POV-Ray : Newsgroups : povray.advanced-users : specular highlight bug? Server Time
18 Oct 2026 14:26:59 EDT (-0400)
  specular highlight bug? (Message 1 to 12 of 12)
Subject: specular highlight bug?
Date: 23 May 2003 15:39:33
Message: <3ece78f5$1@news.povray.org>
Why does the specular highlight vanish if I make my light source shadowless?
Is there any way round this?
simple test scene:
//the blue light has a specular highlight, the red does not.
sphere { z*3, 1 pigment { rgb .5 } finish { specular 1 roughness 0.01 } }
light_source { <-1,1,-1>*1000 rgb <1,0,0> shadowless }
light_source { <1,1,-1>*1000 rgb <0,0,1> }
Any help would be much appreciated, it's causing massive slowdown in my render
to test shadows for 50 light sources.
Tek
http://www.evilsuperbrain.com
Subject: Re: specular highlight bug?
Date: 23 May 2003 16:34:33
Message: <3ece85d9$1@news.povray.org>
Not a bug, a feature. Shadowless light_sources were designed to be used
as fill lights, to simulate interdiffuse reflections which produces no
noticeable highlights. I guess removing the highlights gave a speed
boost also.
I know of no speedwise workaround.
Povingly,
Philippe
Date: 23 May 2003 16:47:30
Message: <3ece88e2@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> a écrit dans le message de news:
3ece78f5$1@news.povray.org...
Try using light_groups.
camera {location  -z*5+y*5 look_at   y}
light_group{
    light_source{-z*1000, rgb 1 rotate x*40 rotate y*40}
    sphere{0,1 translate y pigment{rgb x} finish{phong 1}}
    global_lights off
plane{y,0 pigment{rgb 1} }
light_source{-z*1000, rgb 1 rotate x*40 rotate y*40 shadowless}
BTW, that was one of the reasons we used a lot of light groups in the space
image (www.oyonale.com/iss) so that objects wouldn't project shadows on each
other and still have highlights.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 23 May 2003 17:35:16
Message: <3ece9414@news.povray.org>
Well my problem is that I have a light dome with 50 light sources, so if I have
shadows turned on at all there's a significant performance hit, even when just
testing for self-shadowing.
Ah well, I guess I should just be more patient and allow more time for
rendering.
Tek
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3ece88e2@news.povray.org...
> light_group{
>     global_lights off
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 23 May 2003 17:36:49
Message: <3ece9471$1@news.povray.org>
We could do with a seperate no_specular tag or something...
Ah well, it's not a big enough problem for me to bother writing my own patched
version of POV :)
Tek
"Philippe Debar" <phd### [at] wanadoobe> wrote in message
news:3ece85d9$1@news.povray.org...
> boost also.
> Povingly,
> Philippe
Date: 24 May 2003 02:40:03
Message: <3ecf13c3@news.povray.org>
In article <3ece88e2@news.povray.org> , "Gilles Tran" <git### [at] wanadoofr>
Well, that is after all one of the main reasons why light_groups exist :-)
And they are also fairly fast, or, to be precise, there is next to no speed
penalty on objects not lit by those light sources.  Nevertheless,
light_groups could still be a bit faster if shadow rays could be controlled
as well as some people have requested in the past...
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 24 May 2003 11:25:01
Message: <web.3ecf8e07ac50e57f84d065310@news.povray.org>
Yap.. That isn't bug. But I have found a serious problem from POV-Ray
highlights. It's impossible to create some metallic highlights because
POV-Ray takes highlight color from DIFFUSE reflectance..
Matti
Date: 25 May 2003 17:59:34
Message: <3ed13cc6@news.povray.org>
Um... specular highlights take their colour from the light source [and the
pigment colour if it's metallic]. They're not directly related to the diffuse
property.
Tek
"Matti Karnaattu" <nomail@nomail> wrote in message
news:web.3ecf8e07ac50e57f84d065310@news.povray.org...
> Matti
Date: 26 May 2003 03:19:18
Message: <3ed1bff6$1@news.povray.org>
diffuse
> property.
Unless you're specifying "metallic"
 - Slime
[ http://www.slimeland.com/ ]
Date: 26 May 2003 03:22:25
Message: <3ed1c0b1@news.povray.org>
But I thought that objects in one light group still projected shadows on
objects in a different light group?
 - Slime
Date: 28 May 2003 01:48:33
Message: <cjameshuff-664287.00495628052003@netplex.aussie.org>
In article <3ed1bff6$1@news.povray.org>, "Slime" <slm### [at] slimelandcom>
> > diffuse property.
I believe that's what Tek meant by "and the pigment colour if it's
metallic". That's what it's supposed to do, and from looking at the
source code that's exactly what it does. More specifically, the specular
contribution of each layer uses the pigment of the same layer (the
variable Layer_Pigment_Colour in the source code). I'm not sure why
Matti thought it used diffuse...
http://tag.povray.org/
Date: 31 May 2003 08:55:02
Message: <web.3ed8a5c8ac50e57f84d065310@news.povray.org>
>property.
Pigment colour is diffuse reflectance in POV-Ray. Highlights colour should
be taken from specular reflectance which is reflection colour in POV-Ray.
Matti
