POV-Ray : Newsgroups : povray.advanced-users : 3D mathematics question Server Time
18 Oct 2026 10:31:12 EDT (-0400)
  3D mathematics question (Message 1 to 18 of 18)
Subject: 3D mathematics question
Date: 8 Nov 2004 16:05:40
Message: <418fdfa4@news.povray.org>
Suppose I have a triangle with corners A, B and C. Suppose, further,
that I have a line that passes through P and Q.
Now... how do I figure out whether these two objects intersect each
other? (I don't care *where* they intersect, only *if*.)
Andrew.
Subject: Re: 3D mathematics question
Date: 8 Nov 2004 16:11:52
Message: <418fe118$1@news.povray.org>
Well, you could generate the plane of the triangle, and then cut the line
through P and Q with that plane. The angle between the vectors that point
from the intersection to the three corners then needs to add up to 360
degrees to lie in the triangle.
I hope that's correct, just wrote this off the top of my head. Maybe someone
can correct me if I've missed something.
Tim
"Tim Nikias v2.0"
Date: 8 Nov 2004 16:15:09
Message: <418fe1dd@news.povray.org>
Tim's solution is most likely the best, but if you're looking for a quick
solution and you're not worried about speed, then you might just want to
#declare a triangle and trace() a ray towards it.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 8 Nov 2004 16:23:53
Message: <418fe3e9$1@news.povray.org>
Uh... dude... how the HELL do you calculate the angle between vectors?? :-S
(I had already figured out how to test if the line passes through the
plane of the triangle. Whether it goes through the triangle itself...?)
Actually, here's a thought... What if a take the dot product of point C
against the vector from A to B? Then I take the dot product of the point
where the line intersects the plane. If the answer has the same sign but
is nearer to zero, then I can do the same check with the other pair(s)
of points...
Maybe that could work...
Andrew.
Date: 8 Nov 2004 16:27:12
Message: <418fe4b0@news.povray.org>
> of points...
Uh... no... that's NOT going to work...
What I want is a vector *perpendicular* to AB, but still in the same
plane as the triangle... :-S
Date: 8 Nov 2004 16:38:15
Message: <418fe747$1@news.povray.org>
Inverse trigonometric operations are slow.
Try this search:
http://www.google.com/search?q=efficient+line+triangle+intersection
Tor Olav
http://subcube.net
http://subcube.com
Date: 8 Nov 2004 16:42:49
Message: <vppvo0ljvc5nobs4q75c4fhb63ueaj3l3t@4ax.com>
On Mon, 08 Nov 2004 21:26:38 +0000, Andrew the Orchid <voi### [at] devnull> wrote:
do a cross vector between triangle edges. This makes vector S perpendicular to
triangle. Now, do a cross vector between S and edge AB and you have vector to
AB and again on the plane of trinagle. Is that readable ?
Writing it blindly and without handling special cases:
#macro DoIt(A,B,V1,V2,V3) /* point and triangle */
  #local AB = B-A;
  #local P1 = V2-V1;
  #local P2 = V3-V1;
  #local S = vcross(P1,P2);
  #local P = vcross(S,AB);
  (P)
ABX
Date: 8 Nov 2004 17:06:20
Message: <418feddc@news.povray.org>
> Try this search:
Was about to try something even more complex and longwinded. But the
very first link gives me this:
Plane thru A, B, C is given by
   P(u, v) = A + u*AB + v*AC
Line thru J, K is given by
   L(t) = J + t*JK
Intersection of P and L is I=L(t) where
   t = N . (A - P) / N . (Q - P)
u,v coordinate of I is
   u = AI . (N x AC) / AB . (N x AC)
   v = AI . (N x AB) / AC . (N x AB)
(N = normal of the plane).
Finally, the point lies within the triangle iff
   u >= 0
   v >= 0
   u+v <= 1
Add to that a check in case the line and triangle are perpendicular -
and anoter check because I want my line to be finite length (check that
0<=t<=1) and we're done! Ha!
Andrew.
Date: 8 Nov 2004 17:22:58
Message: <418ff1c2$1@news.povray.org>
#macro TestIsect(A, B, C, P, Q)
   #local AB = B - A;
   #local AC = C - A;
   #local N = vcross(AB, AC);
   #local PQ = Q - P;
   #local _t = vdot(N, A - P) / vdot(N, PQ);
   #local Isect = ((_t >= 0) & (_t <= 1));
   #if (Isect)
     #local I = P + PQ*_t;
     #local AI = I - A;
     #local J = vcross(N, AB);
     #local K = vcross(N, AC);
     #local _u = vdot(AI, K) / vdot(AB, K);
     #local _v = vdot(AI, J) / vdot(AC, J);
     #local Isect = ((_u >= 0) & (_v >= 0) & (_u + _v <= 1));
   Isect
Andrew.
PS. Annoying that I have to put the underscores on those variable
names... grrr!
Date: 8 Nov 2004 17:38:29
Message: <418ff565$1@news.povray.org>
>> Try this search:
>   L(t) = J + t*JK
>   u >= 0
>   v >= 0
>   u+v <= 1
Yes that looks elegant.
When I sit down and figure out such things myself,
I continue until the solution is as simple as I
can manage to make it.
If it then does not look elegant, then it's probably
not the best solution.
Tor Olav
http://subcube.net
http://subcube.com
Date: 8 Nov 2004 17:59:35
Message: <418ffa57$1@news.povray.org>
Andrew the Orchid nous apporta ses lumieres ainsi en ce 2004-11-08
17:22... :
> Andrew.
> names... grrr!
Use Upercase then you don't need those underscores.
Date: 8 Nov 2004 23:34:44
Message: <cjameshuff-44B729.23344508112004@news.povray.org>
In article <418fe747$1@news.povray.org>,
In POV, the difference between an inverse trig operation and any other
operation is likely to be overwhelmed by the overhead of parsing the
script. Code that is simpler to parse is likely to be faster.
http://tag.povray.org/
Date: 9 Nov 2004 07:55:40
Message: <4190be4c$1@news.povray.org>
Yes, I know.
I thought it was a general mathematic question.
Tor Olav
http://subcube.net
http://subcube.com
Date: 9 Nov 2004 15:14:51
Message: <4191253b$1@news.povray.org>
>> names... grrr!
The idea is to use upercase for vectors and lowercase for scalars...
But yes, that would also work of course.
Andrew.
(I understand not being able to use "x", "y" and "z", but "t"? That's
not even *valid* as a token by itself...)
Also vaguely irritating is the need to wrap Boolean assignments with
brackets, but still...
Date: 9 Nov 2004 15:21:09
Message: <3j92p01fa2rf6oc4vj9g6t9h3g54id0c83@4ax.com>
On Tue, 09 Nov 2004 20:14:17 +0000, Andrew the Orchid <voi### [at] devnull> wrote:
http://www.povray.org/documentation/view/3.6.1/229/
  VECTOR_BUILT-IN_IDENT:
       x | y | z | t | u | v
and later
  2.2.1.4.3 Operators
and then try
#declare V=<1,2,3,4>;
#declare Vt=V.t;
ABX
Date: 9 Nov 2004 15:22:52
Message: <4191271c@news.povray.org>
> and later
>   2.2.1.4.3 Operators
> and then try
> #declare Vt=V.t;
Oh, sure... V.t is a perfectly valid expression. But - unlike "x" / "y"
/ "z", "t" by itself isn't a valid expression.
Date: 9 Nov 2004 15:29:12
Message: <2s92p0hivb564ku67h24vehqqnn6u6qi74@4ax.com>
On Tue, 09 Nov 2004 20:22:17 +0000, Andrew the Orchid <voi### [at] devnull> wrote:
Look later into "2.2.1.4.6 Built-in Constants"
All built-in vector identifiers never change value. They are defined as though
the following lines were at the start of every scene.
 #declare x = <1, 0, 0>;
 #declare y = <0, 1, 0>;
 #declare z = <0, 0, 1>;
 #declare t = <0, 0, 0, 1>;
 #declare u = <1, 0>;
 #declare v = <0, 1>;
ABX
Date: 9 Nov 2004 15:42:35
Message: <41912bbb$1@news.povray.org>
Well... you learn something every day... I never knew you could do that...
