POV-Ray : Newsgroups : povray.advanced-users : Normal distribution Server Time
10 Apr 2026 21:59:46 EDT (-0400)
  Normal distribution (Message 1 to 10 of 13)
Subject: Normal distribution
Date: 5 May 2004 17:01:21
Message: <40995621@news.povray.org>
POV-Ray's random number generator gives uniformly distributed real numbers.
Any idea how to transform these into normally distributed numbers?
Andrew @ home.
Subject: Re: Normal distribution
Date: 5 May 2004 17:14:10
Message: <40995922@news.povray.org>
  Actually no. It gives uniformly distributed real numbers between 0 and 1,
which is a slightly different thing.
  (And we can also split hairs by noting that floating points numbers aren't
real numbers but a finite set of rational numbers, but would not be relevant
here... :) )
  You can approximate a normal distribution of numbers between 0 and 1
by taking the sum of n equally-distributed numbers and dividing the
result by n. The higher the n, the more closely it resembles normal
distribution, but for practical purposes you don't need a very large n.
Even n=3 already gives a pretty good distribution.
Date: 5 May 2004 17:16:35
Message: <409959b3@news.povray.org>
(which are between 0 and 1, of course)
Date: 5 May 2004 18:15:35
Message: <Xns94E12A3B686Eseed7@news.povray.org>
From "rand.inc"
Rand_Normal(Mu, Sigma, Stream). Normal distribution.
Parameters:
Mu = Mean.
Sigma = Standard deviation.
Stream = Random number stream.
Rand_Gauss(Mu, Sigma, Stream). Gaussian distribution. Like Rand_Normal
(), but a bit faster.
Parameters:
Mu = Mean.
Ingo
Date: 5 May 2004 21:47:07
Message: <4099991b$1@news.povray.org>
-[You can approximate a normal distribution of numbers...]-
...but this is an inefficient method. The standard method is the Box-Muller
transform, given here in C.
float v1,v2,rsq,fac;
do
  v1=rand()*2.0-1.0; v2=rand()*2.0-1.0;
  rsq=v1*v1+v2*v2;
} while (rsq>=1.0 || rsq==0.0)
fac=sqrt(-2.0*log(rsq)/rsq);
This generates two independent normal deviates (v1*fac) and (v2*fac) (with
zero mean and unit variance). The "rand()" function here generates uniform
deviates between 0 and 1.
-[...and dividing the result by n]-
Actually, with this method you need to divide by sqrt(n) if you want to keep
the variance independent of n.
-Chris
Date: 6 May 2004 14:49:14
Message: <409a88aa$1@news.povray.org>
Well yeah, but you know what I *mean* ;-)
> here... :) )
True. (I do recall asking how far apart these numbers are, but never
really got an answer...)
...because the means of different samples from a given population are
normally distributed around the true mean of the population? (And the
true mean of a *truely* uniform distribution from 0 to 1 would be 0.5)
Andrew @ home.
Date: 6 May 2004 14:49:41
Message: <409a88c5$1@news.povray.org>
> From "rand.inc"
> Parameters:
> Mu = Mean.
> Parameters:
> Mu = Mean.
Ah... yes, that's easier! ;-)
Andrew @ home
Date: 6 May 2004 16:30:36
Message: <409aa06c@news.povray.org>
-[I do recall asking how far apart these numbers are]-
Pov-ray uses the IEEE double floating point standard (unless you're
compiling it on a DEC VAX or something obscure), which has 52 bits of
fractional precision, which gives about 2^-52 as the distance between random
numbers. However, pov-ray actually uses a 32-bit linear congruential random
number generator, which only uses 32 bits of precision.
-[because the means of different samples from a given population are
normally distributed around the true mean of the population]-
Yes - or rather, they approach a normal distribution as the number in each
sample tends to infinity (the Central Limit Theorem)
-Chris
Date: 6 May 2004 20:32:34
Message: <cjameshuff-486021.19315106052004@news.povray.org>
In article <4099991b$1@news.povray.org>,
If you can easily generate a few random numbers and don't need a very
close approximation, the averaging method can be faster. The problem
isn't really efficiency, it's accuracy...the result isn't all that close
to a normal distribution unless you use lots of points and rescale the
numbers to get out of the range of the original numbers.
In the places where this approximation is used, that is rarely a
problem. It's often more useful to have a known range that the random
numbers are limited to. It's a very fast and easy way to get objects to
bunch up around a point with a roughly Gaussian distribution.
http://tag.povray.org/
Date: 7 May 2004 08:47:28
Message: <cjameshuff-E9E2AE.07464607052004@news.povray.org>
In article <409aa06c@news.povray.org>,
> numbers.
Not quite correct. You're forgetting that floating point numbers are not
fixed point...they're quite a bit more complicated. In addition to the
52-bit plus-one mantissa, IEEE 754 double precision numbers also have an
11 bit exponent, which can go down to -1023 and up to 1024. You end up
with a pretty complex distribution of possible numbers...just how big a
step there is between a value and the next possible larger or smaller
value depends on what that value is.
At most, it may be even less. Assuming it fills the entire 32 bit range,
that gives you 2^32 steps, 4294967296 steps with 2.328306436538696e-10
between each step.
