POV-Ray : Newsgroups : povray.advanced-users : Creating blurred image via textures...? Server Time
4 Nov 2026 21:37:59 EST (-0500)
  Creating blurred image via textures...? (Message 1 to 18 of 18)
Subject: Creating blurred image via textures...?
Date: 17 Jun 2003 11:30:03
Message: <3eef33fb$1@news.povray.org>
Lets say I have a picture. Via patterns, averaging
pigments, layered textures etc I'd like to blur the
image_map. How would I do that? I've first though
about translating the image_map off to the right,
and then rotate that translation, i.e. translating the
image to the right, then down, then left, then up.
The more samples I take, the more I average together.
This obviously doesn't truly blur the image and is
very visible as a circular effect... Any ideas?
Tim Nikias v2.0
Email: Tim### [at] gmxde
Subject: Re: Creating blurred image via textures...?
Date: 17 Jun 2003 14:56:43
Message: <cjameshuff-513CC2.13472517062003@netplex.aussie.org>
In article <3eef33fb$1@news.povray.org>,
It sounds like you are translating the individual pigments to points on
the perimeter of a circle. Try translating them to random points inside
the circle instead.
http://tag.povray.org/
Date: 17 Jun 2003 15:46:05
Message: <3eef6ffd$1@news.povray.org>
Not sure what circular effect you are seeing, you might
try something like the following, it seemed to look like
bluring to me.
#local Blur_Image  = pigment {
  image_map {
    png "testimg.png"
#local Blur_Left = pigment { Blur_Image translate <0.01,0,0>};
#local Blur_Right = pigment { Blur_Image translate <0,0.01,0>};
#local Blur_Up = pigment { Blur_Image translate <-0.01,0,0>};
#local Blur_Down = pigment { Blur_Image translate <0,-0.01,0>};
box {
  <0,0,0>, <1,1,0.001>
      average
      pigment_map {
        [1, Blur_Image]
        [1, Blur_Left]
        [1, Blur_Right]
        [1, Blur_Up]
        [1, Blur_Down]
    finish { ambient 0.3 }
  translate <-0.5,-0.5,0> // center on the origin
Date: 17 Jun 2003 16:42:58
Message: <3eef7d52$1@news.povray.org>
Random positions -inside- a circle should look good.
But it will render a *lot* quicker if you can find some way to blur the texture
before you apply it.
Tek
http://www.evilsuperbrain.com
"Tim Nikias v2.0" <tim### [at] gmxde> wrote in message
news:3eef33fb$1@news.povray.org...
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
Date: 17 Jun 2003 16:59:53
Message: <3eef8149$1@news.povray.org>
Doh! I just read your reply to my other post on p.b.i. Now I understand why you
want to avoid processing the image beforehand :)
Tek
news:3eef7d52$1@news.povray.org...
texture
> Tek
> > Tim Nikias v2.0
Date: 17 Jun 2003 17:27:44
Message: <3eef87d0$1@news.povray.org>
I've found a way. I find it pretty neat, cause I
just LOVE when I can do all kinds of stuff with
POV alone...
What I do:
Render image with only specular highlights, rest
black.
Load that via image_map. Fiddle with patterns so
that I have the image_map only from <0,0,0> to
<1,1,0>, with an outer border in pure black.
This pigment is then translated around a circle
with quasi-even distribution (achieved using a
neat fibonacci-distribution method which requires
no heavy processing, but just a single float value
to generate position).
Voila! The image is blurred!
Now, since this blurs the main specular highlights away,
I just add another layer with the unblurred specular
highlights.
Done! I'll post a nice example shortly.
Tim Nikias v2.0
why you
> Tek
Date: 17 Jun 2003 17:39:16
Message: <cjameshuff-B27A79.16295917062003@netplex.aussie.org>
In article <3eef7d52$1@news.povray.org>, "Tek" <tek### [at] evilsuperbraincom>
> texture before you apply it.
Use an image_map of a function image of a pigment function with the
blurred pigment.
image_map {
    function xRes, yRes {
        pigment {average...}
Date: 17 Jun 2003 17:57:14
Message: <3eef8eba$1@news.povray.org>
> image_map.
It should be possible with functions, but will that will
be slow and limited to grayscale.
You can also mildly blur an image_map with my bicubic
interpolation patch, but thats's limited to 16 samples, so
no huge blur radius.
Lutz-Peter
Date: 17 Jun 2003 18:04:03
Message: <3eef9053@news.povray.org>
Did it with pigment-patterns alone, but had to
go through a function once to apply my own
color-map for transparencies. Thanks for
the suggestion anyways!
Tim Nikias v2.0
> blurred pigment.
> image_map {
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 17 Jun 2003 18:05:21
Message: <3eef90a1$1@news.povray.org>
I've done it averaging quasi-even distributed samples
in a pigment and pass that through a function to
apply my own color-map for transparency-handling.
Want to experiment a little with how many samples
may be used for that...
Tim Nikias v2.0
> > image_map.
> Lutz-Peter
Date: 17 Jun 2003 19:42:51
Message: <cjameshuff-ACC062.18333417062003@netplex.aussie.org>
In article <3eef9053@news.povray.org>,
The point of using a function image would be for rendering
speed...evaluating the function/average pigment can get quite slow, you
can do it once at parse time and get a faster render. If you're just
rendering the image on a plane to just do a post-process filter, this
probably won't help.
Date: 17 Jun 2003 19:44:56
Message: <cjameshuff-1E88FC.18353917062003@netplex.aussie.org>
In article <3eef8eba$1@news.povray.org>,
pigment {average
    pigment_map {
        [1 function {R_Func(x, y, z)} color_map {[0 rgb 0][1 red 3]}]
        [1 function {G_Func(x, y, z)} color_map {[0 rgb 0][1 green 3]}]
        [1 function {B_Func(x, y, z)} color_map {[0 rgb 0][1 blue 3]}]
Date: 18 Jun 2003 04:04:36
Message: <3ef01d14$1@news.povray.org>
Hm.. I don't understand what you're after.
What I'm doing now is take several pigments
and average them for the blurring effect. I then
wrap this into a function and apply my own
color_map. So I'm passing it through the function
like you suggested. Or am I misunderstanding
something?
Do note that I do need transparency based on
the brightness, so I'm not sure what you're after.
Are you suggesting I should use image_map function
to create an internal image-map, then pass that to
a function again, for me to apply the transparency?
Tim Nikias v2.0
Date: 18 Jun 2003 04:26:20
Message: <3ef0222c$1@news.povray.org>
I've just tried and compared the image_map
approach to the approach I used. You're
idea about passing the pigment through the
image_map function moves the load off of
the tracing process onto the parsing process.
So, depending if I want quick renders or
quick parsing, I set up a switch so that one might
choose freely where the timing should rise.. :-)
I'm wondering though, if there'd be a method
to output that image_map function on the fly,
that'd be neat!
Tim Nikias v2.0
> something?
> Tim Nikias v2.0
Date: 19 Jun 2003 10:33:09
Message: <cjameshuff-DC15C5.09231519062003@netplex.aussie.org>
In article <3ef0222c$1@news.povray.org>,
Exactly. If you were using the blurred pigment in an actual scene, you
could save rendering time this way. But if you are just putting the
pigment on a plane to render a blurred image, it isn't as useful.
> that'd be neat!
I'm not sure what you mean...are you talking about automatically
generating the function-of-image-map-of-pigment-function construct? That
could be done with a simple macro.
Date: 19 Jun 2003 12:41:31
Message: <3ef1e7bb@news.povray.org>
What I meant is that if POV-Ray creates an internal
image-map, that one could be saved to disk, couldn't
it? And I don't mean rendering it alone to get an
image. While POV-Ray parses, it could output the
data it saves for the internal image-map to an
image...
Tim Nikias v2.0
> > that'd be neat!
Date: 20 Jun 2003 10:56:03
Message: <cjameshuff-E738C6.09455120062003@netplex.aussie.org>
In article <3ef1e7bb@news.povray.org>,
> image...
This would be possible to implement. You could even do it in POV Script
with an ASCII image format. Unless there is some use for this within the
scene file, it might be better as part of a post-process stage...one
thing I've always wanted was the ability to create and save multiple
image buffers. You could create multiple post-processed versions, and
combine them into more versions, etc.
Date: 30 Jun 2003 11:23:41
Message: <3f0055fd$1@news.povray.org>
I used this to create a blurred image texture by adding small scale bozo to
the coordinates.  It looks a little like smeared chalk.
Bye,
Hans Mikelson
Christopher James Huff wrote:
> pigment {average
>     pigment_map {
#declare fbi    = function  {pattern {bozo turbulence .015 octaves 5 omega
1.3 lambda 1.5 scale .001}} ;
#declare fimage = function {pigment {image_map {png "image8.png"}}} ;
#declare T_Blur01 =
texture
    //pigment {
    //image_map {
    //    function 100, 100 {fimage(x,y,z)}
  pigment
   {average
    pigment_map
        [1 function {fimage(x+fbi(x,y,z)*.1, y+fbi(x,y,z)*.1,
z+fbi(x,y,z)*.1).red} color_map {[0 rgb 0][1 red 3]}]
z+fbi(x,y,z)*.1).green} color_map {[0 rgb 0][1 green 3]}]
z+fbi(x,y,z)*.1).blue} color_map {[0 rgb 0][1 blue 3]}]
    finish {
        ambient 1.0
        diffuse 0.0
