POV-Ray : Newsgroups : povray.advanced-users : Weird POV crash. ARGH! Server Time
4 Nov 2026 20:03:41 EST (-0500)
  Weird POV crash. ARGH! (Message 1 to 12 of 12)
Subject: Weird POV crash. ARGH!
Date: 24 Aug 2003 08:53:01
Message: <3f48b52d@news.povray.org>
Ouch.
Dozens of hours into rendering of this nice, complex scene, with radiosity
and AA turned on, continuing after one BSOD and one power failure, POV
(official release) blurts out this...
'Rendering Error: No textures in multi-texture CSG object.'
WTH? The scene renders at lower res (320x200) just fine, so the scene itself
should be pretty much all right. But even that takes about four hours, so I
guess the 1024x768 one would have been... um, forty hours. But there's no
way to continue after this kind of error, so I'm left with a three-quarter
image.
Could anybody enlighten me about how this can happen and if there's any way
to avoid it? I know it's not memory, I got 512M and POV took some 12M.
-- Me
ps. No, I won't attach the scene file. Not only is it taking ages to render,
it also has several MB of stuff in mesh #includes and imagemaps and such.
Subject: Re: Weird POV crash. ARGH!
Date: 24 Aug 2003 14:50:08
Message: <3f4908e0$1@news.povray.org>
In article <3f48b52d@news.povray.org> , "J.Random Raytracer"
Because the object causing this error simply isn't visible then...?
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Aug 2003 14:57:35
Message: <3f490a9f@news.povray.org>
> Ouch.
Please note: This is *not* a crash.  Your subject line it totally
misleading.  This is a simple error message!
Please use the correct terminology in the future.  A crash is an abnormal
termination of the program, not any error the program displays and lets you
continue to work with it.
    Thorsten
Date: 24 Aug 2003 14:58:58
Message: <3f490af2$1@news.povray.org>
> to avoid it?
I would try to remove all cutaway textures.
    Thorsten
Subject: Re: Weird POV 'crash' (abortion or is it a bug?) ARGH!
Date: 25 Aug 2003 15:52:51
Message: <3f4a6913@news.povray.org>
Well,
    in reply to 1, the scene does not have any objects that small and it
renders just fine at hi-res without radiosity.
    in reply to 2, this kind of fully non-obvious error is nasty in the
manner that it does not quite allow continuing the work since it gives
little clue about what is wrong, and IMO it looks like one that should have
been caught already in the parsing stage, and while it is not a total system
crash or program error, it still very well qualifies as Abnormal End.
    and to 3, if there are features that do not work in conjunction but are
not documented incompatible (like cutaway_textures and radiosity appear now)
then it's a bug. And at least 98% of the only cutaway_textured object is
already rendered at that stage, although there is no way knowing where the
radiosity pincushion might get its rays to.
But I'll try it anyway. It's not a big change. Thankx.
    'J.R.R'
Date: 25 Aug 2003 17:23:07
Message: <3f4a7e3b@news.povray.org>
"J.Random Raytracer" <wyr### [at] hotmailcom> a écrit dans le message de
news:3f48b52d@news.povray.org...
> POV took some 12M.
Are you sure of that figure ? It seems very low for a radiosity scene
requiring 40 hours to render and using several MB of meshes, image_maps and
such.  I know that in the past, POV-Ray running out of memory gave me some
strange errors.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 26 Aug 2003 02:40:21
Message: <3f4b00d5$1@news.povray.org>
In article <3f4a6913@news.povray.org> , "J.Random Raytracer"
In that case, if you can create a minimum scene using only the
cutaway_textures object that reproduces the problem, it would help to
improve this.
No, the termination is no abnormal.  It is simply unexpected for you, but it
is *not* an unintended program behavior to terminate at the given point.
Whether it should terminate where it does is a totally different issue, and
I agree that it should not terminate there *if* possible.
I neither said nor inferred that it has to do anything with cutaway_textures
in conjunction with radiosity.  This is just some wild guess on your part!
As you have not provided a scene showing the problem you have with the
current behavior - which is, as I pointed out not nice but intentional
rather than random - there is no way of telling what actually happens.
    Thorsten
Date: 26 Aug 2003 11:28:42
Message: <3f4b7caa$1@news.povray.org>
Try to see how much virtual memory pov has been using?
Date: 26 Aug 2003 12:21:55
Message: <3f4b8923@news.povray.org>
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3f4a7e3b@news.povray.org...
> > POV took some 12M.
and
> strange errors.
Well, it certainly was under 20M... I just restarted a continue of the scene
with a slightly modified scene to get rid of the cutaways. (fingers crossed)
And the several MB of meshes is just the file size on disk; in memory they
certainly should be much smaller!
And, getting a scene that takes lots and lots of hours to render is easy if
you're an isosurface freak like me, and put in enough many complex big glass
objects with interiors and fresnel reflections and other fun stuff. :-)
There's only 1200 frame level objects, so it's not that complex as scenes
go.
    'J.R.R'
Subject: No more unwanted POV phenomenon, yay! (was Re: Weird POV crash. ARGH!)
Date: 26 Aug 2003 16:13:51
Message: <3f4bbf7f@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3f490af2$1@news.povray.org...
way
> > to avoid it?
>     Thorsten
Well, that did it. Slightly mangled pic in p.b.i. Whee. Thanks again.
    'J.R.R'
Subject: Re: No more unwanted POV phenomenon, yay! (was Re: Weird POV crash. ARGH!)
Date: 26 Aug 2003 16:25:00
Message: <3f4bc21c@news.povray.org>
In article <3f4bbf7f@news.povray.org> , "J.Random Raytracer"
> way
>> > to avoid it?
>>     Thorsten
You are welcome.
Nevertheless, it would still be nice to have a simple scene which
demonstartes the message you reported.  It might be it would then be
possible to find a way to handle it at parse time rather than render time.
    Thorsten
Date: 26 Aug 2003 19:01:22
Message: <3f4be6c2$2@news.povray.org>
This is probably caused by a slight misuse of the cutaway_texture feature.
The syntax of cutaway_textures allows you to create a situation where the
texture is undefined for a surface in the CSG object.  Unfortunately, POV
won't know this until render time, because POV doesn't pre-compute CSG
operations.  If POV were to decompose the CSG object into a mesh, for
example, it would be able to determine this situation before render-time.
When a Ray in POV hits a surface with an undefined texture at runtime, this
error message is generated.
The solution would be to carefully review the texture definitions and
applications for your objects that use the cutaway_textures feature.
Remeber that the default texture might not be applied for some objects
within the CSG object (otherwise cutaway_textures wouldn't work).  Make sure
every surface of your object will have a texture defined.
-Nathan
"J.Random Raytracer" <wyr### [at] hotmailcom> wrote in message
> Ouch.
itself
I
> image.
way
> -- Me
render,
