POV-Ray : Newsgroups : povray.advanced-users : Black spots in PR 3.6 radiosity Server Time
4 Nov 2026 16:05:08 EST (-0500)
  Black spots in PR 3.6 radiosity (Message 1 to 7 of 7)
Subject: Black spots in PR 3.6 radiosity
Date: 14 Sep 2004 15:27:27
Message: <4147461f$1@news.povray.org>
Hi all,
I have a problem with POV Ray 3.6 and radiosity. Random black spots appear
that aren't there when I render the same file in 3.5
Take a look at this file (PR 3.6)
http://www.brickshelf.com/gallery/jeroendehaan/Renders/povray360.jpg
and this (PR 3.5)
http://www.brickshelf.com/gallery/jeroendehaan/Renders/povray350.jpg
These are the radiosity settings:
 global_settings {
          max_trace_level 20
          radiosity {
            brightness 1
            count 300
            distance_maximum 100
            error_bound 0.25
            gray_threshold 0.50
            low_error_factor 0.775
            minimum_reuse 0.015
            nearest_count 8
            recursion_limit 1
and for the colours:
#declare lg_color_B00 = texture {
   pigment { rgbft <0, 0.0749999999999997, 0.9, 0, 0> }
   normal { bumps .01 scale .10 turbulence 0  }
   finish {
      ambient .0
      diffuse 1
      brilliance 1
      phong 1 phong_size 40
      specular 1
      reflection { .05 falloff 1 exponent 1 }
      conserve_energy
This is for blue. All the colours use the same normal and finish.
Is it me, a wrong setting or a "bug" in 3.6?
Jeroen de Haan
If you want the complete file please e-mail me on infor at digitalbricks dot
nl
Subject: Re: Black spots in PR 3.6 radiosity
Date: 14 Sep 2004 15:40:03
Message: <ci7h7l$iqf$1@chho.imagico.de>
jeroen de haan wrote:
> Hi all,
What makes you think this has anything to do with radiosity?
Apart from that a minimal test scene will of course be required to check
this.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 14 Sep 2004 16:31:24
Message: <4147551c@news.povray.org>
news:ci7h7l$iqf$1@chho.imagico.de...
> > Hi all,
appear
> this.
Here is a no radiosity test from PR 3.6:
http://www.brickshelf.com/gallery/jeroendehaan/Renders/kraanpovray36noradiosity.png
Jeroen
Date: 14 Sep 2004 16:57:07
Message: <41475b23$1@news.povray.org>
A similar problem was mentioned by Michael Raiford on 6/13/2004 12:20 AM in
povray.binaries.images. I don't think a solution was found, though the
consensus seemed to be that it was related to media-radiosity interaction.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 15 Sep 2004 07:53:44
Message: <41482d48@news.povray.org>
>  - Slime
This seemed to happen in scenes that contained radiosity+scattering
media+spotlights. At least for me, this is the situation I ran across.
~Mike
Date: 15 Sep 2004 10:36:18
Message: <41485362$1@news.povray.org>
"jeroen de haan" <inf### [at] digitalbricksnl> a écrit dans le message de
news:4147461f$1@news.povray.org...
Could you try to remove the reflection statement (particularly the exponent)
to see if it works. It solved a vaguely similar problem for another user
(see the last messages in povray.beta-test.binaries). I came upon the
black-dots-in-radiosity-scene-issue myself (though I solved it eventually by
using another object as I was a little bit in a hurry...).
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 15 Sep 2004 12:00:02
Message: <ci9onl$j52$1@chho.imagico.de>
Note the exponent is 1 which is default.  The bug report you cited had
trouble with non-default just like the scene using crand Bob Hughes
showed some time ago.  Apparently the changes made to prevent those
problems did not completely slove it, the code applying the exponent
should always check for the argument being below zero.  But i have never
seen the same problem with exponent 1 (and if you have a scene showing
this please post it).
