POV-Ray : Newsgroups : povray.advanced-users : HF + ground fog !? Server Time
18 Oct 2026 12:31:45 EDT (-0400)
  HF + ground fog !? (Message 1 to 5 of 5)
Subject: HF + ground fog !?
Date: 9 Nov 2003 13:31:31
Message: <3fae8803@news.povray.org>
Hello. I try to use a ground fog that is upside an HeighField (with "hollow"
keyword) this HF is located at 0.0 on Z axix, up to 1.0. I put a ground fog
from 0.0 to 'alt' 3.0 and I try with differents distances. But pov said that
my camera is inside à non-hollow objet, the fog doesn't work ! If I replace
this HF with a plane... It's work ! Is there a bug ?
Thanks...
Subject: Re: HF + ground fog !?
Date: 9 Nov 2003 14:07:18
Message: <3fae9066$1@news.povray.org>
PS : The 'inverse' keyword doesn't work too !
Date: 9 Nov 2003 14:15:22
Message: <3fae924a$1@news.povray.org>
"_Light_Beam_" <s.f### [at] tiscalifr> a écrit dans le message de
news:3fae8803@news.povray.org...
Well, hf have been used with ground fog for a while, so if there's a problem
here it must be rare indeed. To debug this, you need to make a minimal scene
demonstrating the problem (only camera + light + fog + hf). My first guess
is that something else in the scene, or something specific to this
particular hf, is causing the problem, but it's impossible to say without a
minimal demo scene.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 9 Nov 2003 18:00:30
Message: <3faec70e$1@news.povray.org>
Sorry... I've found the solution : There where a (old test) plane 30 units
lower than HF, but he was hollow too, I removed it and its works BUT I don't
know why a infinite Y plane 30 units under the HF removes my fog !!!
Date: 9 Nov 2003 18:52:48
Message: <3faed350$1@news.povray.org>
> I don't
A plane's "inside" is not necessarily underneath it. If you defined your
plane like this:
plane {
-y, 30
then it will be solid everywhere *above* y = -30. Instead, you can define it
like this:
plane {
y, -30
and it will be solid *below* y = -30.
 - Slime
 [ http://www.slimeland.com/ ]
