stop_at - begin_at) + begin_at);
      #local result = result + vlength(V2-V1);
      #local V1 = V2;
      #local c = c + 1/num;
   (result)
#declare sample = Len_Spline(ABC_spl, 0, 0.5, 2000);
You might also want to look at the MSM macro in
Ingo's meshmaker stuf. http://members.home.nl/seedseven/
Date: 20 Feb 2007 20:20:01
Message: <web.45db9d5f564aa52a4daddc090@news.povray.org>
Florian Brucker <tor### [at] torfboldcom> wrote:
> Hi!
> something :)
> Regards,
> Florian
I wrote a macro to generate a mesh2 object based on a spline path.
It doesn't allow for varying radius along the sweep, and the ends aren't
capped so it's just a hollow tube (no CSG).  It was written specifically
for doing texture-mapped hoses, so the UV mapping is worked out.  I'll post
it in binaries later.
Another simple method is to build the object with spheres & cylinders, and
apply the pigment individually to each object.
Mark
Date: 24 Feb 2007 06:19:03
Message: <45e01f27@news.povray.org>
Thanks, I'll see if it solves my problem. But as I'm having lots of
those tubes (around 1000) which are all pretty curvy I'm afraid I might
run into memory problems. We'll see :)
That's what I'm doing right now, but you need an awful lot of cylinders
to make it look right. And the sweep thingy would be more elgant, too ;)
Florian
Date: 24 Feb 2007 06:20:53
Message: <45e01f95$1@news.povray.org>
Yep, at parse time, that is. Unfortunately I'd need that information at
render time in the pigment function. Perhaps I'll be able to put
something together from it, though. Thanks!
Florian
Date: 24 Feb 2007 06:22:57
Message: <45e02011$1@news.povray.org>
Ah, wouldn't work all too good in my case I'm afraid.
Is there an object that's slower than parametric? ;) Seriously, the
cylinder/sphere method I'm using now is IMHO better suited (but still
not optimal).
Uh, nice idea. Now if I just had any idea about uv mapping :)
Thanks for your tips!
Florian
Date: 24 Feb 2007 11:16:55
Message: <45e064f7$1@news.povray.org>
Florian Brucker nous apporta ses lumieres en ce 24-02-2007 08:41:
> Regards,
> Florian
In some cases, you can use sections of torus for the curved parts. It can enable
you to dramaticaly reduce the number of components that you need.
A day for firm decisions!!!!!  Or is it?
