POV-Ray : Newsgroups : povray.advanced-users : Testing for NaNs Server Time
10 Apr 2026 18:25:11 EDT (-0400)
  Testing for NaNs (Message 1 to 4 of 4)
Subject: Testing for NaNs
Date: 10 Jan 2005 03:54:08
Message: <41e242b0@news.povray.org>
I've been running into errors with one of my supersurface tests:
<code>
// Parametric variable form
#declare uMin = 0; // Minimum u value
#declare uMax = radians(180); // Maximum u value
#declare uNum = 90; // Number of points in u direction
#declare uWrap = 0; // u wraps around if != 0
#declare uSeed = 2252; // Random number seed for u parameter
#declare vMin = 0; // Minimum v value
#declare vMax = radians(356); // Maximum v value
#declare vNum = 90; // Number of points in v direction
#declare vWrap = 1; // v wraps around if != 0
#declare vSeed = 7335; // Random number seed for v parameter
#declare IsRnd = false; // True if random number used
#declare IsUV = true; // True if uv-mapping used
#declare Smooth = 1; // Smooth flag
#declare Detail = "Partial"
/* Detail values
  Verbose = Line by line details
  Partial = Operations only
  Other = Filename only
/* For all macro functions
 i = Current value of u parameter
 j = Current value of v parameter
 p = Current value of u variance (0...1)
 q = Current value of v variance (0...1)
// Optional functions
#macro rd(a,b,m,n1,n2,n3,th)
 #local ra = abs(cos(m*th*0.25)/a);
 #local rb = abs(sin(m*th*0.25)/b);
 pow(pow(ra,n2)+pow(rb,n3),-1/n1)
#macro pof(n,ex,of) pow((n+of)*(n+of),ex*.5)-of #end
#declare a1=pi+2;
#declare b1=pi-2;
#declare m1=5.5;
#declare n11=1.50;
#declare n21=1.75;
#declare n31=1.25;
#declare a2=phi(2);
#declare b2=phi(3);
#declare m2=1;
#declare n12=0.30;
#declare n22=-.25;
#declare n32=-.35;
// point function
#macro pnt(i, j, p, q)
 #local rdi = rd(a1,b1,m1,n11,n21,n31,i+1e-3); // altered
 #local rdj = rd(a2,b2,m2,n12,n22,n32,j+1e-3);
 #local si = sin(i);
 #local ci = cos(i);
 #local sj = sin(j);
 #local cj = cos(j);
  /*torus
  #local xp = sj*(rdj+rdi*si);
  #local yp = cj*(rdj+rdi*si);*/
  //sphere
  #local xp = rdj*cj*rdi*si;
  #local yp = rdj*sj*rdi*si;
  #local zp = rdi*ci;
  #local dz = pof(zp, 1.3, 4.5);
  <xp+.1*dz,zp,yp>
</code>
Certain values of th, particularly 0, in the rd macro results in a NaN (Not
a Number) from dividing by 0 if n2 or n3 are negative.  A quick, dirty
workaround was the code marked "altered" which ensured that th never hit 0,
pi/2, pi, etc.
I use the code above to generate large mesh2 objects.  The errors were not
being caught until POV-Ray parsed the meshes, usually several minutes.  I
want to catch these errors more quickly and flag them with #error
directives, causing quick failure the instant one of these calculations goes
awry.
So, what is the fastest and easiest way to detect NaN floats and vectors?
David Wallace
TenArbor Consulting
"Just In Time Cash"
www.tenarbor.com
Subject: Re: Testing for NaNs
Date: 10 Jan 2005 05:40:24
Message: <41e25b98@news.povray.org>
  There isn't.
  What happens eg. with a division by 0 is completely system-dependant,
and even whether you get a 'NaN' value or something else is
system-dependant. (In fact, the 'NaN' value itself is system-dependant
because not all architectures implement the IEEE floating point numbers.)
  There's no portable way of testing "is this value a NaN?".
  The only way you can prevent it from happening is to test the
operands of the division prior to performing the division.
Date: 10 Jan 2005 07:13:32
Message: <3vr4u093dc6ui3erqpalcp8931nn1lmggn@4ax.com>
Hmm, IIRC there are already some assumptions about features of the compiler
for POV-Ray and isnan() is part of (C99) standard
http://www.opengroup.org/onlinepubs/009695399/functions/isnan.html
ABX
Date: 10 Jan 2005 13:16:15
Message: <41e2c66f$1@news.povray.org>
Are you (btw.) aware that it is possible to declare user
defined functions in POV-Ray ?
I think your code can be improved by using some of those.
You can find some relevant source code for POV-Ray here:
http://astronomy.swin.edu.au/~pbourke/povray/supershape/
Tor Olav
http://subcube.net
http://subcube.com
