POV-Ray : Newsgroups : povray.advanced-users : Max-value with function int() Server Time
29 Jul 2024 02:21:44 EDT (-0400)
  Max-value with function int() (Message 1 to 10 of 19)
Subject: Max-value with function int()
Date: 13 May 2003 19:02:20
Message: <3ec1797c$1@news.povray.org>
Hello,
when I was testing how I can translate a float like
1.23456789e-28
into a 6 bytes notation for a ppm file I noticed that
the float function int() has a maximum value.
Try this:
#declare Num1 = pow(2,30);
#declare Num2 = pow(2,31);
#declare Num3 = pow(2,32);
#declare Int1 = int(Num1);
#declare Int2 = int(Num2);
#declare Int3 = int(Num3);
#debug concat("\nNum1 = ",str(Num1,0,-1),
       " | Num2 = ",str(Num2,0,-1),
       " | Num3 = ",str(Num1,0,-1))
#debug concat("\nInt1 = ",str(Int1,0,-1),
       " | Int2 = ",str(Int2,0,-1),
       " | Int3 = ",str(Int3,0,-1),"\n")
The result for me was:
Persistence of Vision(tm) Ray Tracer Version 3.5 win32 (.icl)
Num1 = 1073741824.000000 | Num2 = 2147483648.000000 | Num3 = 1073741824.000000
Int1 = 1073741824.000000 | Int2 = -2147483648.000000 | Int3 = -2147483648.000000
There is no warning about a max value in the manual.
Maybe it is wise to do this.
Jaap Frank
Subject: Re: Max-value with function int()
Date: 13 May 2003 19:37:18
Message: <3ec181ad@news.povray.org>
Seemingly POV-Ray does an "(int)(x)" operation, when it should instead
make a "floor(x)".
Date: 13 May 2003 23:06:19
Message: <cjameshuff-8D127F.23063713052003@netplex.aussie.org>
In article <3ec181ad@news.povray.org>, Warp <war### [at] tagpovrayorg>
> make a "floor(x)".
Not floor(), the int() operation is a bit different, which is why POV
has both floor() and int() functions. floor() rounds to the next lower
integer, but int() truncates the fractional part, effectively rounding
towards 0. The standard C rint() function may be a better way to
implement this.
http://tag.povray.org/
Date: 14 May 2003 08:45:04
Message: <3ec23a4f@news.povray.org>
> implement this.
  Rounding would change its behaviour, which might not be good (eg. int(0.6)
would now give 1 instead of 0).
  If the different behaviour of floor() with regard to negative values is
a problem, then the solution is easy: x<0 ? -floor(-x) : floor(x)
Date: 14 May 2003 10:30:29
Message: <3ec25305@news.povray.org>
This snippet also shows what is happening, perhaps more clearly:
#declare r = pow(2,31) - 3;
#declare i = int(r);
#while (i>0)
   #declare r = r + 1;
   #debug concat("r = ", str(r,0,-1), ";  int(r) = ", str(i,0,-1), "\n")
This produces the following three lines in the Messages pane (with POV-Ray
3.5 on WinXP):
r = 2147483646.000000;  int(r) = 2147483646.000000
r = 2147483647.000000;  int(r) = 2147483647.000000
r = 2147483648.000000;  int(r) = -2147483648.000000
So, this demonstrates this implementation of POV represents integers with a
32 bit number wheel, that wraps from positive to negative values at 2 raised
to the 31st power (2^31, 2**31, or pow(2,31). This is of course because the
high order bit is used as a sign bit.
Suggestions:
Anyone working with large numbers should be made aware that POV maps all
real numbers to this number wheel when the int( ) function is used;
This awareness could be made available by modifying the entry for the int( )
function in the POV manual;
It would be nice to suggest a good alternative for persons whose work is
affected by this. It would be helpful if this was also included in the
manual.
An alternative that should work in all cases is
// given an original float f of unknown magnitude that might exceed the
limits of the int( ) function
#declare tmp = floor ( abs( f ) );
#declare f = ( f > 0 ? tmp : -tmp);
(Above is untested; beware possible typos, etc, and perhaps others should
check my logic)
Will Woodhull
Thornhenge, SW Oregon, USA
willl.at.thornhenge.net
PS-- it should be noted that the size of the number wheel that int( ) uses
is compiler dependent. The limit will probably be 2^63 on the newer machines
that are coming out, and probably 2^15 on antiques using 8086 code.
"Jaap Frank" <jjf### [at] xs4allnl> wrote in message
news:3ec1797c$1@news.povray.org...
> Hello,
> 1.23456789e-28
> Try this:
1073741824.000000
> Jaap Frank
Date: 14 May 2003 10:35:48
Message: <3ec25444@news.povray.org>
Correction to earlier post:
#declare f = ( f < 0 ? -tmp : tmp);
Date: 14 May 2003 16:38:42
Message: <3ec2a952@news.povray.org>
In article <3ec25305@news.povray.org> , "Will W" <wil### [at] NOSPAMwizzardsnet>
Nobody ever said POV-Ray offers infinite precision.  To the contrary, it has
been said very often that very small or very big numbers when used will not
always produce the desired results.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 14 May 2003 16:51:09
Message: <3ec2ac3d@news.povray.org>
  I still think that (C's) floor() should be used instead of (C's) int()
for the POV-Ray int() function.
  Since you can represent 5000000000.25 with povray's identifier, I don't
see any reason why POV-Ray's int() should not return 5000000000.
  (Or better "x<0 ? -floor(-x) : floor(x)" to maintain the same behaviour.)
Date: 14 May 2003 17:29:50
Message: <cjameshuff-59FA63.17301314052003@netplex.aussie.org>
In article <3ec23a4f@news.povray.org>, Warp <war### [at] tagpovrayorg>
You're right, rint() doesn't do what I thought it did. Your expression
should do the right thing without stomping on the precision. Perhaps
adding a separate round() or rint() built-in function would be useful as
well.
Date: 14 May 2003 17:56:44
Message: <3ec2bb9c$1@news.povray.org>
I found more unexpected limitations:
When using the functions mod(A,B) and div(A,B)
you can't give values for A greater then int(float),
else the results are wrong.
Obviously both functions needs integer values.
Maybe a hint in the manual about the integer functions
is needed.
Jaap Frank
