POV-Ray : Newsgroups : povray.advanced-users : Tricky object alignment problem Server Time
4 Nov 2026 11:22:41 EST (-0500)
  Tricky object alignment problem (Message 1 to 14 of 14)
Subject: Tricky object alignment problem
Date: 26 May 2006 17:03:16
Message: <44776d14$1@news.povray.org>
OK, have a look at this:
#macro Rectangle(A, B, C, D, r)
   sphere {A, r}
   sphere {B, r}
   sphere {C, r}
   sphere {D, r}
   cylinder {A, B, r}
   cylinder {B, C, r}
   cylinder {C, D, r}
   cylinder {D, A, r}
As you can see, this draws a wireframe rectangle between 4
user-specified points in space.
Assuming that all 4 points are actually co-plannar, what would the *the
simplest* way to fit a box{} object into the middle of the thing?
Subject: Re: Tricky object alignment problem
Date: 26 May 2006 17:33:21
Message: <44777420@news.povray.org>
  Actually it's not enough for the points to be coplanar, they must also
form a perfect parallelogram or else 1 box will not do. If the shape is
not a perfect parallelogram then you'll have to use at least the difference
of two or three boxes.
  Of course you could go the easy way and close that object with
polygons or even triangles, unless you really want it to be solid,
in which case you'll have to either go with the boxes or use eg.
planes.
Date: 27 May 2006 07:07:13
Message: <447832e1$1@news.povray.org>
> planes.
Used for CSG --> I'd like it to be solid.
Hmm... planes is a good idea though!
(Actually, the code that generates the 4 points guarantees them to form
a rectangle. To be specific, A and B are identical except for the Z
coordinate, as are C and D...)
Date: 27 May 2006 07:18:50
Message: <4478359a$1@news.povray.org>
>   sphere {A, r}
>   sphere {B, r}
>   sphere {C, r}
>   sphere {D, r}
>   cylinder {A, B, r}
>   cylinder {B, C, r}
>   cylinder {C, D, r}
>   cylinder {D, A, r}
> #end
Use Matrix_Trans() or Shear_Trans()
(These are macros in transforms.inc)
This may also be relevant:
"How to transform a triangle into another", 2. October 2002
http://news.povray.org/povray.text.tutorials/thread/%3C3D9B843D.E5392CD0@hotmail.com%3E
http://tinyurl.com/nwvck
Tor Olav
http://subcube.com
Date: 27 May 2006 08:17:01
Message: <4478433d@news.povray.org>
  I don't think that's a guarantee of rectangularity nor even
parallelogramity.
Date: 27 May 2006 08:18:20
Message: <4478438c@news.povray.org>
  That will only work if the points form a perfect parallelogram.
Date: 27 May 2006 08:57:39
Message: <44784cc3$1@news.povray.org>
Yes, that's true.
(But I assumed that he wanted to use his macro for his wireframe
letters. See his latest post in povray.binaries.images)
Tor Olav
http://subcube.com
Date: 27 May 2006 10:32:48
Message: <44786310$1@news.povray.org>
> parallelogramity.
Why not?
Oh, did I not mention that A and C have *the same* Z coordinate? (As do
B and D...)
Date: 27 May 2006 10:49:46
Message: <4478670a$1@news.povray.org>
Thanks for the tip! :-D
Subject: A solution
Date: 27 May 2006 11:43:03
Message: <44787387$1@news.povray.org>
This seems to work...
#macro DrawPoly(Points, Radius)
   #local A = Points[0];
   #local B = Points[1];
   #local C = Points[2];
   #local AB = B - A;
   #local AC = C - A;
   #local Norm = vnormalize(vcross(AB, AC));
   #local V1 = Norm;
   #local V2 = vnormalize(AB);
   #local V3 = vcross(V1, V2);
   prism
     linear_sweep
     linear_spline
     -Radius, +Radius, dimension_size(Points, 1),
     #local lp = 0;
     #while (lp < dimension_size(Points, 1))
       <vdot(V3, Points[lp]), vdot(V2, Points[lp])>
       #local lp = lp + 1;
     translate +y*vdot(A, Norm)
     Reorient_Trans(y, Norm)
In case it way be of use to anybod else...
Subject: Re: A solution
Date: 28 May 2006 11:11:55
Message: <4479bdbb$1@news.povray.org>
Could you provide an example of use? I can't get it to work in the test
scene below. Granted, it doesn't use a parallelogram, but it looks like it
is meant to handle other coplanar points too. Besides, doesn't work with a
parallelogram either. If you really need it for parallelograms only, then I
can think of a simpler solution that uses a box instead of a prism.
#include "transforms.inc"
   sphere {A, r}
   sphere {B, r}
   sphere {C, r}
   sphere {D, r}
   cylinder {A, B, r}
   cylinder {B, C, r}
   cylinder {C, D, r}
   cylinder {D, A, r}
   #local AB = B - A;
   #local AC = C - A;
   #local V1 = Norm;
   prism
     linear_sweep
     linear_spline
     #local lp = 0;
       #local lp = lp + 1;
#declare Points = array[4] {<-1,-1,0>, <1,-2,1>, <1,2,1>, <-1,2,0>}
camera {location -6*z}
light_source {<-1,2,-3>*1000, color rgb 1}
union {
   Rectangle(Points[0],Points[1],Points[2],Points[3], 0.3)
   DrawPoly(Points, 0.3)
   pigment {rgb 1}
Rune
http://runevision.com
Date: 3 Jun 2006 15:09:56
Message: <4481de84@news.povray.org>
It *is* supposed to work for any polygone. Apparently it doesn't...
Please rip out the line at the end of DrawPoly() that says
and replace it with
   Shear_Trans(V3, V1, V2)
Let me know if that fixes the problem...
Date: 6 Jun 2006 07:28:31
Message: <448566df$1@news.povray.org>
> and replace it with
It seems to fix it. :)
Rune
Date: 7 Jun 2006 13:42:36
Message: <4487100c$1@news.povray.org>
Introduces an extra rotation that just happens not to be necessary in
the special case I had when I designed the thing. ;-)
