POV-Ray : Newsgroups : povray.advanced-users : Max-value with function int() Server Time
4 Nov 2026 21:45:59 EST (-0500)
  Max-value with function int() (Message 1 to 19 of 19)
Subject: Max-value with function int()
Date: 13 May 2003 19:02:20
Message: <3ec1797c$1@news.povray.org>
Hello,
when I was testing how I can translate a float like
1.23456789e-28
into a 6 bytes notation for a ppm file I noticed that
the float function int() has a maximum value.
Try this:
#declare Num1 = pow(2,30);
#declare Num2 = pow(2,31);
#declare Num3 = pow(2,32);
#declare Int1 = int(Num1);
#declare Int2 = int(Num2);
#declare Int3 = int(Num3);
#debug concat("\nNum1 = ",str(Num1,0,-1),
       " | Num2 = ",str(Num2,0,-1),
       " | Num3 = ",str(Num1,0,-1))
#debug concat("\nInt1 = ",str(Int1,0,-1),
       " | Int2 = ",str(Int2,0,-1),
       " | Int3 = ",str(Int3,0,-1),"\n")
The result for me was:
Persistence of Vision(tm) Ray Tracer Version 3.5 win32 (.icl)
Num1 = 1073741824.000000 | Num2 = 2147483648.000000 | Num3 = 1073741824.000000
Int1 = 1073741824.000000 | Int2 = -2147483648.000000 | Int3 = -2147483648.000000
There is no warning about a max value in the manual.
Maybe it is wise to do this.
Jaap Frank
Subject: Re: Max-value with function int()
Date: 13 May 2003 19:37:18
Message: <3ec181ad@news.povray.org>
Seemingly POV-Ray does an "(int)(x)" operation, when it should instead
make a "floor(x)".
Date: 13 May 2003 23:06:19
Message: <cjameshuff-8D127F.23063713052003@netplex.aussie.org>
In article <3ec181ad@news.povray.org>, Warp <war### [at] tagpovrayorg>
> make a "floor(x)".
Not floor(), the int() operation is a bit different, which is why POV
has both floor() and int() functions. floor() rounds to the next lower
integer, but int() truncates the fractional part, effectively rounding
towards 0. The standard C rint() function may be a better way to
implement this.
http://tag.povray.org/
Date: 14 May 2003 08:45:04
Message: <3ec23a4f@news.povray.org>
> implement this.
  Rounding would change its behaviour, which might not be good (eg. int(0.6)
would now give 1 instead of 0).
  If the different behaviour of floor() with regard to negative values is
a problem, then the solution is easy: x<0 ? -floor(-x) : floor(x)
Date: 14 May 2003 10:30:29
Message: <3ec25305@news.povray.org>
This snippet also shows what is happening, perhaps more clearly:
#declare r = pow(2,31) - 3;
#declare i = int(r);
#while (i>0)
   #declare r = r + 1;
   #debug concat("r = ", str(r,0,-1), ";  int(r) = ", str(i,0,-1), "\n")
This produces the following three lines in the Messages pane (with POV-Ray
3.5 on WinXP):
r = 2147483646.000000;  int(r) = 2147483646.000000
r = 2147483647.000000;  int(r) = 2147483647.000000
r = 2147483648.000000;  int(r) = -2147483648.000000
So, this demonstrates this implementation of POV represents integers with a
32 bit number wheel, that wraps from positive to negative values at 2 raised
to the 31st power (2^31, 2**31, or pow(2,31). This is of course because the
high order bit is used as a sign bit.
Suggestions:
Anyone working with large numbers should be made aware that POV maps all
real numbers to this number wheel when the int( ) function is used;
This awareness could be made available by modifying the entry for the int( )
function in the POV manual;
It would be nice to suggest a good alternative for persons whose work is
affected by this. It would be helpful if this was also included in the
manual.
An alternative that should work in all cases is
// given an original float f of unknown magnitude that might exceed the
limits of the int( ) function
#declare tmp = floor ( abs( f ) );
#declare f = ( f > 0 ? tmp : -tmp);
(Above is untested; beware possible typos, etc, and perhaps others should
check my logic)
Will Woodhull
Thornhenge, SW Oregon, USA
willl.at.thornhenge.net
PS-- it should be noted that the size of the number wheel that int( ) uses
is compiler dependent. The limit will probably be 2^63 on the newer machines
that are coming out, and probably 2^15 on antiques using 8086 code.
"Jaap Frank" <jjf### [at] xs4allnl> wrote in message
news:3ec1797c$1@news.povray.org...
> Hello,
> 1.23456789e-28
> Try this:
1073741824.000000
> Jaap Frank
Date: 14 May 2003 10:35:48
Message: <3ec25444@news.povray.org>
Correction to earlier post:
#declare f = ( f < 0 ? -tmp : tmp);
Date: 14 May 2003 16:38:42
Message: <3ec2a952@news.povray.org>
In article <3ec25305@news.povray.org> , "Will W" <wil### [at] NOSPAMwizzardsnet>
Nobody ever said POV-Ray offers infinite precision.  To the contrary, it has
been said very often that very small or very big numbers when used will not
always produce the desired results.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 14 May 2003 16:51:09
Message: <3ec2ac3d@news.povray.org>
  I still think that (C's) floor() should be used instead of (C's) int()
for the POV-Ray int() function.
  Since you can represent 5000000000.25 with povray's identifier, I don't
see any reason why POV-Ray's int() should not return 5000000000.
  (Or better "x<0 ? -floor(-x) : floor(x)" to maintain the same behaviour.)
Date: 14 May 2003 17:29:50
Message: <cjameshuff-59FA63.17301314052003@netplex.aussie.org>
In article <3ec23a4f@news.povray.org>, Warp <war### [at] tagpovrayorg>
You're right, rint() doesn't do what I thought it did. Your expression
should do the right thing without stomping on the precision. Perhaps
adding a separate round() or rint() built-in function would be useful as
well.
Date: 14 May 2003 17:56:44
Message: <3ec2bb9c$1@news.povray.org>
I found more unexpected limitations:
When using the functions mod(A,B) and div(A,B)
you can't give values for A greater then int(float),
else the results are wrong.
Obviously both functions needs integer values.
Maybe a hint in the manual about the integer functions
is needed.
Jaap Frank
Date: 14 May 2003 19:26:38
Message: <3ec2d0ad@news.povray.org>
  I suppose these use internally C's int() as well. Using fdiv() and floor()
instead should fix the problem.
Date: 14 May 2003 19:46:03
Message: <3ec2d53b@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3ec2a952@news.povray.org...
with a
raised
the
has
not
>     Thorsten
I feel like you've missed my main point and focused on a minor explanatory
detail.
I don't see where there is anything wrong with the POV implementation of
int( ). The limitations of integer arithmetic are well known; the SDL's
limitations in this regard are no different from most C and C++ compilers,
and derivative works.
With one exception.
Generally in other packages the limitations of int( ) function are
documented. This is missing from POV's documentation. An additional sentence
that stated the range of integers would bring POV's int( ) function into
alignment with similar packages, and help savvy SDL writers avoid problems
in their code.
A broad statement that very "very big or very small numbers when used will
not always produce the desired results" implies, to me, that there are the
usual problems with very large or very small floats, like around pow(10,80)
and pow(10,-80).  Two billion and change just isn't all that big-- and is an
entirely different kind of accuracy problem.
I'm not saying you've got an ugly baby or it needs corrective surgery. It's
a bright, happy baby, and a lot of fun. But there is a button undone on her
documentation.
Will Woodhull
Date: 14 May 2003 20:02:15
Message: <3ec2d907@news.povray.org>
news:3ec2ac3d@news.povray.org...
behaviour.)
fwiw, I agree that this is the clause most people should be using instead of
int( ).
Will Woodhull
Date: 15 May 2003 08:15:24
Message: <3ec384dc$1@news.povray.org>
In article <3ec2d53b@news.povray.org> , "Will W" <wil### [at] NOSPAMwizzardsnet>
> in their code.
But generally you get a ready made library and/or documentation specific to
one platform.  Adding such arbitrary detail to the POV-Ray documentation
helps nobody but will confuse many.
The real problem is that the parser currently does not prevent you from
shooting yourself in the foot.  I agree that it should enforce bounds
whenever possible.  Nevertheless, finding by trial and error what works and
what doesn't really does not help because:
1. It can be found in the source code more accurately.
2. The behavior is intended as is right now.
3. Values of this size will not be useful for anything in a scene.
4. It will not be changed in POV-Ray 3.x.
    Thorsten
Thorsten Froehlich
Date: 15 May 2003 11:19:54
Message: <3ec3b01a@news.povray.org>
news:3ec384dc$1@news.povray.org...
sentence
problems
> > in their code.
to
Actually, the documentation of cross platform packages I've used generally
cover this by saying that there is a limit, which is dependent on the
platform or compiler settings, and advises that those who need to know where
to go to find that other documentation. In my opinion, including detail like
this is in the documentation of something like the int( ) function is not
arbitrary. It has a specific use in decreasing the time a reasonably astute
user with a bit of experience will spend in searching through documentation
or developing his own methods of assessing the limits of the software.
In the current discussion, if this detail had been included in the docs this
discussion would have much more quickly moved on to how to get around the
limitation. The idea of using "#declare x = (x<0 ? -floor(-x) : floor(x));"
would have been brought to the fore much sooner. A lot of verbiage would
have been avoided. Also, I would not now be wondering if I've stepped into
some kind of pissing contest with a youngsta programma who still has too
much ego involvement with his code. I'm not saying that is the case; I don't
know. The doubt does interfere with communications though-- I'm spending a
lot more time reviewing my words trying to make sure I don't step on a
tender ego than I would if we were in, say, a perl forum. I don't much like
having to go to that extra work.
> whenever possible.
Actually, I prefer parsers that do not enforce arbitrary bounds. I've become
pretty perlish in my coding practices in the last decade, and I now
recognize my responsibility as the programmer is to know what the limits are
and to break them only when necessary. The parser's responsibility goes no
further than accurately translating what I write into executable code. If I
want to do something "illegal", I don't want some stupid parser yapping that
I can't do that. So I'm not sure who you are agreeing with here, but it
isn't me. My position is not that the parser should enforce limits, but that
the documentation should clearly state those limits where it is reasonable
to expect to see them stated. It would also be helpful to point to an idiom
that can get around the limitation, when doing so would cost no more than a
handful of text characters.
This conflicts with your statement that the boundaries are platform/compiler
dependent, and not a part of POV itself.
I have said nothing anywhere about changing the intended behavior. My
concern is about communicating what the intended behavior is, in a clear
fashion, in a place where it is intended that the user should go to find out
such things.
I don't think you can count on that never happening. I'm amazed at the
rendering times some povers have the patience for, and the level of fine
detail that some strive for. Between fractals and meshes, and renderings at
7800x5200 pixels or more,  and faster CPUs, it won't be long before some
povers are attempting to iterate over such quantities-- 2 billion and change
isn't so very many snowflakes, grains of sand, leaves in a forest, etc. I
really wouldn't be surprised if some users aren't already deep in the "more
than 2 billion" territory. You have just given me cause to wonder how many
people have silently set aside projects that showed a lot of promise in the
early detail phases of development, but blew up when they attempted to scale
them to full size.
But will the documentation be changed in POV-Ray 4.x?  After this
discussion, there is now the possibility. Before this discussion, there was
not.
>     Thorsten
Thorsten, thank you for your time.
Will Woodhull
Date: 18 May 2003 21:39:51
Message: <cjameshuff-B2DD2F.20402818052003@netplex.aussie.org>
In article <3ec3b01a@news.povray.org>,
Of course there's a limit, and anyone coding these types of scenes
should already be aware of that. It's not anything special to POV-Ray.
> I can't do that.
Right...the parser shouldn't say anything if you do something wrong, it
should just mysteriously fail. That's wonderful for user-friendliness.
(Yuck, Perl...)
No it doesn't. By looking at the source code, you can tell what
platform-dependant constants are being used.
> not.
It most likely will, as 4.0 will be a different program. Using the
documentation for previous versions often does not work very well.
Date: 19 May 2003 10:42:57
Message: <3ec8ed71$1@news.povray.org>
In article <cja### [at] netplexaussieorg> ,
>> I can't do that.
> (Yuck, Perl...)
Sorry, haven't had time to follow-up on this thread.  Your answer is exactly
what I would have answered.
    Thorsten
e-mail: tho### [at] trfde
Date: 20 May 2003 16:07:25
Message: <3eca8afd$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3ec2d0ad@news.povray.org...
The first three numbers below exceed the max-value 2 147 483 647 for div() and
mod().
> N(11 117 333 955)N(4 254 934 330)N(3 900 569 407)N(7 382 340)N(3358)N(970)}//  -
Warp -
Haven't this give you troubles?
Jaap Frank
Date: 20 May 2003 21:44:38
Message: <3ecada06@news.povray.org>
> mod().
> Warp -
  Nope. By chance, not because I knew how to avoid it.
  mod() doesn't matter because it only takes the least-significant values
of the number. If the most-significant are lost in a double->int conversion,
that doesn't affect the value of mod.
  As for div(), I suppose that what the POV-Ray source code is doing is
something like "int(a/b)" (instead of "floor(a/b)" as it really should).
That is, the division is done first, and the conversion to int only to the
result. Since for example 11117333955/13 = 855179535, which is well
inside the 31-bit range of int, the result is (luckily) not cut.
