![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Does someone knows how to convert 3D scenes to Depth Images (or Layered
Depth Images). I know some guys that have done that by modifying Pov-Ray (
http://www.cs.nthu.edu.tw/~chunfa/pcm2002.pdf ) but I don't know how.
Thanks,
Rodrigo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <400da1ca$1@news.povray.org>,
Several people have done this, it's a pretty easy patch to create. I did
it by adding a special global_settings option, I think Ron Parker did it
as a command line option, and MegaPOV versions earlier than 1.0 allowed
the depth information to be output with a post-process filter. However,
it isn't absolutely necessary to modify POV to do so, it's just the
easiest way...you can give all objects a flat white texture with ambient
1 and use black fog (or a flat black texture and white fog), or give
everything a texture using a spherical pattern centered on the camera.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank You very much.
de news:cja### [at] netplex aussie org...
> http://home.earthlink.net/~cjameshuff/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
