POV-Ray : Newsgroups : povray.advanced-users : Some math aid required... Server Time
28 Jul 2026 12:10:20 EDT (-0400)
  Some math aid required... (Message 15 to 24 of 24)
Subject: Re: Some math aid required...
Date: 10 Feb 2004 14:42:24
Message: <402933DF.9090504@hotmail.com>
> The slope of the tangent is simply the derivative, the rate of change at
> the given point. Unless I've screwed up the math somewhere, that would
> be:
> P1*3*(1 - t)^2*(-1) +
> P2*3*(2*(1 - t)*(-1)*t + (1 - t)^2) -
> P3*3*(2*t*(1 - t) - t^2) +
> P4*3*t^2
> simplified:
> 3*(P2 - P1 + (P1 - 2*P2 - P3)*2*t + (P2*3 + P3*3 + P4 - P1)*t^2)
> (somebody want to check that?)
3*(P2 - P1 + (P1 - 2*P2 + P3)*2*t + (-P1 + P2*3 - P3*3 + P4)*t^2)
	Andrel
Date: 10 Feb 2004 15:22:15
Message: <cjameshuff-90A371.15223610022004@news.povray.org>
In article <402### [at] hotmailcom>,
Well, that doesn't work. The resulting lines are close, but not quite
tangent. My results look right, any errors are small ones.
http://tag.povray.org/
Date: 10 Feb 2004 15:34:26
Message: <40294052$1@news.povray.org>
> Well, as far as I can tell, the second method Sascha gave is identical
> to the one I gave, though expressed a bit differently. I'm not sure
> what's going on with the first method...but I think it's mathematically
> equivalent, just a shortcut. I'm going to have to look at it further...
It works, now that I've cleaned the code and found some stupid mistakes I
made... As I understand it, instead of interpolating between four points
with a cubic, I interpolate with three points with a squared function. I
guess there's some more fundamental background behind this (perhaps googling
Bernstein might help, who knows), but I'm not in the mood right now to dig
into math. Perhaps tomorrow, when I'm less lazy and getting more and excited
with Povray again.
SNIP [some Math Stuff]
Ah, now I understood what you were aiming at. Yes, that should work, too.
But honestly, that "shortcut", as you called it, looks nice and slick in
code, whereas the "simplified" model looks pretty ugly. Unless... Taking a
long shot here, but I guess you could adjust the formula so that it ends up
looking like the one Sascha gave...
Ah well, tomorrow is time for math-fun. Today, my brain is already spent
(well, most of it).
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 10 Feb 2004 16:17:44
Message: <cjameshuff-F597F7.16180510022004@news.povray.org>
In article <40294052$1@news.povray.org>,
Well, yes, the derivative of the cubic spline is a quadratic function.
It doesn't interpolate between those three points though...its value at
one of those points is not the value of that point, it is the slope of
the tangent line at that point. It appears to be something like a
quadratic interpolation of the tangents formed by the control points...
Again, that was only a simplified expression of the equation of the
derivative. The term "simplified" has nothing to do with how simple it
is compared to other solutions.
B0(t) = (1 - t)^2
B1(t) = 2*t*(1 - t)
B2(t) = t^2
n0 = p1 - p0
n1 = p2 - p1
n2 = p3 - p2
n(t) = n0*B0(t) + n1*B1(t) + n2*B2(t)
(p1 - p0)*(1 - t)^2 + (p2 - p1)*2*t*(1 - t) + (p3 - p2)*t^2
But this does not work at all...
Date: 11 Feb 2004 03:05:23
Message: <4029e243$1@news.povray.org>
Christopher James Huff wrote:
> B0(t) = (1 - t)^2
> B1(t) = 2*t*(1 - t)
> B2(t) = t^2
> n0 = p1 - p0
> n1 = p2 - p1
> n2 = p3 - p2
Sure it does!
Take a look at the image at http://192.94.226.61/decasteljau.png
it shows a bezier curve defined by p0,p1,p2,p3 and the deCasteljau construction
of point P at t = 3/4 (just as an example).
The tangent through P is, as we can see, the vector b - a.
Ok, let's take a closer look:
first, let's construct the points x,y and z
x = p0(1-t) + p1t
y = p1(1-t) + p2t
z = p2(1-t) + p3t
now we can construct a and b
a = x(1-t) + yt =
  = p0(1-t)^2 + p1t(1-t) + p1(1-t)t + p2t^2 =
  = p0(1-t)^2 + p1*2t(1-t) + p2t^2
b = y(1-t) + zt =
  = p1(1-t)^2 + p2t(1-t) + p2(1-t)t + p3t^2 =
  = p1(1-t)^2 + p2*2t(1-t) + p3t^2
our tangent is b - a =
  = p1(1-t)^2 + p2*2t(1-t) + p3t^2 - p0(1-t)^2 - p1*2t(1-t) - p2t^2 =
  = (p1-p0)(1-t)^2 + (p2-p1)*2t(1-t) + (p3-p2)t^2
Q.E.D
Date: 11 Feb 2004 04:19:54
Message: <4029F379.9060901@hotmail.com>
> tangent.
Are you sure? I have used this myself and when I used it
the tangents were correct. Note also the symmetries in the
coefficient, the binomial coeeficients and the nice alternating
signs. I think the original error may be in the line:
 > P2*3*(2*(1 - t)*(-1)*t + (1 - t)2) -
In my deriviation the final '-' is a '+'. BTW, I derived the
equations in the same way as you did. Well, of course, we both
have the same sort of math training I suspect :).
completely aside:
I had to compute the tangents when trying to
understand where some of my apparently discontinuous
normals in bezier patches come from. To check what I
would expect against the POV source I  manually
constructed a subdivision in smooth triangles. For
this I needed the local normal in the vertices of the
subdivided patch. The result was nearly identical to
the POV version and remaining differences the result
of round off errors. Conclusion: there is nothing
wrong with mor mine nor POVs calculations. I only
still have these images with discontinuous normals
in bezier patches that I can prove to be continuous.
In short: I an still absolutely confused about this.
But that is life I suspect :)
To be continued someday, but todat I have to work
a bit first.
What equations did you use in the end?
Date: 11 Feb 2004 08:33:53
Message: <cjameshuff-1E9AC1.08341411022004@news.povray.org>
The one at the very end? That was in the original equation:
P1*(1 - t)^3 +
P2*3*(1 - t)^2*t -
P3*3*t^2*(1 - t) +
P4*t^3
If that's wrong, than the original equation is too. If you're talking
about something in that term, the Maxima result is: 3*P2*(1 - t)^2 -
6*P2*(1 - t)*t
3*P2*((1 - t)^2 - 2*(1 - t)*t)
3*P2*(-2*(1 - t)*t + (1 - t)^2)
Which agrees with my result.
As for training, I'm currently slogging my way through Calculus II, and
am mainly self-taught. I'm still mainly teaching myself, due to the fact
that the instructor can't speak clear English or write legibly. I'm also
taking Numeric Analysis, which may cover splines later this semester.
a():=0.1; b():=0.9; c():=0.2; d():=1;
(Defined as functions because I couldn't figure out how to define them
as variables in Maxima...damned annoying program, with practically
useless documentation.)
f(t):=a()*(1 - t)^3 + b()*3*(1 - t)^2*t - c()*3*t^2*(1 - t) + d()*t^3;
fd(t):=3*(b() - a() + (a() - 2*b() - c())*2*t + (b()*3 + c()*3 + d() -
a())*t^2);
tgt(t, p):= (t - p)*fd(p) + f(p);
plot2d([f(t), tgt(t, 0.2), tgt(t, 0.5), tgt(t, 0.9)], [t, 0, 1]);
Date: 11 Feb 2004 09:19:40
Message: <402A39BB.7010809@hotmail.com>
> P1*(1 - t)^3 +
> P2*3*(1 - t)^2*t -
> P3*3*t^2*(1 - t) +
> P4*t^3
Sorry, I did not check all your equations, I should have.
You are absolutely right here, your original equation
is wrong. There should not be a minus there either ;)
> If you're talking
I had never heard of Maxima, just googled it.
Perhaps I give it a try someday.
off-topic: Mostly I do the math required for POV by hand.
For years I did not do as much math as I do now. Sometimes
I even try to convince people that POV is an interesting
kind of application for learning math at a highschool level.
You often want to achieve some goal and the only way to do
it is sit down and do the equations. Along the same line,
if someone asked me why that should learn math at highschool
one of my answers is: to be able to create realworld
objects in POV!
	Andrel
Date: 11 Feb 2004 11:48:18
Message: <cjameshuff-576C46.11483911022004@news.povray.org>
Well, that would explain why my equation works for finding tangents to
it, but yours doesn't. Thought it looked odd...
Mostly I program the computer to do it for me. I'm terrible at that kind
of thing, always making arithmetic errors and simple little stuff like
that...at least it wasn't me this time.
> objects in POV!
It is a very good way of learning how the math applies to and relates to
the real world, or at least approximations of it.
Date: 11 Feb 2004 12:59:20
Message: <402a6d78@news.povray.org>
Tim Nikias v2.0 wrote:
> so, I've got the following formula to calculate Bezier-Splines:
> Anyways, I need to calculate the direction/tangent of the spline at any
> given position.
I suggest that you go googling for "Frenet Frames"
Look for web pages similar to this norwegian one:
http://tinyurl.com/27xap
Tor Olav
