POV-Ray : Newsgroups : povray.advanced-users : Isosurface speed Server Time
18 Oct 2026 06:36:33 EDT (-0400)
  Isosurface speed (Message 1 to 20 of 20)
Subject: Isosurface speed
Date: 28 Aug 2006 10:05:15
Message: <44f2f81b$1@news.povray.org>
I have an isosurface that's making my 2.2 GHz Athlon64 cry. Currently
averaging just 40 pixels/second - and that's just for the *black*
pixels! I hate to think what it will slow down to if it ever gets to the
part with some surface in it...
The real killer is that it's actually a very simple (I might even say
"boring") shape I'm trying to trace. It's essentially a Z-shaped oval
pipe. That's it.
However, since it's the isosurface of a 18th degree polynomial, I've had
to set max_gradient=exp(18) to get it to render correctly.
In layman's terms, the problem is simple. Because the *maximum* gradient
of the function is extremely high, POV-Ray is densely sampling all of
space (even the completely empty parts) just in case there's some
surface there. In fact, it just so happens that the edges of the
bounding box are where the function is steepest; where the surface is,
the function is fairly shallow.
And so, I've been sitting here thinking about all the ways POV-Ray could
arrive at its result faster. The trouble is, I can think of quite a few
that would work for *this* shape, but would fail in special cases. It
just so happens that the shape I'm trying to trace has a huge max
gradient, but is actually a very simple shape.
One idea is if POV-Ray were to cache the locations of previously
discovered surface points. Then instead of densely sampling the entire
length of a ray, you would only need to sample "around" where the last
surface was found.
This instantly fails when you reach a nearer edge that should occlude
the previously-found surface. POV-Ray would *still* need to densely
sample all the way back towards the camera to check it's found the
*nearest* surface point. (Also, a cache lookup would have to end up
being quicker than just calculating samples...)
Another idea is to do a little prepass stage where POV-Ray builds up a
low-res 3D map of the surface, so it has some idea where to start
looking when tracing a ray. You start by finding a surface point - ANY
surface point - and then finding other surface points near to it, until
you have covered the entire surface with a loose grid of points. Doing
it this way avoids the edge problem, because you "follow" the surface
round before you even start tracing.
This instantly fails if the surface is not completely connected. It also
fails if the grid points are too far apart to pick up small details.
(You would need something like a max_complexity number telling POV-Ray
how "messy" the surface is, and hence how fine a grid to use.)
Yet another idea (similar to the previous one) is to split all of space
into a grid of cubic volumes, and attempt to figure out which cubes
actually contain some surface, and which ones are completely empty.
Once again, this doesn't work well for disconnected surfaces. How will
you tell if a cube contains anything? POV-Ray would need to know the
minimum possible size of a feature to look for... And then how would you
actually look for it? We could end up doing more work here then what we
do currently!
In short, lots of ideas that would work for the shape I'm trying to
trace, but none that would work for every possible shape one could try
to trace.
Anybody have any further thoughts?
Subject: Re: Isosurface speed
Date: 28 Aug 2006 10:11:37
Message: <20060828151139.5f46bd20@mekanori.mon.istic.org>
> to trace.
Nothing general, but if you (the user) know where the bits of surface
are, you could try splitting up the isosurface into smaller chunks, and
set the max_gradient lower where it doesn't need to be as high. I
couldn't tell from your description whether this is the sort of
isosurface that that would work for: it usually works well for functions
with low gradients in most places but singularities at a few points.
"Of all  things,  good sense is  the most fairly  distributed:  everyone
thinks  he is  so well  supplied  with it  that even  those who  are the
hardest to satisfy in  every other respect never  desire more of it than
they already have."   --  Descartes, 1637      http://surreal.istic.org/
Date: 28 Aug 2006 10:29:00
Message: <44f2fdac@news.povray.org>
Hmm... could work.
Attached is a graph of the function I'm trying to trace. (Note the
LOGARITHMIC Y SCALE!) The red line is the function. The green line is
the isosurface threshold. (i.e., the parts below that line are "inside",
and the parts about it are "outside".)
You can see why POV-Ray is struggling; on a linear scale, the graph is
two vertical lines with a flat part in the middle. So POV-Ray has to
tip-toe through space at some ridiculous spacing to be absolutely
certain that there isn't some vertical line in the graph taking us down
to a surface. If it was a different function, there might be. But for
this one, there isn't.
Currently POV-Ray has the maximum possible gradient. That is, the 1st
derrivative of the function's value with respect to space. I wonder -
would POV-Ray be able to do something more intelligent if it had the
maximum SECOND derrivative too? Then perhaps it would know that the
sides are very steep, but the steepness can't change very suddenly...
Hmm, no, that's still not much help.
Download 'graph1.png' (11 KB)
Preview of image 'graph1.png'
Date: 28 Aug 2006 10:34:38
Message: <44f2fefe$1@news.povray.org>
Post a minimal scene with the function, there might be ways to improve
render time.
	Thorsten
Date: 28 Aug 2006 10:45:51
Message: <44f3019f@news.povray.org>
  I suppose you have tried with a lower max_gradient and it resulted
in an incorrect rendering?
Date: 28 Aug 2006 10:53:09
Message: <44f30355$1@news.povray.org>
Yes.
Specifically, a black image. (max_gradient=exp(17) renders with a few
holes. exp(16) gives a totally black picture.)
Have a look at the graph I posted. The sides of this function rise like
x^18, but the bit in the middle is quite "flat". Without the
astronomical max_gradient, POV-Ray samples the edge of the BB and sees a
value like 10^12 or something, and thinks "hey, no surface for miles
around" and doesn't find anything. But if you turn up the max_gradient
high enough to make POV-Ray take resonable size steps even when f=10^12,
then when you get to the middle POV-Ray start to take *minute* little
steps...
It seems I've found a very pathalogical case for the particular
algorithm POV-Ray is using. As I said, I'm not really sure what POV-Ray
could do differently here...
Subject: Ooo... a solution?
Date: 28 Aug 2006 10:58:01
Message: <44f30479$1@news.povray.org>
I just had a brainwave!
I changed fn(x, y, z) to log(fn(x, y, z)), and changed the max_gradient
to 4. I'm now getting several thousand pixels/second.
Of course - the logarithm function makes the crazy vertical sides less
"vertical", while not flattening out the parts near the solutions so
POV-Ray still has some contours to go on.
(I read somewhere that dividing your function by a big number makes
max_gradient lower, but doesn't make it trace any faster. But this trick
makes the big numbers small, but leaves the small numbers alone so
POV-Ray doesn't go around taking tiny steps there any more.)
Subject: Re: Ooo... a solution?
Date: 28 Aug 2006 14:45:30
Message: <g05rCfAomz8EFw8M@econym.demon.co.uk>
That sounds like me
http://www.econym.demon.co.uk/isotut/dont.htm
I'll have to go back to that page and see if your trick can be applied
generally.
Mike Williams
Gentleman of Leisure
Date: 28 Aug 2006 15:14:38
Message: <44f3409e$1@news.povray.org>
> That sounds like me
Yeah.
Ooo... "you can't use arrays in an isosurface function". Um... well... I
just did. :-.
> generally.
You gotta see the isosurface function the way POV-Ray sees it. (See the
graph I posted in another reply here.)
I've been thinking about the way POV-Ray's sphere-tracing algorithm
works. (I should diagram that thing sometime...) Anyway, it seems that a
large max_gradient isn't too much of a problem, by itself. The problem
occurrs when
1. The function has a high max_gradient.
2. The function has large areas of "nearly zero".
The high max_gradient makes POV-Ray take tiny little steps through the
nearly-zero areas. (But if you turn down the max_gradient, the high
values make POV-Ray take giant steps and completely miss the surface.)
The logarithm function is perfect here, because it makes big values
small, but doesn't change small values much. (The sqrt() function would
work too, but to a lesser extent.)
Problem #1 is going to be negative numbers. You'll have to bias the
function completely into positive space before attempting to take the
logarithm, and then bias the result back. This fails for functions that
zip of to minus infinity. (Actually, it's probably best to keep the
whole function above 1, rather than just above 0.)
Note that my solution works because the surface I'm actually trying to
draw is quite simple, it's just the maths is confusing POV-Ray. Not sure
what happens if the surface really *is* complicated - I suspect you
can't do too much about that...
Date: 28 Aug 2006 20:22:41
Message: <44f388d1@news.povray.org>
> just did. :-.
  You can use an array to *create* an isosurface function. You can't
use an array *in* an isosurface function (IOW the function cannot
access an array).
Date: 29 Aug 2006 04:18:52
Message: <WZW25YAWR+8EFwJe@econym.demon.co.uk>
>> That sounds like me
>Yeah.
>just did. :-.
I don't say you can't use arrays. I say
  You can't index an array inside an isosurface function.
  You can use individual fixed elements of an array, like A[3] but you
  can't use the function variables to index the array like A[floor(x)].
  However, you can do this:
  http://www.econym.demon.co.uk/isotut/arrays.htm
Mike Williams
Date: 13 Sep 2006 09:50:00
Message: <web.45080b8cf7b7b54cfddaa4670@news.povray.org>
Povray isosurfaces are fastest when the actual gradient does not differ
too much from maxgradient. Therefore I always try to code isosurface
functions such that their value is the actual distance from the surface.
Of course in general this is only approximately and/or locally true.
In your case I would basically wrap an 18th root around the function.
(Still you have to take some care as to small and negative values.
Assuming a threshold of 1 you could wrap pow(max(1/2, ... ),1/18).)
Of course this is similar to your own idea of wrapping a logarithm.
We all learned at school how to build derivatives of functions. In fact
this was an algorithm on the symbolic representation of the functions
(as opposed to numerics) and could be incorporated into povray (Maybe
except for some inbuilt pattern functions, I don't know about those...).
So instead of assuming the gradient to be maxgradient, the isosurface
algorithm could compute the actual gradient. Of course, in order to know
how far this computed gradient can be trusted, the *second* derivative
must be bounded or computed. And if it is computed, we need to know a
bound or compute the third, and so on. So this would amount to defering
the maxgradient specification until some later derivative which hopefully
does not change too much. In your case that would be the 18th deriviative
with a bound of 0.
I am unsure though, if this actually has merits: With multiplications the
derivatives can be a lot more lengthy than the original function. Also,
as the functions depend on 3 variables, there are 3^n derivatives of
order n to be considered. This can get out of hand rather faster than it
has any benefits.
  Mark Weyer
Date: 13 Sep 2006 10:03:11
Message: <45080f9f@news.povray.org>
  You mean an isosurface which renders *correctly* is fastest when its
gradient and the max_gradient are close to each other?
  Naturally a lower max_gradient will always produce a faster isosurface,
but it won't render correctly if it's too low, of course.
Date: 13 Sep 2006 10:35:01
Message: <web.45081621f7b7b54cfddaa4670@news.povray.org>
My statement was meant as a rule of thumb and is imprecise in several ways.
Furthermore it is only based on how I think it works.
My point is that I have found it worthwhile to get rid of 'nonlinearities'
in iso functions. Extra wrappers of sqrt or such might take more time per
sample, but make the algorithm require much fewer samples. Of course I am
only interested in correct renderings.
In this sense an incorrectly rendered iso renders fastest when it is omitted
(or maybe replaced by its contained_by -- it can even speed things up by
eclipsing complex objects) ;-)
I recall some SCC entries that use incorrect iso rendering on purpose.
But I am not aware of a 'serious' application of this practise...
  Mark Weyer
Date: 27 Sep 2006 06:52:47
Message: <pan.2006.09.27.10.53.03.34363@knobbits.org>
Okay, so I'm making the mistake of reading this group even though I'm not
really an expert at povray (I have made a couple of moderately
complex scenes but compared to whats on irtc I'm a novice), and I'm
finding this isosurface stuff fascinating.  So I'm going to attempt to
contribute with my knowledge of maths and some educated guesses about how
the isosurface stuff works.  Feel free to correct or flame me.
AIUI, the isosurface stuff works by assuming that the function's value
won't change by more than x/max_gradient over a distance of x, so it uses
this and an algorithm sorta like newton's method or the sturmian root
solver to find points that lie on the surface.  This all gets ugly if the
function, like, has an order greater than 1, or has an exponential or 1/x
in it, etc, since these functions have derivatives that increase
indefinitely in certain regions.
But all of these functions can be mapped to functions where there is a
one-to-one mapping between the zero values (or the values that we want
mapped to the surface), and whose derivatives are bounded.  For example,
x^2 = 10
Its derivative is x which increases indefinitely, but if we go
sqrt(x^2) = sqrt(10)
x = sqrt(10)
Then we end up with a function whose derivative is bounded and whose 0
locus (sorry if I'm not using correct terminology here) is still the same.
This is what Orchid effecitively did with his exponential function.  By
taking the log of the whole function he created a new function with the
same properties.
For the function x^2 this is trivial - it produces a new function which is
easily used in an isosurface anyway.  Orchid's function was less obvious.
I'm curious, could this kind of thing theoretically be done automatically
by povray?  What if it were to use log(function) or sqrt(function) or
1/function to find the surface points rather than the actual function, and
the max_gradient were to apply to that function instead of the original?
Mick.
Remove the -news from my email address.
http://mickworld.knobbits.org/
Date: 27 Sep 2006 15:43:59
Message: <451ad47f$1@news.povray.org>
[Actually it's x TIMES max_gradient, but you've got the idea.]
POV-Ray samples the function more densely when it gets "close" to a
zero, and less densely when it's nowhere near one. To know what "near"
is, it must know the maximum gradient. It doesn't actually need to know
multiple derrivates or anything, it just needs an upper bound on how
densely it needs to sample to not miss any zeros.
More specifically, it gets ugly if the function contains discontinuities
or poles. Beyond that, it works for arbitrary functions. (Which is why
POV-Ray uses it. Other methods work only for polynomials or only for a
function you have the derivative of, etc. But this method works for
*anything*, provided it has "nice" numerical properties.)
> For example,
> x^2 = 10
True - but POV-Ray only ever renders A FINITE SECTION of the function.
;-) Within that section, the derivative will be bounded.
This doesn't alter the fact that the derivative could well be
increasibly big, causing POV-Ray to take drastically more samples than
is really necessary near the zeros (where the derivative is actually
much smaller).
> but if we go
> x = sqrt(10)
Correct. The surface to be rendered hasn't changed, but the derivative
doesn't vary so wildly any more. (In fact, in this trivial case it's
constant.)
> same properties.
My particular function was something like x^18 + ... = 0. It has almost
vertical sides, yet the "interesting" part has a tiny derivative. My
using the log() function I can "magnify" the interesting bit, and zoom
out the unimportant vertical walls that are confusing the poor root solver.
However, note that you must make sure the function is NEVER NEGATIVE,
since log(-1) is a complex number, and POV-Ray won't like that. This
sometimes requires you to translate the function in the Y-direction,
take the log, and then translate the result back again:
   f2(x) = k + log(f1(x) - k)
Selecting the correct k turns out to be very critical. The log function
shrinks large features, but it can also "magnify" small ones. If you get
the "wrong" value for k, you can end up creating big vertical side RIGHT
NEXT TO THE ZEROS. That means you MUST use a high max_gradiant or
POV-Ray will overshoot the zeros - the exact thing we were trying to
avoid...
(The problem gets even more fun if you start taking double-logs!)
For every function for which this is faster, there is another one for
which it is slower. It would probably take more time to detect which
case applies than to just use the "wrong" variant. (See above.)
OTOH, it might be worth making a *keyword* to do this kind of
optimisation automatically instead of altering the function by hand...
Date: 28 Sep 2006 09:19:51
Message: <pan.2006.09.28.13.20.12.48220@knobbits.org>
> avoid...
Yeah, the magnification of small values (which also applies to, say,
sqrt(x)), is something I forgot about.  I guess real world functions would
be less trivial to "map" in the sense I was talking about.
Why would you want to do that for a function other than a
double-exponential?  Masochism? Maths fetish? :)
>> automatically by povray?  What if it were to use log(function) or
>> sqrt(function) or 1/function to find the surface points rather than the
>> actual function, and the max_gradient were to apply to that function
Also, I just realised, I think most functions with ever-increasing
gradients could be reined in by putting it in a min() or max() function,
or both.  Would that work with your exp function?
Mick.
Date: 28 Sep 2006 20:34:47
Message: <451c6a27$1@news.povray.org>
Michael (Micksa) Slade nous apporta ses lumieres en ce 28/09/2006 09:20:
>> avoid...
> Mick.
You can come acros functions that have even more extreem gradients and a single
log still give you a max_gradient in the thousands, like a 20th degree or more
or an x^10x kind of case. You then may want to use double logs. In that case, it
can be usefull to use log(max(0, log(YourFunction))) to clip negative values.
If That Phone Was Up Your Butt, Maybe You Could Drive A Little Better!
Date: 29 Sep 2006 00:30:00
Message: <web.451ca0b3b14bbacda2fccf710@news.povray.org>
I suppose you could try using the evaluate keyword instead of just giving
max_gradient...  go with evaluate 1e+17,3,0.1 or so, and maybe it'd run at
a decent speed (if you're lucky) without mucking about with renormalizing
the function.
Date: 29 Sep 2006 15:00:23
Message: <451d6d47$1@news.povray.org>
> the function.
The evaluate keyword is only for figuring out what max_gradient should
be optimally set to. It doesn't change the need to make the function
*reasonably* well behaved to get good performance...
