POV-Ray : Newsgroups : povray.advanced-users : JPG-output with povray for windows v3.5 Server Time
4 Nov 2026 18:45:20 EST (-0500)
  JPG-output with povray for windows v3.5 (Message 1 to 49 of 49)
Subject: JPG-output with povray for windows v3.5
Date: 18 Feb 2004 10:04:18
Message: <40337ef2$1@news.povray.org>
hi everybody.
is there a possibilty to have the output of a render as a jpg file?
because in the message window of povray it says "LibJPEG 6b, Copyright
1998 Thomas G. Lane"... i didn't find a commandline-switch or something
to change the output to jpg, but if it's not possible, why mention the
JPEG-llibrary?
an alternative would be a program i can use in a batchfile to convert
files from bmp to jpg, if possible with low quality loss, like acdsee
does. i need this because i want to make an animation with 1500 frames,
but at 640x480 this would need 900kb per picture, resulting in almost
1.5GB of files. this would not be a problem if i were rendering on my
own pc, but i have to do it on another machine to which i have only slow
access via wlan.
thanks for listening to me, and if this is the wrong newsgroup, please
point me to the right one.
bye
	Marc
Subject: Re: JPG-output with povray for windows v3.5
Date: 18 Feb 2004 10:16:04
Message: <ib07301t7ehcgvibh45fud07geqg53139d@4ax.com>
On Wed, 18 Feb 2004 16:08:31 +0100, Marc Roth <mar### [at] rothconsultcom> wrote:
> hi everybody.
> JPEG-llibrary?
For reading?
http://www.google.com/search?q=site:www.povray.org+JPEG
> does.
IrfanView ?
> 1.5GB of files.
PNG format ?
> access via wlan.
SMPOV ?
http://www.it-berater.org/smpov.htm
ABX
Date: 18 Feb 2004 10:33:42
Message: <403385d6$1@news.povray.org>
>>"LibJPEG 6b, Copyright 1998 Thomas G. Lane"
> For reading?
you got a point there... :)
>>does.
> IrfanView ?
i'll try this one
>>1.5GB of files.
> PNG format ?
i'm not familiar with this format, i thought it was equally uncompressed
>>access via wlan.
i don't think that makes sense, as the connection is not only slow but
also rather buggy, too many frames would get lost... ATM i'm simply
copying the .pov file to the remote machine if i have to render
something big, start up povray, wait, and when it finishes i take some
hours to copy the resulting pictures to my pc
Date: 18 Feb 2004 12:19:09
Message: <40339e8d$1@news.povray.org>
"Darren" <dne### [at] sanrrcom> wrote in message
news:40339bda$1@news.povray.org...
> I'm doing the same thing. I use NETPBM aka PBMPlus. A free set of tools
> for doing all kinds of image manipulation. Have POVRAY output PPM files
> (which is one of the NETPBM formats) and just use PPMTOJPEG to compress
> it. I believe it's available on sourceforge, runs fine on both Windows
> and Unix.
<snip />
I'll throw in my recommendation for netpbm as well. It's a little odd to
learn at first until it snaps in your head how they designed it, but it is
the ultimate conversion utility and it handles damn near every image format
you'll ever see -- and you can make uber MPEG-1 movies with it too. It's
like POV-Ray -- you /can/ find software with fancy interfaces, but you'll
never get the true feeling of power that netpbm will give you (arggh, arggh,
arggh, more power!)
Date: 18 Feb 2004 13:49:12
Message: <cjameshuff-3EBE65.13494818022004@news.povray.org>
In article <403385d6$1@news.povray.org>,
> > PNG format ?
PNG uses lossless compression. The reduction in file size is less than
with lossy formats like JPEG, but you get a perfect reproduction of the
image. It makes a good replacement for GIF, having better compression,
supporting 48 bit color, alpha channels, and file gamma values. It's
also good for archiving images or other situations where you want to
keep full quality.
http://tag.povray.org/
Date: 18 Feb 2004 14:42:16
Message: <4033c018$1@news.povray.org>
In article <403385d6$1@news.povray.org> , Marc Roth <mar### [at] rothconsultcom>
>>>access via wlan.
A WLAN is reliable as any other network as far as deliverly of data is
concerned, it is just slow.  Nothing can get lost or be buggy just because
it is used over a WLAN.
    Thorsten
e-mail: tho### [at] trfde
Date: 18 Feb 2004 15:20:02
Message: <4033c8f1@news.povray.org>
  Are there any other lossy formats than JPEG? ;)
Date: 18 Feb 2004 16:44:54
Message: <4033dcd6$1@news.povray.org>
I just invented one: All files compressed with my format are 0 bytes in
size, and when the image is read, its dimensions and colors are guessed.
I expect this to be in widespread use before long.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 18 Feb 2004 16:45:40
Message: <4033dd04$1@news.povray.org>
>     Thorsten
trust me, i have to use it every day... the problem is, that the walls
in our house are to thick for it to work properly... i made a check via
the ping utility over a week about 20% of the pings didn't arrive
but i do agree that it *should* be as reliable as any other network in a
more common situation ;)
bye,
    Marc
Date: 18 Feb 2004 16:47:24
Message: <4033dd6c$1@news.povray.org>
Dan P wrote:
<snip>
> It's
> arggh, more power!)
sounds good, i'm gonna try it :)
bye,
    Marc
Date: 18 Feb 2004 17:23:27
Message: <4033e5df$1@news.povray.org>
In article <4033dd04$1@news.povray.org> , Marc Roth <mar### [at] rothconsultcom>
A ping is not a reliable way to check network reliability.  Your problems
are more likely due to faulty or incompatible equipment with unreliable
drivers (especially many recent cheap WLAN cards tend to have this problem).
They do not create a WLAN at all.  Throwing away the noname cards and base
station and replacing them with brand name equipment will get rid of such
problems.  Really!
Some of those noname cards cannot keep a network up even if they sit next to
each other!  With brand name hardware it will work just fine and signals
pass at least through two 18 cm reinforced concrete floors and three 25 cm
brick walls (my home setup).  Or work 70 m away from your home.  At least
they did for me in the past four years.  And in many different locations and
setups it also works reliably.  You really need reliable hardware, that is
all ;-)
    Thorsten
Date: 18 Feb 2004 22:50:27
Message: <cjameshuff-E6FF00.22510218022004@news.povray.org>
In article <4033c8f1@news.povray.org>, Warp <war### [at] tagpovrayorg>
MPEG?
Okay, there's no other lossy still image format in common use. Someone
mentioned GIF...it isn't lossy, it's just really limited in the number
of colors it can represent. I can't think of any other lossy formats,
but I know they exist, so I didn't rule them out.
Date: 19 Feb 2004 01:10:58
Message: <sA$DcCAPA+MAFw+5@econym.demon.co.uk>
I believe it's possible to save images as single-frame lossy animations
in various formats, and there are fractal image compression algorithms
like FIF (Fractal Image File).
Mike Williams
Gentleman of Leisure
Date: 19 Feb 2004 04:41:11
Message: <403484b7@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> GIF?
  GIF is a lossless format.
  Granted, it only supports 256 colors, but that doesn't make it a lossy
image format. That makes it only an image format which supports 256 colors.
You can't control the quality of the "lossiness" because there isn't any.
Anything you store in the gif file can be retrieved exactly. Its color
limitation is not a method to pack the image smaller, it's just a limitation.
Date: 19 Feb 2004 04:43:14
Message: <40348532@news.povray.org>
> in various formats
  It would be a keyframe, and AFAIK keyframes are basically a JPEG (more
or less) of the first original frame.
  Agreed, but how many image viewers/manipulation programs have you seen
supporting that? ;)
Date: 19 Feb 2004 04:46:44
Message: <40348604@news.povray.org>
> MPEG?
  If I'm not completely mistaken, an I frame of an mpeg file (which a
1-frame mpeg would be) is basically a jpeg (more or less).
  JPEG2000 is the next version of JPEG (and certainly better), even though
I don't know if you can call it a "different format from JPEG"...
  Does anyone have any idea why JPEG2000 has not widespread even though
it's so much better than JPEG? I have always wondered this and found it
a big pitty.
Date: 19 Feb 2004 06:43:38
Message: <4034a16a@news.povray.org>
In article <40348604@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
It is really much different.  the formats only really have the name in
common.
> a big pitty.
The compression algorithm is far more complex.  And I am not even sure there
is a license free way to use it.  Either way, there is no good, portable
library to read/write it yet.  The IJG JPEG library is kind of a "standard"
for JPEG on the other hand.
    Thorsten
Date: 19 Feb 2004 07:51:36
Message: <cjameshuff-6730E0.07521119022004@news.povray.org>
In article <40344a95$1@news.povray.org>, Darren New <dne### [at] sanrrcom>
wrote:
> True, it depends on how many colors you're trying to represent. Given
> this is a ray-tracing newsgroup and GIF only supports 256 colors, I
> think it's safe to say it's lossy. ;-)
Not lossy, just very coarsely quantized. If you call that lossy, than
every possible representation of the image is lossy. The term "lossy"
refers to the compression algorithm used, and the method used by GIF
lets you retrieve exactly the same values you put in: it's lossless.
Date: 19 Feb 2004 08:07:32
Message: <4034b514@news.povray.org>
I think he was attempting to add some humor into his reply: since we're
dealing with POV-Ray and thus, mainly 16 to 32 bit images, 256 colors would
be a loss, and thus, GIF would be "lossy" for saving the output-images.
Technically, you're right, on a humoristic level, he's right. :-)
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 19 Feb 2004 09:19:43
Message: <4034c5ff@news.povray.org>
  Then every existing image format is lossy because POV-Ray calculates
the color components as 32-bit floats. Converting them eg. to
8 bits-per-component or even 16 bits-per-component image (eg. PNG)
is lossy.
Date: 19 Feb 2004 10:59:37
Message: <4034dd69@news.povray.org>
In article <4034c5ff@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> is lossy.
I would not be surprised if floating-point colors were part of some TIFF
format specification ;-)
    Thorsten
Date: 19 Feb 2004 13:56:56
Message: <403506f7@news.povray.org>
> Technically true, but since your eyes have a very difficult (if not
> impossible) time distinguishing more than 8 bits of color, one could
> argue differently too. :-)
  Actually for B/W images 8 bits can sometimes be too little, specially
when dealing with large areas of very slowly changing shades of gray.
Date: 19 Feb 2004 15:48:31
Message: <4035211f$1@news.povray.org>
To add to that: I'm on 32bit for my Desktop, because I'm seeing bands of
colors when using only 16bit with my raytraced images (which is hence the
reason why I output to 24bit BMP most of the time). Since Windows offers me
only 16 or 32, I'm on 32.
Tim
"Tim Nikias v2.0"
Date: 19 Feb 2004 15:59:01
Message: <40352395$1@news.povray.org>
me
And eventhough you are using 32-bit mode, you see only 24-colors, unless you
have some specialiced video card. I also agree that 8-bits/channel is way
too little with color gradations. And for editing purposes 16-bit/channel is
sometimes mandatory. Sadly there are not many (consumer grade) video cards
showing 48-bit colors.
Severi
Date: 19 Feb 2004 16:55:40
Message: <v3ca301hage8ai0djo6divhvsn364rifp3@4ax.com>
On Wed, 18 Feb 2004 21:33:09 -0800, Darren New <dne### [at] sanrrcom>
It's close to black & white, isn't it?
Andreas
Date: 19 Feb 2004 19:13:43
Message: <cjameshuff-F3536F.19142019022004@news.povray.org>
In article <4035211f$1@news.povray.org>,
Why BMP? You should use PNG...aside from the compression, it stores the
gamma value in the file, and lets you save images in 48 bit...16 bits
per channel, or 65536 levels per channel instead of 256.
Date: 19 Feb 2004 19:19:08
Message: <cjameshuff-5524B6.19194519022004@news.povray.org>
In article <40352395$1@news.povray.org>,
"32 bit color" is just 24 bit color with an extra byte every 3 bytes.
This keeps memory nicely aligned, but contributes nothing to the color
precision. It's just a memory/speed tradeoff, though the fourth value is
often used for things like alpha.
You don't necessarily need to view it to get a benefit from it.
Date: 19 Feb 2004 19:27:58
Message: <cjameshuff-E5DC6E.19283519022004@news.povray.org>
In article <4034dd69@news.povray.org>,
There is...96 bits per pixel. Not often used for this reason...a
1600x1200 image would take 21MB. There are other formats that use about
half as much. They do so with less precision, but 32 bits per component
is overkill for most things.
Date: 19 Feb 2004 20:15:03
Message: <40355f97$1@news.povray.org>
Well, for one, I can use BMP directly as wallpaper on my Windows OS. I don't
need more than the 24bit it comes with, that's another. And, most of the
time, the image gets converted to JPG anyway, either for posting on these
very newsgroups that I've got open and running almost every hour my PC is
running, or for my website. Only seldomly do I need other formats, like for
a book publishing. And even then, 24bit was sufficient so far.
So, though your points are valid and true, I'm too lazy. :-)
But I've never really understood that gamma issue with PNGs... How exactly
does it work, and how is it supposed to work? I've heard that it stores the
gamma value it has been made with, and a viewing app would adjust the gamma
to compensate for different screens, but does it really work?
"Tim Nikias v2.0"
Date: 20 Feb 2004 04:46:58
Message: <4035d792$1@news.povray.org>
>>is lossy.
     Or maybe FITS standard for astronomical pictures ?
Date: 20 Feb 2004 06:13:32
Message: <4035ebdb@news.povray.org>
  Not if you want to perform post-processing of POV-Ray images... :)
  (And btw, wouldn't them be useful for HDRI images?)
Date: 20 Feb 2004 10:59:34
Message: <40362ee6$1@news.povray.org>
that may be true, but the network can't be stable if even a ping can't
get through for a lot of the time...
> all ;-)
i think d-link isn't such a noname brand ;) and there shouldn't be any
incompatibilities between products of one brand which were designed to
be used together, as the whole wlan-network is based on d-link hardware.
the only thing i can think of as a roblem, except for the walls would be
  the OS used on the server machine. currently i'm using win2k pro sp4,
but it may be too hard for windoze to handle 3 network interfaces at the
same time (1 wlan, 1 lan, 1 internet) i really would like to use linux
for server purposes, but i'm not familiar enough with it to ensure 100%
uptime, and as my father uses the server for his company, this is not
acceptable :( (he has no problems BTW with the network, as he is
connected via lan...)
bye,
     Marc
and god said: let there be a light_source { location SUN look_at EARTH,
rgb SUNLIGHT }
Date: 20 Feb 2004 11:17:00
Message: <cjameshuff-EAF963.11173720022004@news.povray.org>
In article <4035ebdb@news.povray.org>, Warp <war### [at] tagpovrayorg>
Depends...most processing is unlikely to benefit much from the greater
precision, and it uses more memory. ILM uses a half-precision 16 bit
format...a sign bit, a 5-bit exponent, and 10 bit mantissa.
Hmm...there's nothing stopping you from putting those half-precision
float values in a 48-bit PNG image, though they won't display properly
in any PNG reader. FNG? Even has a nice pronunciation: FaNG
Date: 20 Feb 2004 13:38:11
Message: <cjameshuff-E11E6F.13384920022004@news.povray.org>
In article <40355f97$1@news.povray.org>,
And as I recall, Windows only accepts BMP files for this, right?
Stupid...Mac OS allows anything QuickTime can open: JPEG, PNG, GIF,
TIFF, etc.
> I don't
But the smaller file size isn't a benefit?
That's what it does, and it does work...if the software displaying the
PNG handles the gamma value. I don't know how common that is...
Date: 20 Feb 2004 14:04:37
Message: <40365a45$1@news.povray.org>
> TIFF, etc.
Windows XP supports BMP, GIF, JPEG, PNG and DIB (?) for background images.
 - Slime
Date: 20 Feb 2004 15:28:00
Message: <40366dd0@news.povray.org>
In article <40362ee6$1@news.povray.org> , Marc Roth <mar### [at] rothconsultcom>
Indeed, they should work.  Of course, you are out of luck if somebody else
nearby is using noname hardware...
If you get a chance, try XP.  It might work better as it came out after
WLANs were popular, rather than before.
Alternatively, I would strongly recommend use a real WLAN router.  Those
routers (for around US$ 100 you get really good and feature-rich ones these
days) usually have a few ethernet connectors, a WLAN interface and an
ethernet interface for the external network connection (i.e. a DSL or cable
modem, some even include a modem or ISDN interface or at least a serial
port).  And these routers can be configured via a web browser from the
inside of the network easily.
Even more important, you can hide the Windows system behind a firewall and
only expose selected ports (i.e. if you run a web server on the Windows
system you would only expose port 80).  Especially a Windows box connected
directly to the internet is a problem these days with all the viruses
floating around.  Even more so if you also store important or private data
on the Windows system!
As far as using Linux is concerned, a server exposed to the internet indeed
requires a good understanding of Linux to really configure right.  So a
router is probably the better choice.  And a router also does not go offline
if the Windows system crashes.
    Thorsten
Date: 20 Feb 2004 16:23:38
Message: <40367ada@news.povray.org>
> No. You just have to turn on "active desktop", after which Windows will
> accept as background anything IE can display, including web pages
> dynamically refreshed.
But who would want to use Windows IE for wallpaper reasons with all the
security leaks..? That aside, Active Desktop threw up on me several times.
So I just use BMP.
"Tim Nikias v2.0"
Date: 20 Feb 2004 16:24:47
Message: <40367b1f$1@news.povray.org>
Windows 2000 is running here. Don't like XP. Mainly because the newer the
Windows version, the higher the hardware it requires to run as smoothly as
the predecessor running the same apps...
"Tim Nikias v2.0"
Date: 20 Feb 2004 16:35:28
Message: <40367da0@news.povray.org>
> TIFF, etc.
Yup. I know, it sucks. Linux accepts all kinds of images as well, which is
kinda fun, especially with neato effects. :-) But most of my software
requires Windows, and I'm not yet that much into Linux as if I could switch.
It would be, if it'd be needed. I've got several GBs to spare, so rendering
at BMP isn't a threat. Additionally, I do almost no post-processing on my
images, so I can just keep the source-code. Most of my images render in
under a few hours, so that's sufficient. Those that don't... Well, just a
little more patience required. That aside, I regularly update my hardware,
so after a year or so, images render even faster than initially. In a sense,
I don't have to keep as many images as I do, and for lazy reasons I keep
them in BMP to use them as wallpapers.
There are good arguments to use a different format, I don't deny that. It's
just much easier this way in my current PC situation. Why go through the
hassle of converting images everytime I want a new wallpaper? It's that
simple. :-)
That all aside: is the PNG compression Povray uses the optimum? I've found
that I could use Paint Shop Pro to convert the images to even smaller PNG
images and didn't notice any loss. Maybe I should experiment again and see
why PSP was able to reduce the size, but perhaps there's an issue with
output from POV-Ray to disk that can't be overcome that easily? I've got no
clue how the PNG-specs are, so maybe POV could save space if it would save
the PNG once it knows how the image looks like, but this isn't done for
buffering reasons etc. Just curious.
Me neither, that why I was asking. I wouldn't notice any difference on my
own PC of course, and the PC's I normally have access to are much like my
own (Screenwise), so I wasn't able to check on that yet, and also wasn't
required to work around such an issue. But we all know of the "too dark"
comments on binaries.images... I rarely do dark images, so I've had that
problem only once or twice here.
Tim
"Tim Nikias v2.0"
Date: 20 Feb 2004 19:25:39
Message: <4036a583@news.povray.org>
might be a good idea but as the server is used for my fathers company it
should only use legally obtained software and buying a new OS is for my
father, as his part of the networks works quite well, not an option...
see above :(
about viruses there should be no problem, the server has a norton
antivirus & firewall with uptodate virusdefinitions and only ports that
are neccessary are opened.
i know that windows is supposed to be crashing rather frequent but our
server usually keeps running over some months before a reboot is needed,
maybe by some new security update or something like this... and this
means maximum 3min downtime, which is acceptable IMO
bye,
	Marc
rgb SUNLIGHT }
Date: 21 Feb 2004 02:06:29
Message: <Xns94961539F4D0Ctomatimporg@203.29.75.35>
"Tim Nikias v2.0" <tim.nikias (@) nolights.de> wrote in
news:40367da0@news.povray.org:
>> TIFF, etc.
> which is kinda fun, especially with neato effects. :-) But most of my
> software requires Windows, and I'm not yet that much into Linux as if
> I could switch.
> rendering at BMP isn't a threat. Additionally, I do almost no
> post-processing on my images, so I can just keep the source-code. Most
> of my images render in under a few hours, so that's sufficient. Those
> that don't... Well, just a little more patience required. That aside,
> I regularly update my hardware, so after a year or so, images render
> even faster than initially. In a sense, I don't have to keep as many
> images as I do, and for lazy reasons I keep them in BMP to use them as
> wallpapers.
> It's just much easier this way in my current PC situation. Why go
> through the hassle of converting images everytime I want a new
> wallpaper? It's that simple. :-)
> found that I could use Paint Shop Pro to convert the images to even
> smaller PNG images and didn't notice any loss. Maybe I should
> experiment again and see why PSP was able to reduce the size, but
> perhaps there's an issue with output from POV-Ray to disk that can't
IIRC, POV does line by line compression, and PSP compresses all lines at
once.
Tom
The Internet Movie Project
http://www.imp.org/
Date: 14 Jan 2005 21:27:22
Message: <41e87f8a$1@news.povray.org>
Thorsten Froehlich nous apporta ses lumieres en ce 2004-02-19 06:43:
> common.
>>a big pitty.
>     Thorsten
Looking back at old posts.
With the free jpeg2000 you can save only small images (640*480 or less). For anything
larger, you
need to pay a licencing fee.
Date: 16 Jan 2005 21:39:21
Message: <cjameshuff-92A37C.21393016012005@news.povray.org>
In article <41e87f8a$1@news.povray.org>,
> anything larger, you need to pay a licencing fee.
Yuck. Is this for commercial software only, or for all software?
Well, I think all the important LZW patents have expired now, so aside
from PNG there's LZW compressed TIFF, which got slightly better
compression than PNG on most of the images I tested, and is quite a bit
more flexible.
Date: 17 Jan 2005 05:55:10
Message: <41eb998e$1@news.povray.org>
Christopher James Huff nous apporta ses lumieres en ce 2005-01-16 21:39:
For all of them! Pay or freeware. And the licence is prety expencive.
Date: 17 Jan 2005 07:12:38
Message: <41ebabb6@news.povray.org>
> more flexible.
  There's no one single way of making lzw encoding (even though the result
is decodable with any regular lzw decoder). Some programs do a better job
than another. You should definitely not trust some random image editor to
give you the best possible png compression ratio because they usually don't.
  Run the png through pngcrush and advpng and then compare it to the tiff.
Date: 17 Jan 2005 08:08:40
Message: <41ebb8d8@news.povray.org>
In article <41eb998e$1@news.povray.org> , Alain <ele### [at] netscapenet>
I don't know where you got this information, but it is incorrect:
<http://www.jpeg.org/faq.phtml?action=show_answer&question_id=q3f042a68b1081
Baseline JPEG 2000 is free just like baseline JPEG is free.
    Thorsten
Date: 17 Jan 2005 14:10:33
Message: <cjameshuff-08C5F5.14105017012005@news.povray.org>
In article <41ebabb6@news.povray.org>, Warp <war### [at] tagpovrayorg>
PNG is not LZW, it's the older LZ77 compression, which was unencumbered
by patents when it was chosen. I was comparing LZ77 PNGs with LZW TIFFs.
The TIFFs came out consistently smaller...not much, but not by an
insignificant amount either.
I did use pngcrush, but not advpng. The PNG images were compressed about
as well as is possible, the TIFF images were unoptimized.
Date: 17 Jan 2005 17:02:41
Message: <41ec3601$1@news.povray.org>
Thorsten Froehlich nous apporta ses lumieres en ce 2005-01-17 08:08:
>     Thorsten
At least this one is asking a fee, whitch cam be steep:
http://www.luratech.com/shop/index.jsp?categoryKey=27&OnlineShopId=798491105998585283
Up to US$8400
Date: 17 Jan 2005 17:58:17
Message: <41ec4309@news.povray.org>
In article <41ec3601$1@news.povray.org> , Alain <ele### [at] netscapenet>
998585283
> Up to US$8400
It is not a *license* for JPEG 2000 they are selling.  All they are selling
is their library to read/write JPEG 2000 files.  That is something entirely
different.
    Thorsten
