POV-Ray : Newsgroups : povray.advanced-users : Holograms Server Time
4 Nov 2026 21:43:51 EST (-0500)
  Holograms (Message 1 to 14 of 14)
Subject: Holograms
Date: 7 May 2003 15:27:17
Message: <3eb95e15$1@news.povray.org>
Questions, questions...
Does anyone know the physics behind holograms?
(Sorry - just received a brand new Windows 2000 CD yesterday. They like to
print holograms on 'em to prove they're real... yeah, right!)
More to the point, can I draw one with POV-Ray? :-)
Andrew.
Subject: Re: Holograms
Date: 7 May 2003 22:03:33
Message: <3EB9BAE2.77607E95@pacbell.net>
For a wealth of resources on the physics and technology behind
those snazzy holograms visit - http://www.holoworld.com/
Not directly. You could generate a pattern (image) in POV-Ray but you
would still need the laser technology to actually produce a physical
working hologram.
With sufficient effort you could probably figure out a way to simulate
one in POV-Ray but I wouldn't know where to start. You may want to visit
Rune's site and see what he did to create his compact disk object. The
iridescence seen on a CD is caused by the same basic principals behind
holograms.
http://runevision.com/3d/include/include.asp
Ken Tyler
Date: 8 May 2003 02:35:19
Message: <r1ujbv4dp9lipbm3cch6hpnvg6t2068g3j@4ax.com>
On Wed, 7 May 2003 20:25:47 +0100, "Andrew Coppin" <orp### [at] btinternetcom> wrote:
I have recently shared user_defined camera patch
(http://news.povray.org/search/?s=user_defined) prepared for MegaPOV with
http://www.bdp-optics.com/ . With this extension they are now able to prepare
material to 'print' 3D images directly from POV script
(http://news.povray.org/povray.binaries.images/31396/ ). I do not know details
behind 'printing' method but you can ask them about details and ordering.
ABX
Subject: Slight revision
Date: 8 May 2003 03:35:19
Message: <3eba08b7$1@news.povray.org>
OK, on reflection maybe I was a little unclear. (Reflection, get it? Hehe...
eh... heh... oh never mind! :-P) What I ment was... can I put a hologram
into a POV-Ray scene?
Andrew.
Date: 8 May 2003 08:17:10
Message: <cjameshuff-7C21CE.08171108052003@netplex.aussie.org>
In article <3eb95e15$1@news.povray.org>,
http://www.wikipedia.org/w/wiki.phtml?search=hologram&go=Go
http://www.everything2.com/index.pl?node_id=615788
A hologram requires optical effects that POV can not simulate directly.
You may be able to get something close to what a hologram made with a
very long wavelength would look like by combining functions, but it
would not work very well and would be very slow.
http://tag.povray.org/
Subject: Re: Slight revision
Date: 8 May 2003 08:19:30
Message: <cjameshuff-CBB364.08193108052003@netplex.aussie.org>
In article <3eba08b7$1@news.povray.org>,
An actual hologram or something that looks like one? An actual hologram
is not practical, but emitting media is all that is necessary for making
something that looks like one.
Date: 8 May 2003 09:07:57
Message: <slrnbbklj9.819.steev@hot.pl>
Nie odpowiada�bym, gdyby nie to, �e autorem jest Christopher James Huff :
That's right...
Here is example :
< http://www.irtc.org/ftp/pub/stills/2002-06-30/ddreams.jpg >
(ok, it's not a _really good one_, but it's mine ;)
S�awek
  ________
_/ __/ __/ The answer is 42.
 \__ \__ \_______________________________________________________________
 /___/___/ S�awomir Szczyrba                              steev(AT)hot.pl
Date: 8 May 2003 16:55:25
Message: <3ebac43d$1@news.povray.org>
Will check these out later...
That's the information I was looking for.
Thanks.
Andrew.
Date: 9 May 2003 13:49:12
Message: <3ebbea18@news.povray.org>
Could you fake a 3d hologram with some clever bounding - similar technique
to the 'infinity cube' ?
PGP Public Key
Date: 9 May 2003 16:36:36
Message: <cjameshuff-29A217.16363809052003@netplex.aussie.org>
In article <3ebbea18@news.povray.org>,
I don't know what you expect from this...I can't see how you would get
anything like a hologram this way.
You could make the hologram as an actual shape and just make it
shadowless, and maybe fool around with the diffuse and transparency. (a
hologram is transparent, it only adds to what is behind it)
Emitting media is probably the most accurate way, though...or at least
the most like a real-world hologram. Unless you're talking about the
silvery white-light things.
Date: 15 May 2003 13:45:57
Message: <1fv0hn7.ytl47pyw72w2N%kaveh@delete_this.focalimage.com>
> wrote: > Does anyone know the physics behind holograms? > (...) > More to
> prepare material to 'print' 3D images directly from POV script
> details behind 'printing' method but you can ask them about details and
> ordering.
They are using lenticular screens, which feed each view to each eye,
giving you a stereo image. It's not a hologram, which gives you
effectively infinite views.
-- Kaveh
Date: 15 May 2003 13:45:59
Message: <1fv0hvi.1395i4lrjjj28N%kaveh@delete_this.focalimage.com>
(Sorry for late response. I have not checked posts for a while.)
This is a very interesting problem I have been thinking about for a
while. I am actually what you would call a "holographer", but relatively
new to povray. My interest is to "preview" a hologram before I make one.
So I like to see if there are any distortions of the image when I move
relative to the hologram. For example, this happens when you change the
wavelength of the reconstruction beam to that of recording. For an
example of what I mean, you can look at
http://www.bazargan.org/Swing.mp4
This is an animation done with povray, using the (forward) ray tracing
equations for obtaining a holographic image. The beauty of povray is
that it is an excellent language for putting in math formulae, and then
it renders and animates it for you!
Here is a more complex example:
http://www.bazargan.org/dispersion-comp.mp4
Here the 'object' is a horizontal line of spheres. The hologram is
viewed with polychromatic light, but the light has first been dispersed
with a diffraction grating, so that the final images are all in line.
Of course the animation you see is just a geometric grid, not what you
would "see". For instance the image is only visible by the observer (the
eyeball) when it is looking through the hologram itself, but it does
show the "swing" of a holographic image. This is already very useful for
looking at distortions, multiple-wavelength playback, etc.
The next challenge is to show a 'photorealistic' image of a hologram in
a scene. For example, you have a hologram hanging on a wall, illuminated
by a white light above it. I think we can apply the same ray tracing
formulae, but this time in a 'backward' or computer graphics sense. So
the hologram becomes a 'special' surface. When a scene is rendered, the
color of each pixel on the hologram can be calculated by taking into
account the recording geometry, the original wavelength, the final
reconstruction wavelength (or band of wavelengths) and the object.
I am not really clear about how to do this, but I have in mind some kind
of 'function' for the hologram surface. I hope this can be done in a
single pass in povray.
A very useful tool has been the Lightsys 3 macros:
http://www.ignorancia.org
which draw in a color approximating to the wavelength chosen.
Kaveh
Date: 16 May 2003 05:42:41
Message: <8dc9cvsqa7os648lbfh1a71btalq315651@4ax.com>
On Thu, 15 May 2003 18:46:00 +0100, kav### [at] delete_thisfocalimagecom (Kaveh)
Perhaps, but I just received output of my patch in this technic and it looks
very impressive.
ABX
Date: 16 May 2003 14:11:18
Message: <1fv2fup.1socxax19cw81mN%kaveh@delete_this.focalimage.com>
> very impressive.
Oh, properly done, the result would be impressive indeed, and with pov
pictures, even more impressive.
What I would love to do is to make a hologram from, say, 180 views from
pov. Give me a little time. I'm working on it. ;-)
Kaveh
