POV-Ray : Newsgroups : povray.advanced-users : image_map transparency vs. difference Server Time
18 Oct 2026 13:31:29 EDT (-0400)
  image_map transparency vs. difference (Message 1 to 11 of 11)
Subject: image_map transparency vs. difference
Date: 13 Oct 2003 12:21:09
Message: <3f8ad0f5$1@news.povray.org>
I recently discovered image map alpha channel transparency and have a couple
of questions/observations:
(1) I did some comparison tests between differencing out ten holes in the
side of my model airplane to create windows vs. using a PNG image map where
the alpha channel holes in the map create the transparencies. I was
expecting the image map method to be slightly faster, but it was
consistently over 40% faster (and the gap only widened as I added more
windows). Can anyone who is familiar with the internal workings of POV-Ray
explain why this is so? Intuitively it would seem that using image map
transparency "stores" the differencing calculations statically so they're
only calculated once (when you create the image map in the first place, for
which I used POV-Ray, btw), and at runtime all of the differencing
calculations are unneeded; POV-Ray just wraps the image map around my
airplane fuselage cylinder and then creates a "hole" wherever a light ray
strikes a transparent pixel in the alpha channel of the image map... is that
a fair approximation of what's happening?
(2) Here's something I really don't understand: Obviously the trade-off of
using image maps vs. differencing is that you must use fairly large image
files to get acceptable results; otherwise, if the camera gets too close to
the model you start to see jagged edges around the window "holes". But when
I created a 4000x4000 version of my image map, the rendering time was almost
*exactly* the same as when I was using a 1000x1000 PNG file. The amount of
memory used jumped considerably, of course, but the average rendering time
between the 1000x1000 and 4000x4000 image maps was essentially unchanged. Is
that about right?
TIA...
Scott Gammans
Subject: Re: image_map transparency vs. difference
Date: 13 Oct 2003 13:09:08
Message: <3f8adc34$1@news.povray.org>
"Scott Gammans" <dee### [at] yahoocom> a écrit dans le
message de news:3f8ad0f5$1@news.povray.org...
that
Other people will explain the details, but differencing many objects from a
main one is not very efficient and leads to long render times. The trick is
to cut the object in several pieces, have 1 or 2 difference per piece and
then union{} the pieces. Of course, this is not always possible but any
repeating objects such as windows should be treated that way whenever
possible.
Is
> that about right?
Experience shows that image_maps are very efficient so it's not really
surprising. The worse that can happen is RAM trouble.
About the jaggies, did you try interpolate 2 on the maps ? It can help
sometimes.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 13 Oct 2003 14:19:23
Message: <3f8aecab$1@news.povray.org>
Hi Gilles! Thanks for the fast response.
a
is
> possible.
And this is one of those cases where it wouldn't be practical. My model has
some pretty complex shapes other than cylinders which have transparencies,
and differencing those shapes into pieces ground my workstation to a halt
(some of the shapes are sheared with matrix{} and differencing something
that has been matrix-sheared didn't seem to work too well).
I guess that makes sense... why calculate a hole when you can look it up in
a static bitmap? As for memory, my workstation has 2 GB of RAM so I don't
think memory will be a problem.
> sometimes.
I knew I forgot to ask something in my original message... yes, I did try
interpolation and method 2 (bilinear interpolation) seems to give the best
results as the POV-Ray help file suggests. I still get better results going
with a higher-rez bitmap, but only for extreme closeups, so I'm content to
create two sets of image and bump maps (one set of low-rez maps for
animations and distance shots, and one high-rez set). But here's the
thing... when interpolation 2 is selected for all of my image/bump maps, the
rendering time slows down only slightly (very nearly within the range of
statistical insignificance, from the 10 test runs I performed) over using no
interpolation at all. So my question is, why would you *not* want to use
bilinear interpolation on your image and bump maps?
Thanks!
Date: 13 Oct 2003 14:23:11
Message: <MYDPoGA7xui$EwUn@econym.demon.co.uk>
You may find some enlightenment as to what's happening in my Holes
Tutorial <http://www.econym.demon.co.uk/holetut/>. Or by taking a close
look at the differences in the statistics that are produced when you run
the scenes.
Basically what happens is that POV can't create efficient automatic
bounding for differences, so each ray is being tested against the
fuselage and against every object that's differenced from it. So if you
have 10 windows, each ray is being tested for intersection with 11
objects. The more windows you have, the more intersection tests are
performed on each ray.
If you use the alpha channel approach, then each ray is only being
tested against the single fuselage object. The number of holes doesn't
affect the number of intersection tests.
>that about right?
It takes exactly the same amount of processing power for POV to look up
the contents of point <2000,2000> in a 4000x4000 image map as it does to
look up the contents of point <500,500> in a 1000x1000 image map. As
long as you have enough free physical memory to hold the whole of the
large image in RAM the speed should be the same.
If you can derive an equation which specifies where the windows are
located, then you could use a pigment function instead of an image map.
This should give you smooth edges at any magnification. This should be
nearly as fast as using an image map unless your equation turns out to
be very complicated.
The one thing that you can't do with the alpha channel approach is to
deal with a fuselage that has thick walls.
Mike Williams
Gentleman of Leisure
Date: 13 Oct 2003 15:11:30
Message: <3f8af8e2$1@news.povray.org>
Hi Mike,
> the scenes.
That makes eminent sense... thanks for the 'splanation (and the online
tutorial!)
I learn something new about POV-Ray every day, it seems like. I never
understood what Function Image was for until you gave that example just now.
Fascinating... I will definitely give that a try.
You can't? That's not what I'm seeing. My fuselage has walls which are 0.1
POV-Ray units thick. Image-mapped alpha transparency seems to work just
fine... there's definitely a recessed, three-dimensional appearance to the
windows, just like I had when I was differencing the holes out. By "thick
walls" do you mean, for example, 1 POV-Ray unit thick on an box{5,-5} (i.e.,
a wall with a thickness that is a significant % of the size of the object)?
Thanks for taking the time to respond.
Date: 13 Oct 2003 17:19:39
Message: <3f8b16eb@news.povray.org>
message de news:3f8aecab$1@news.povray.org...
has
To be frank, when one wants to model real-life objects with a certain
accuracy, primitives and CSG do have limits and the price to pay in terms of
conception and rendering time may just be too high. Curves, bevels, holes
and uv-mapping are more the realm of mesh modellers.
I agree that interpolation could certainly be turned on by default. This is
probably a legacy issue, as this may not have been desirable when 386s were
considered as fast machines. There are other features in the same situation
actually (ambient > 0 in standard textures for instance).
G.
- Posters
Date: 13 Oct 2003 17:33:10
Message: <cjameshuff-28DB2A.17305113102003@netplex.aussie.org>
In article <3f8ad0f5$1@news.povray.org>,
It doesn't create a hole, the surface is still there, it is just
transparent. This technique is a sometimes-useful hack, but does not
have any actual effect on the geometry of the object.
> that about right?
The work to find the pixels involved and interpolate between them is
constant, and independent of the resolution of the image. Pretty much
just clamp the coordinates to [0, 1], multiply by the width and height
and round down to get one corner pixel, and simply add integers from
there. It will be slightly slower due to more memory being accessed, but
probably not by enough to reliably measure. Unless you run out of RAM
and start swapping...
http://tag.povray.org/
Date: 13 Oct 2003 17:37:28
Message: <cjameshuff-9110A7.17351013102003@netplex.aussie.org>
In article <3f8af8e2$1@news.povray.org>,
If you take a closer look, you will see that the holes have no "sides".
You are just making transparent areas in the skin of the object, the
result will look like two thin layers. Irregular holes will look
especially bad this way. And it does depend on thickness, but there
isn't any simple relation, it depends highly on the situation. You will
probably usually get away with it in paper-thin objects and other
situations where you wouldn't see the sides of the hole.
Date: 13 Oct 2003 17:40:49
Message: <cjameshuff-8372CB.17383013102003@netplex.aussie.org>
In article <3f8aecab$1@news.povray.org>,
Pretty much only if you want the mosaiac effect of nearest-neighbor. The
speed issue was more important on older computers, when just displaying
the image was a significant amount of work for a machine to do.
Date: 13 Oct 2003 19:33:30
Message: <3f8b364a$1@news.povray.org>
Hmm, yes, if I get really, really close I do see two thin layers. I would
have to get so close, though, that the ragged edges of the image maps would
be more noticeable. From the distances that I'm planning to view the model,
the eye is fooled into seeing the two ultra-close layers as one "wall".
Date: 14 Oct 2003 11:10:22
Message: <3f8c11de$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
Well yes, my choice of words was poor. I realize that there isn't an actual
CSG operation performed, but the effect to the viewer is essentially the
same: you now have a transparent area in the shape of the transparent area
in your image map.
> > The amount of
time
unchanged. Is
> > that about right?
Which is what I'm seeing. Thank you very much for taking the time to
respond!
