Darren New <dne### [at] san rr com> wrote:
> Warp wrote:
> > So because the makers of the compiler are lazy they force the
> > user of the language to make bad code?
> Correctamundo! Welcome to commercial programming!
If I'm not completely mistaken this thread was about what would be
useful features and what would be unnecessary features for a theoretical
future OO scripting language for POV-Ray.
Last time I checked POV-Ray was not commercial and the developers didn't
have really tight deadlines.
> > C++ does multiple inheritance quite efficiently, and even if it didn't,
> > why should it matter? You just need to know how heavy multiple inheritance
> > is and then decide whether to use it or not in your application.
> Spoken like someone who writes all his own code without using someone
> else's libraries. Very good. :-)
I do use someone else's libraries a lot. For instance, I use the STL
libraries in almost every single C++ program I make. I do know most of
the advantages and disadvantages (including bottlenecks) in them.
> > One could argue that virtual functions are inefficient because they
> > produce internally an indirect function call (subroutine call to an
> > address got from behind a pointer got from behind a pointer), which
> > potentially make them slightly slower than regular function calls.
> Of course, that assumes the compiler's too stupid to turn this into a
> direct call in the case that there's no actual dynamic dispatch in the
> program. Same kind of thing. Lazy compiler writers. ;-)
If a member function has been declared virtual in C++, there's no way
the compiler can know at compile time there will be no more than one
derived class implementing that function. It can't even theoretically
check this at linking time because some code in a dynamic library (which
may change in the future) may implement that virtual function.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Christopher James Huff <cja### [at] earthlink net> wrote:
> > I can't see interfaces as anything else than very limited classes.
> Because you're stuck in thinking about things in terms of C++...I think
> it'd help you to learn a few more object-oriented languages.
Actually I was thinking in terms of Java. My comment was in no way
related to C++.
> You asked why one would forbid multiple inheritance. The ones doing the
> forbidding are the compiler writers. Hence, the answer is from a
> compiler-writer's point of view. Compiler-writers don't *use* multiple
> inheritance. They *implement* it.
That's exactly my point.
The fact that implementing multiple inheritance in a compiler is
laborious shouldn't be a good-enough reason for depriving the user of
the compiler from the possibility of using multiple-inheritance for
something useful.
It's a bit like "sorry, I don't know how to implement function calls
in my compiler, so you'll just have to make your code without function
calls". Not acceptable. :)
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
> Of course, this is basically doing what language-level
> constant references would do, and isn't much simpler...
Exactly my point. :)
> > That doesn't mean it shouldn't be made secure.
> It does mean it should be made as simple as feasible. Lack of constants
> hasn't done much harm in POV-Ray.
This is because you can pass things by value and because there isn't
really any modules with a state (which you could break by accident).
But as soon as you introduce modules (which work like libraries) you
need some security features to avoid the user breaking their functionality
by accident.
> Yet, just 2 posts up, you said
> > For example, in Java I see two types of classes: The regular ones
> > and the extremely limited ones which they call "interfaces".
> > What I wonder is why have two types of classes like this when just
> > one type suffices? IMO interfaces cause more problems than they avoid.
> You need to learn to stay on topic. ;-)
I don't understand where I went off-topic.
I said that I don't like Java interfaces and I don't understand why
there needs to be any. So IMO this new scripting language doesn't need
any interfaces á la Java.
In article <4032b303$1@news.povray.org>,
Tom Melly <pov### [at] tomandlu co uk> wrote:
> IMHO this comes down to 'pov ain't oo' - I don't think anyone denies
> that oo capabilities in pov wouldn't be at the very least interesting,
> but that's not the issue....
Now, what was that you were saying anyway? I never figured out if you
thought OO capabilities were interesting or not...though this thread
makes it clear that at least some people consider them to be of great
interest. It's almost at the 200 message mark...
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
In article <403b2846@news.povray.org>, Warp <war### [at] tag povray org>
> related to C++.
I meant that you're looking at Java in terms of C++, by considering
interfaces to be multiply-inherited, limited classes.
On Sun, 22 Feb 2004 01:11:47 -0800, Tek wrote:
(Just a hint: start a new thread "Cast operators are evil" and I'll
agree at once)
>My point is that a+b takes a different length of time according to the types of
>a and b, where as MyMatrixAddFunction(a,b) takes the same length of time always,
I don't know what you want to state above. I think everybody will
agree that adding two matrices will take more time than adding two
integers. An operator adding two matrices takes the same time as your
MyMatrixAddFunction() function.
>plus you can search for it to see where it's executed in the code,
Ok, this might by an advantage.
>plus you can
>stick a nice big comment on the prototype of it saying "//avoid calling this
>unless really necessary, it's very slow" so that anyone who doesn't know how to
>add these two things has to look up the function prototype and read the comment
>and reconsider the code they're writing.
If someone is new to the project (as he doesn't know how to add 'these
two things') you have to train him anyway.
Using appropriate operators is IMHO more intuitive (and as fast as
your My...Function() above).
>I'm not trying to suggest the source looks nicer with more function calls, it
>certainly doesn't. I'd even say I like operator overloading a lot, it's
>extremely useful in high-level programming applications. I'm merely saying that,
>in practice, it makes it easier to write code that is much more complex to
>execute than it is to read or write. This is both it's strongest and weakest
>point.
I don't get the point. All that I know if I see 'My...Function(a, b)'
in the code is "Either a or b, or both of them are not simple types",
it doesn't give me any hint/warning about it's complexity.
>> The macros required to do trivial colour/vector arithmetic are
>> 'information hiding' in the worst sense. They blow up source code and
>> add visual noise which makes it sometimes almost impossible to see
>> what's going on.
>As I said, I support using + for vectors since that's what it will compile to.
>Although I don't really see your point about visual noise, function calls
Think of the core steps of an algorithm as signal, the code you
write/read as noise.
>certainly make it harder to write clearly readable code but since it's harder
>all it takes is more effort.
Yes. Harder to write it once, *and*
- harder to read always,
- harder to find bugs,
- easier to hide bugs,...
>Programming isn't about making things easier for
>the programmer, it's about making the end result better. In application software
>or high level programming these two ideas are very compatible, but in time
>critical stuff like game engines people like me have to give ourselves headaches
>trying to optimize out one cycle in a render loop in order to improve the
>performance of the game. Operator overloading hinders us in this quest.
>Damn that made me sound so cool...
Andreas
On Sun, 22 Feb 2004 12:33:36 -0500, Christopher James Huff wrote:
>In article <n8ag309hemfhpmj8jnt5j5s3k8gr66rm62@4ax.com>,
> Andreas Kaiser <aka### [at] nurfuerspam de> wrote:
>> This might be a 'learning' problem if you aren't aware of the
>> operators 'hidden' complexity.
>Only if the code is poorly designed. You shouldn't have to care about
>the hidden complexity. It doesn't matter one bit how the = operator
>copies a string, only that it does so.
This was meant from a newbie's point of view where 'a *= b' might
appear to be faster than a call to 'MyMatrixMultiplyMatrixEq(a, b)'.
>> >So do functions.
>> Yes, same problem here. There's no correlation between length of
>> function name and complexity.
Oh, I see, I forgot the smiley.
Please read it as "... 'problem' ...".
>It's not a problem. It's a feature. Code written without functions is
>called spaghetti code, it ain't pretty and it is very inefficient and
>unmaintainable. Or should functions that do more have longer names?
This is what I wanted to point out.
> How long should POV-Ray's main() function be?
As short as possible.
Andreas
> though this thread
I am still unconvinced that the greater majority will be served by the
addition of OO capabilities. I see a handful of dedicated programmers
in this discussion discussing what makes a program OO compliant but the
average joe-blow POV-Ray user is conspicuously absent in this discussion.
How much program bloat will it add and how many people will be served by
it? If it's just to provide a new toy, for a few dedicated programming
enthusiasts, rather than to act as a significant improvement for the
mainstream user, I don't think it is worth the effort.
Ken Tyler
In article <403C146F.38604E10@tag.povray.org>,
Honestly, it won't add much bloat. And everyone who uses POV will be
served by it, even if they don't use the features directly. It would
make it easier for the programmer types to create extensions for POV
(lens flares, for example), and make those extensions easier to use.
About the bloat issue: actually, it would be a good idea to replace the
parser completely rather than trying to wedge OO features into this one,
in which case the result could be much faster and more efficient than
the present parser. And remember that non-programmers do use the work
that programming enthusiasts create. The main point of object
orientation is to make it possible to have a simple way to use complex
things, without caring about the guts.
Okay, you obviously don't understand my point, so I'll try to come at it from a
different angle:
I'm sure you would agree there are some applications for which assembler is
better suited than smalltalk, right?
One is basically the lowest level of coding, the other is more or less the
highest.
But, most people don't use either! That's because both extremes have problems
caused by being too low level, or too high level.
All that I'm saying is that in my experience the games industry likes to be at a
slightly lower level than C++. Overloaded operators are one of the things we
prefer to do in the low-level way rather than the high-level way.
Obviously it compiles to the same code but so do all high level languages, it
all ends up as assembler in the end. It's just a question of what level you wish
to think & code at.
Tek
www.evilsuperbrain.com
I heard Ken saying "average joe-blow" wasn't participating in this long
discussion, so I'm here.
"Christopher James Huff" <cja### [at] earthlink net> wrote in message
news:cjameshuff-01630D.22313524022004@news.povray.org...
I guess it could be, if I followed any of this talk at all.
Simple can be good, but... What I'm imagining happening is that a simple
sphere might look like:
ThisSphere.sphere {<1,2,3>,1}
And continued usage (adding a color for example):
ThisSphere.color {<0.1,0.2,0.3,1,0>}
Where MySphere remains defined but gets additional info attached to it. Or
all at once:
ThisSphere.sphere.color {<1,2,3>,1,<0.1,0.2,0.3,1,0>}
Then raytraced when only the name stands alone:
ThisSphere
And so it's difficult to think of doing this for evermore complicated
things. Am I on the wrong track to believe this way? Such as, perhaps, Ken
has too? Apologies if I've gone astray but I had to reread much of this
thread again and i still am unsure of the potential OO-like SDL has, good or
bad.
Bob H.
I would like to see a MyMatrixAddFunction() which adds two matrices
together and which takes the same length of time independently of how
big the matrices given as parameters are.
That's a big like claiming that std::sort() always takes the same length
of time (even if you use it only with one type of parameters).
Besides, it's not 100% sure that a function called "MyMatrixAddFunction()"
will always take the same amount of time because you can overload that
function name to do something else with some other types (in the exact
same way you can overload operators to do that).
They will.
Learning to program OO programs is not the only way of benefiting from it.
It's obvious that if POV-Ray had a full-featured object-oriented scripting
language, only a few percentage of POV-Ray users would learn to use it at
its full strength.
However, that doesn't mean only this small percentage will benefit from it.
Having a good, full-featured OO language means that those hc programmers
can make better libraries which are more powerful and very easy to use.
If designed correctly, everyone can use these libraries without much
effort or learning, thus indirectly benefiting from the power of the
language.
Think of it like this: You don't need to know how your fully graphical
operating system works internally: The hc programmers which made that OS
have already figured out the difficult parts for you and made a simple
user interface for you to benefit from these properties. Even though
you may not know how to program hardware and other types of low-level
things, you still are indirectly benefiting from it because someone else
made an easy-to-use interface to use it.
However, these few hc programmers need the tools to make their programs.
If they don't have the tools, then everyone is on their own.
In article <403c3ec3$1@news.povray.org>,
For example, being able to make a lens flare object that you can
translate around, put in a CSG, etc.
That wouldn't be any syntax I recognize. It could easily end up looking
like:
def ThisSphere = sphere {<1,2,3>,1}
ThisSphere.pigment.color = <0.1,0.2,0.3,1,0>;
> all at once:
def ThisSphere = sphere {<1,2,3>, 1 pigment {<0.1,0.2,0.3,1,0>}}
The dot syntax is just about always used for accessing parts of an
object, not for creating one. Like vector .x, .y, .z, or color .red,
.green, etc.
> ThisSphere
There's several ways adding the object to the scene could be handled,
this is one way.
Yes. You're assuming you would have to do everything in a much more
complex fashion, this is not the case. The final result could be very
similar to the current POV language in general use.
In article <06nn30d5mm6n9obft2tquhgr82le6s4jok@4ax.com>,
And I've seen people ask if functions and variables with longer names
were slower to access (in C++), I've even seen code with shortened names
to maximize speed...but this kind of newbie misconception shouldn't last
long, and is no argument against operator overloading.
In article <403b27c6@news.povray.org>, Warp <war### [at] tag povray org>
However, there are cases where the compiler can figure out which
inherited implementation is desired and turn a member function call into
a static call, or even inline it. Pretty much whenever the exact type of
the object being referred to is known.
C++ doesn't play particularly well with dynamic linking. C++ RTTI and
virtual functions can cause many problems with it.
In article <403b9397@news.povray.org>, Warp <war### [at] tag povray org>
And that's where you keep going off topic. We're not talking about Java
interfaces, we're talking about interfaces.
news:cjameshuff-625719.08263725022004@news.povray.org...
Or
> > all at once:
> .green, etc.
Ahh yes, thanks for that clarification. I suspected as much but it was
looking to me like everything was to be built in the same way as accessing
it later.
> > ThisSphere
> this is one way.
I like not having to use object {ThisSphere}, so this is a good thing I
think. Minimized scripting in the same vein as not needing parent wrappers,
which I believe you actually mentioned back in the thread someplace, could
be nice. Maybe not clear until learning what's what, but easier to write.
Okay. But, admittedly, it would still become more code-like for the writers
of it. Yet, presumably, easier to use the result. Regardless, I think all
this will come down to a widened dividing line between casual artists and
data-crunchers. Since no one knows the future for certain it could go either
way, good or bad thing. Maybe no worse than other changes had been. Hmmm...
That's a statement not to be taken too lightly. The halo, semicolons,
patterns... sounds ultra mild compared to most of the talk in this thread.
Bob H.
In article <403d0e51$1@news.povray.org>,
> it later.
You could create a language in such a way, but it would be quite
strange...actually, JavaScript is a little similar. But none of the
syntaxes I've seen suggested for POV would do it this way.
I think you might be referring to my "#declare MyObj = object {MyObj
translate...}" example. I would actually prefer some kind of wrapper,
though maybe not of that exact form. Something like:
scene {
MyObj;
AnotherObj;
AndAnotherOne;
SomeProcedureThatReturnsAnObject();
ObjectMaker.MakeAnObject();
Basically, any statement that results in an object puts an object into
the scene when used within a scene {} block. Outside a scene block, the
object just gets ignored. Otherwise you'll run into annoyances when you
call something that returns an object that is only desired some of the
time. Say you have a procedure that does something to an object and
returns that object for convenience, but you sometimes need to call it
but don't need the returned object. Without the scene{} block
restriction, you'd have to do something like declare a dummy variable
just to hold the object you don't want...annoying.
I also think it makes things a bit clearer to have some kind of wrapper
for the object name.
Well, it won't make the internals of a lens flare system any easier for
non-coders to understand, but it will make it easier for them to use it.
Objects are typically seen as "black boxes", they can be very complex
inside but nobody has to care about that, they only use the stuff on the
outside.
> Regardless, I think all this will come down to a widened dividing
> line between casual artists and data-crunchers.
I don't think so. It will mean more is possible entirely within POV
script, so the "data crunchers" won't have to go to external tools, and
the casual users have a much shorter distance to go before they can
understand and create similar things. POV-artists and POV-coders, rather
than POV-artists and C++/Java/Python-coders-who-export-POV-code.
news:cjameshuff-6C16F7.17001225022004@news.povray.org...
> scene {
> MyObj;
> AnotherObj;
> AndAnotherOne;
> time.
---snip---
Yes, I can see the reasoning here. This whole discussion, of what I didn't
skip anyway, was causing my mind to wander and think about it being possible
to write a piece of the SDL likened to the way a #macro() is now but with
far more interaction. And so, in that way, I thought of it as allowing for
subsets of a new kind of SDL which are callable at any time; same as the
program code itself. Maybe the term would be soft-code rather than
hard-code. From that idea I could see it as not needing every designation
such as would be if a material{} had to always be written out in full for a
simple color.
Anyway, I think I'm understanding it better now that I spoke up. It surely
is of the realm of programming before the final usage could come into play.
But I feel I've backtracked here by rehashing what's probably already been
said.
Bob H.
In article <cjameshuff-DF3DAB.08451225022004@news.povray.org>,
I forgot to mention it, but you might want to look up "fragile base
classes".
"Warp" <war### [at] tag povray org> wrote in message news:403c6c39@news.povray.org...
What I mean is that "+" should always take the same length of time, and should
not be confused with something that will take a different length of time.
Though I'm tired of repeating myself. If you disagree with me that's fine, but
you still seem to misunderstand what I'm saying, and I've got tired of
explaining.
Honestly I was just trying to point out we don't do this in the games industry,
not start a debate based on confusion...
Tek
So what's the difference between Java interfaces, your interfaces and
abstract classes?
> classes".
But I was not talking about changing base classes. I was talking about
changing derived classes. There's a big difference.
> I mean, Java interfaces are specific to Java, generic interfaces aren't,
> and abstract classes can actually have code and stuff in them and Java
> doesn't support that. Why do you ask?
That doesn't really tell what these "generic interfaces" are, and how
they are different from either abstract classes or Java interfaces.
I know the latter two, but I have no idea what these "generic interfaces"
could be.
> They're interfaces that can't have code and aren't specific to Java.
That's like saying that a "generic int" is a variable which can have
an integer value and is not related to C.
That statement doesn't make any sense.
> For example, one could ask "Should a generic int be limited in size in a
> new programming language? If so, should a generic int throw an error on
> overflow or just silently wrap around?" You're not asking specifically
> in the context of C, for which the decision has already been made.
> You're asking in the context of a new language which hasn't been
> invented yet.
The difference is that basically you are saying that these "generic
interfaces" are identical to Java interfaces, but have nothing to do
with Java interfaces...
